Old 06-13-2014, 12:04 PM   #1
vicious_fishes
Member#: 158864
2003 SOHC destroker
Default FHI 2pot vs brembo rear brake bias
seeing as i couldn't get an answer in the brake section...
the brakemath spreadsheet thinks that the FHI 2pots have more braking torque. the brembo's are iirc 316mm rotors with a 36mm piston. the FHI 2pots are a 290mm rotor with a 38mm piston. but stoptech front brakes to suit brembo have LARGER pistons than to suit wrx.
what gives? are the brembo's higher torque or not?
Old 06-13-2014, 05:14 PM   #2
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Piston area times radius arm = about 2% more for FHI
KNS Brakes is offline   Reply With Quote
Old 06-17-2014, 08:59 AM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
you GOT your answer
you just didnt like it....
Old 06-17-2014, 09:14 AM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
The brembos dont have higher trq, then 2pots. They do however have more thermal dispersion. Basically the Brembos start to work better after repeated hard braking from higher speeds. 120-140+ on trackdays. Or the users "over use" their brakes and are killing them. IMO I normally find users need to upgrade their Pads, fluid and lines. If they use the right parts their current brakes will prove to be sufficient.
Of course the fanboys wont hear that...
Ian,
Old 06-17-2014, 11:11 AM   #5
vicious_fishes
Member#: 158864
2003 SOHC destroker
Originally Posted by Uncle Scotty View Post
you GOT your answer
look at the post dates/times in each thread scotty... the answers in the other thread were posted AFTER this one.
