Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC > SCIC Vendor Classifieds
Old 12-12-2012, 05:20 PM   #101
Vaughn Performance
Vendor Sales Rating: (14)
Member#: 170489
Originally Posted by leopard print View Post
Hi Anthony.
I have a pretty basic question. I already have the GTWorx Bilstein/RCE Yellow combo on my 2012 WRX hatch. I'm currently looking to purchase some sways and endlinks to compliment the setup. What do you recommend? My car is a DD.
Oh, and please send me a price quote for pick up for whatever you recommend.
Thanks for your help.
I'd go with whitleine 24mm/22mm adjustable bars and kartboy solid endlinks. I'll shoot you a PM with pricing.
-Anthony
__________________
Vaughn Performance is offline   Reply With Quote
Old 12-13-2012, 02:44 PM   #102
flyguyeddy
Member Sales Rating: (4)
Member#: 236695
1995 impreza outback
dark green/greyish
car:
1995 impreza outback wagon, EG33 swap underway, stripped interior
parts gathered:
07 front sti arms
rear aluminum sti lat links
04 sti struts
03 wrx subframe and swaybar
parts on the "to get list"
04 sti rear hubs (will be paying for them today)
4/2 pot brakes, FHI or nissan, dont care which
coilover sleeves and springs @ 10"225#f/12"200#r
strut revalve by either you or odi (depending on lead time and such, i dont really care who lol)
roll cage minus a few of the bars required for rally (so i dont have to wear a helmet all the time)
Team Dynamics gravel wheels with grabber at2's
custom made camber correct 2" strut and trailing arm mount spacers (steel) and 1" subframe spacers (out of delrin)
what i want to do with this is be able to play in the mud/gravel roads locally here and run through fields and **** without having to worry about bottoming out/ ruining my suspension. a gravel revalve would probably be nice for this (as we have discussed on D.I.) i also will be driving this on the street so i dont want body roll to become an issue. would i be better off not running a rear swaybar or maybe a small one, or a nice sti rear bar and disconnects?
flyguyeddy is offline   Reply With Quote
Old 12-13-2012, 03:17 PM   #103
Vaughn Performance
Member#: 170489
The stuff that gets revalved that we do is done by Odi actually. We send work in to him.
Anyway, that's looking to be a good set up for what you have in mind. As for the swaybars, I'd run front/rear bars for tarmac, maybe the STi bars since STi arm's are going in. That's going to help with the roll on tarmac. Just disconnect the front for gravel. I have 22mm bars front/rear on my wagon. I run it with the front disconnected and leave the rear, feels excellent in dirt!! I'm on Kings and STi revalved struts. With the bars hooked up and good summer tires on, actually feels pretty darn good on tarmac!
You should add some bushings to that list as well. Since your doing a pretty extensive swap would be a good time to get some of them knocked out.
-Anthony
__________________
Old 12-14-2012, 11:45 AM   #104
flyguyeddy
Member#: 236695
dark green/greyish
which ones? arent sti parts already equipped with group n bushings?
Old 12-15-2012, 11:24 PM   #105
aveera
Member Sales Rating: (16)
Member#: 174725
2002 Wrx Wagon
Can you guys beat these prices. $385 shipped for RC Engineering 750cc injectors for my 02 Wrx? $79 shipped for a Walbro 255 LPH fuel pump with install kit shipped? Please let me know.
aveera is offline   Reply With Quote
Old 12-16-2012, 02:11 PM   #106
flyguyeddy
Member#: 236695
dark green/greyish
Sounds like a good thing to ask via pm and not in a suspension thread.
Old 12-16-2012, 02:22 PM   #107
aveera
Member#: 174725
2002 Wrx Wagon
Ok, I didn't know that there were rules to PM but I'll do that... I did not know that this was a suspension thread either, It was part of the Vendor for sale threads... sorry to disappoint you...
Old 12-16-2012, 09:31 PM   #108
flyguyeddy
Member#: 236695
dark green/greyish
title of thread: "let me help build you a suspension system that suits your needs"
you right, i have no idea why anyone would think it was a suspension thread. i apologize.
Old 12-16-2012, 10:43 PM   #109
Flames4791
Member#: 319172
2003 Impreza WRX
Platinum Silver Metallic
Hi, I have a 2003 WRX on stock suspension. I would like the front and back to balance out a bit. Right now my rear end sits a lot lower than my front, like my springs are really worn or something because its noticeably lower than my friends 2002 wrx. I would like to lower the front by about 1.3 inches and try to match that height with the rear as well. I also would like to stop the rear from sagging so much when I have people in the back seat, so maybe stiffen it up. However, I do not want to spend too much. I am thinking eibach springs with exel g struts and add 1/4 butt spacers to rear. Opinions?
Flames4791 is offline   Reply With Quote
Old 12-17-2012, 05:04 PM   #110
Vaughn Performance
Member#: 170489
Sorry for the slow response folks, was out of town Friday and the over the weekend.
The control arms and lat links. STi uses aluminum arm's, but the bushings are still normal durometer rubber.
I will PM you with that.
Springs don't really wear out, other then maybe corroding. Do you have anything else that might be adding weight to your car that perhaps your friend's doesn't (i.e speaker box etc...). If the shock's are really shot, which if they are the oem bits from 02 it's quite likely they are, that can affect things a little as well.
Also, these cars visually look higher in the front, as the front wheel arches are cut a bit higher, even if the rear is sagging a little, it will look like more then it is.
1.3" inches of lowering is a bit too low for these cars. You'll start to run into geometry issues at that height. Most springs that lower these cars that much also use rates that are much too soft, and only exacerbate the geometry issues as the suspension compresses. If your looking to lower the car a bit without spending much, you could try Swift sport springs paired with KYB GR-2 struts. This set up isn't the most performance oriented upgrade, but if your looking for a mainly cosmetic drop it's the most reasonable. It lowers the car pretty evenly, but if you still wanted to add a little more rear rake you could run the spacers out back.
-Anthony
__________________
Old 12-18-2012, 12:13 AM   #111
flyguyeddy
Member#: 236695
dark green/greyish
damn. i was hoping this wasnt the case.
well maybe then i dont have to buy a new subframe then. i can just change out the bushing on the front of the control arm to fit my current subframe, and reinforce my swaybar mount.
Old 12-18-2012, 05:57 PM   #112
Vaughn Performance
Member#: 170489
I'm not sure what you mean by that? The bushings I mean are the one's pressed into the control arms/lateral links themselves. The bushings themselves would remain the same design, just a firmer rubber, if uprated to the group N one's I mean.
-Anthony
__________________
Old 12-18-2012, 11:35 PM   #113
flyguyeddy
Member#: 236695
dark green/greyish
but couldnt i just put the GC bushing in the front of the 07 sti arms i have? that way they will fit in the 95 subframe on the car? signs point to the OD of the busing being the same as the early cars (or all of them for that matter, just changed sleeve width, which is what screws me on a gc install)
Old 12-18-2012, 11:35 PM   #114
flyguyeddy
Member#: 236695
dark green/greyish
i speak of the front control arms. i will most likely run a gd rear subframe.
Old 12-19-2012, 04:40 PM   #115
Vaughn Performance
Member#: 170489
That I couldn't tell for you for sure. I can't say we've ever tried it.
-Anthony
__________________
Old 01-04-2013, 04:44 AM   #116
MarckWRX
Member Sales Rating: (2)
Member#: 301960
2011 STi
Wrb
Hey Anthony! I bought swaybars f and r from you not long ago for my 2011 Wrx, and they were great but I want something stiffer I guess? But also I changed over to a 2011 sti sedan so what suggestions do you have as far as sway bars? Also what coilovers would you suggest I should buy?
MarckWRX is offline   Reply With Quote
Old 01-04-2013, 03:11 PM   #117
Vaughn Performance
Member#: 170489
Stiffer as in you wanted less roll, or ride quality wise? I'd suggest the same 24/22mm adjustable front/rear bars, that paired with the higher spring rates of the coilovers will make the car have very little roll in corners. You don't want to go too high in bar rate or spring rate or you'll run into problems.
I recommend going with AST 4100 single adjustable coilovers for street/track use. We can pick a spring rate depending on how much track driving you do vs street driving.
-Anthony
__________________
Old 05-01-2014, 01:20 AM   #118
Ismokeyou
Member Sales Rating: (1)
Member#: 287201
2006 2.5i
Regal Blue Pearl
Hey! You know if a 05 sti rear sway will fit on a 2006 2.5i?
Ismokeyou is offline   Reply With Quote
Old 05-01-2014, 03:06 PM   #119
Vaughn Performance
Member#: 170489
No STi rear swaybar is a little different because the rear lateral links are different between the STi and the 2.5i. I can get you a Whiteline 24mm adjustable rear swaybar for you car though if your interested? $215 for that one.
-Anthony
__________________
Old 06-10-2014, 03:53 AM   #120
Ismokeyou
Member#: 287201
2006 2.5i
Regal Blue Pearl
Picked up a 20mm wrx sway with endlinks bushings and mounts. Going to have my buddy sandblast and paint it tomorrow. Also have a whiteline rca kit waiting to be installed. What else should I replace? And what hardware do I need to install my rear sway or do I use the old bolts in the new mounts?
Old 06-10-2014, 11:20 AM   #121
Ismokeyou
Member#: 287201
2006 2.5i
Regal Blue Pearl
Anyone know what bolts I need for the mounts on a 20mm sway and endlinks bolts?
Old 07-23-2014, 04:53 PM   #122
Ismokeyou
Member#: 287201
2006 2.5i
Regal Blue Pearl
Soo now I've got the 20mm swaybar in the rear, bc coilovers sitting flush in the front and tucking a bit of tire in the rear. Installed the whiteline rca kit, what else should I do? Hah
Sent from my iPhone using NASIOC
Old 07-23-2014, 05:02 PM   #123
rymaggi
Member Sales Rating: (17)
Member#: 253442
Default Let me help you build a suspension system that suits your needs.
2006 wrx wagon
Fully built 466whp
Full v7 sti drivetrain
22 F&R sway bars HD Endlinks
RCA kit
Sti front control arms
ALK Kit
BC BR Coilovers 8/7k swift springs
Enkei RPF1's 17x9 245/40 direzzi z2's
Ride height 14" all around
Corner balanced
2.0 front camber
1.5 rear camber
6.5 caster
Want to fine tune it, replace parts need be.
Cars purpose, DD with track duties.
Looking for flat cornering and high speed stability, and also not a complete crap ride quality.
I've noticed at high speeds around bends if I throttle out or messáge the brakes at all it gives me a nasty pitch and feels like I'm going to spin out ass first.
Overall, I want it to handle like a a slot car. And be more overall stable, the car doesn't give me the feedback to be comfortable at higher speeds as I feel it should.
The first thing that came to my mind was stiffer sways and better coils.
rymaggi is offline   Reply With Quote
Old 07-24-2014, 01:58 PM   #124
Vaughn Performance
Member#: 170489
It really depends on what you are looking to achieve with your car?
Originally Posted by rymaggi View Post
2006 wrx wagon
Fully built 466whp
RCA kit
ALK Kit
Corner balanced
2.0 front camber
1.5 rear camber
6.5 caster
I would go with 24mm bars front/rear, with adjustable rear bar. Having the adjustable rear bar is nice for dialing more or less oversteer in/out quickly.
I would also start replacing some of the more major drivetrain and suspension arm bushings. That will help immensely with feedback and response. The rear gets a lot of deflection during cornering, resulting in dynamic alignment changes that equate to a less predictable rear. I would do forward/rear trailing arm bushes, as well as lat links and drivetrain bushes.
Up front I would do front control arm bushing, steering rack. I can set you up with complete bushing bundle for the rear that does the suspension links for $280, the subframe and diff lock bolts for $100.
Drop me a line on here, I can help you get an order sorted.
-Anthony
__________________
Old 07-24-2014, 02:05 PM   #125
rymaggi
Member#: 253442
For sure.
I have the whitelines steering rack bushing.
And rear outrigger bushings, Kartboy subframe lockdown bolts and rear diff bushings.
Send me a pm of the list I need and how much and when I get paid ill pm you back.
ALBANY - Need Help with an Install? Let me help! RubbleDTD Tri-State Area Forum 22 07-06-2009 10:25 PM
Why is that so funny? Let me tell you! Actually, on second thought, nevermind... Asinine Off-Topic 19 06-25-2008 07:39 PM
Hey, let me tell you something that Im telling everyone I know who cares! (or doesnt) Innocent World South West Impreza Club Forum -- SWIC 27 09-15-2006 04:02 PM
Let me help you clean out your garage - takeoffs wanted Elwood Mid West Subaru Owners Club Forum -- MWSOC 17 10-05-2004 12:41 AM
