Old 04-14-2010, 09:45 PM   #151
moreboost
Member#: 124212
06 STI
Built By Inn-Tune
Here is my finished install pics on my 06STI this will maybe give some others some ideas. I did this over a few days since it is not my DD.
Here is a pic once the trunk cover and mat are installed every thing is hidden.
Here is where I installed the gauge.
Finally the car.
moreboost is offline   Reply With Quote
Old 04-14-2010, 11:11 PM   #152
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
You have no issues on heavy breaking?
Chandy69 is offline   Reply With Quote
Old 04-15-2010, 08:32 AM   #153
JoeyOKC
Member#: 209486
you aren't using meth on heavy braking. Only
hard accel
JoeyOKC is offline   Reply With Quote
Old 04-17-2010, 02:56 AM   #154
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
hard accel
indeed...
jigga is offline   Reply With Quote
Old 04-22-2010, 10:41 PM   #155
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
Haven't installed it yet. hopefully have install pics this week. w00t!
just handed one of these kits to andy this week...hopefully itll finally get that top end we have been lookin for
vanillajuice is offline   Reply With Quote
Old 05-28-2010, 09:06 PM   #156
p19124
Member#: 130303
2004 wrx
psm
Where do most people install the feed line for your pumps comeing from your stock sti tank and level sensor
p19124 is offline   Reply With Quote
Old 06-05-2010, 05:46 AM   #157
Canonshooter
Member#: 103479
'07 Forester XT
Newport Pearl Blue
For the Aquamist HSF3 system installed in my '07 Forester XT, I used the stock windshield washer reservior. Photos below show the two float switches installed (lower one for system failsafe activation, upper for tank-low warning light), outlet tapping to pump and pump mounted next to reservior. To further protect the pump from any possible water drips or splashes, I made a splash shield out of a plastic food container and placed over the pump.
Canonshooter is offline   Reply With Quote
Old 06-05-2010, 06:40 PM   #158
Member#: 232251
Originally Posted by AEM Electronics View Post
Some of you might remember our Tangerine Dream WRX from the SEMA show a couple of years ago.
If you don't mind me asking, what kind of power was the car making and what were the flow requirements to use a two pump system?
JHowerton@Aquamist is offline   Reply With Quote
Old 06-07-2010, 09:49 AM   #159
Crimeboss
Member#: 232043
2005 WRX
Default HFS-3 in WRX (large pics)
Here are some install pictures of my HFS-3 as well on my WRX. I wanted to go for a very stealth look. I think the pump mounting came out pretty slick.
First, I made a template.
Then mount your pump to the piece of metal made from your template. Trial fit the pump on the bracket as mounting it higher or lower will influence your water outlet connection as well as clearance to the fender. The washers are used to fill the indentation where the fuel pump controller used to be.
Connect the water line before mounting the bracket to the fender area.
Relocate your fuel controller. I drilled a couple holes and moved it a few inches up.
The bracket and pump mounted to existing holes in the fender area.
STI IC tank mounted next to it.
Since my wife didn't let me get the STI back in 05 (hindsight), my car doesn't have the means to snap the tank down. Make a bracket to secure it.
Wrapped the water lines in split loom tubing and route through existing hole by wire harness.
Down the side of the car and pops out here.
Attach it to one of these.
Crimeboss is offline   Reply With Quote
Old 06-14-2010, 09:59 PM   #160
my94saleen
Member#: 97791
2006 sti
wr blue
^^ nice install. im about to do the almost the same. ? shouldnt the pump be lower or no higher than to the bottom of the meth tank. it looks like it sits almost above it. i want to do the same but mount the pump lower.
my94saleen is offline   Reply With Quote
Old 06-14-2010, 10:45 PM   #161
madcatz
Member#: 187530
Fuk UrSelf
Labonte ISG-10 with IFS-10 Failsafe and FLS-10 Low Fluid Level Switch
Noob to Meth. Found for a great deal, figured why not...... [flamesuit]
Running a PDX 40BB turbo on the LGT now, but have plans to swap to an AVO420BB unit (sitting in the closet)
thanks for the install pix (though most are pre-early 09) giving me some ideas, but ultimately will probably be installed by my tuner when the new turbo goes in
madcatz is offline   Reply With Quote
Old 06-17-2010, 04:34 PM   #162
Crimeboss
Member#: 232043
2005 WRX
I was worried about that at first. However I talked to the nice people supporting aquamist and they said it isn't a problem. Since it's such a short distance, the powerful pump has no problems drawing it up.
You can't go much lower if any in that spot. The pump outlet will start to hit the fender well. You -may- be able to make the bracket longer and move the pump lower and further away. I didn't because I was afraid it would maybe flex too much and hit inside the quarter panel.
Old 06-23-2010, 03:36 AM   #163
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Originally Posted by Canonshooter View Post
Very nice set-up nice clean interior.
dasnowman is offline   Reply With Quote
Old 06-26-2010, 09:39 PM   #164
ohm
Member#: 178468
2007 UGM STI
IAG Built
Nothing special, just a trunk mounted setup. I found some fabric to match the trunk liner, I think it adds a nice touch. Before it was all wood, looked kind of ghetto. Great part is, I can still access my jack.
ohm is offline   Reply With Quote
Old 03-17-2011, 10:36 PM   #165
wrxmadcorona
Member#: 244947
Originally Posted by stangen97 View Post
Hi,
Is it possible to give me the dimensions of the bracket for the HP pump that is mount to the 12L tank? thank you so much as i want to fab it myself.
wrxmadcorona is offline   Reply With Quote
Old 03-20-2011, 08:06 PM   #166
JesseL
Member#: 169556
07' OPB STi BW S256
01' 2.5rs GM6 w/leather!
Wiring up the LED's and switches
The bracket to replace the area where the batery went witht he controlers
More wiring up to the center console where all the switches and LED's ended up
The LED's for the SafeInjection got moved up to my cluster surround, I have Green for when it is spraying, Red for when it should be, but isn't, and white for low tank level.
The pickup from the washer tank
Bracket I made to mount the pump
Reversed intake, and the area it injects
I was only allowed to post 10 pics, have alot more, my photobucket isn't blocked if anyone is really that interested.
http://i5.photobucket.com/albums/y198/Goso/Cars/STi/
JesseL is offline   Reply With Quote
Old 04-08-2011, 04:55 PM   #167
Sensyon
Member#: 212904
2006 Impreza WRX STI
Obsidian Black Pearl
This message is deleted by the original poster.
Sensyon is offline   Reply With Quote
Old 04-08-2011, 04:58 PM   #168
Sensyon
Member#: 212904
[quote=moreboost;30412129]
What is the brand of your Gauge Mount on the Main Cluster?
Old 04-15-2012, 08:01 AM   #169
jockeygolfs
Member#: 260868
2011 STI
2011 STI Sedan. Still in the install process but my tank is done. I went with Aquamist HSF-3 and a Howerton Engineering two one gallon tank setup. I used weather pack connectors and a quick disconnect so that I can easily remove the tank from the trunk without having to open the tank up and unscrew or unplug things inside the box.
jockeygolfs is offline   Reply With Quote
Old 05-08-2012, 10:13 PM   #170
klarowe
Member#: 284753
2004 WRX STI
Couple quick questions. Right now I have an SMC setup (with Labonte MAF controller) that uses the factory washer fluid reservoir. I was hoping to clean up the engine bay a bit during my FMIC install and wanted to relocate the meth injection back to the factory IC sprayer tank. Will my current pump be adequate to pump the extra distance? Also, am I better off going with SS braided lines or what kind of lines should I get to run it to the engine bay (and where can I get them).
Thanks in advance.
klarowe is offline   Reply With Quote
Old 06-14-2014, 02:33 PM   #171
subie98
Member#: 225299
Bump! Any one else have some pictures for more ideas??
subie98 is offline   Reply With Quote
Old 06-19-2014, 09:25 AM   #172
LloydChristmas
Member#: 160516
2005 Aspen White STi
2002 Suzuki GSX-R 750
Here is what my setup looks like...I haven't ran meth in a few years cause I'm running stock internals and don't need any issues to arise.
Also, I could have used my stock I/C spray tank. Just another option.
And of course that cherry drank.
LloydChristmas is offline   Reply With Quote
Old 06-23-2014, 06:40 PM   #173
V8Slayer
Member#: 111565
2007 Legacy Spec.B
305hp/280tq EVOIII 16G
Here's my set up, pretty basic but does the job!
V8Slayer is offline   Reply With Quote
Old 06-24-2014, 12:51 PM   #174
02nismokiller
Member#: 322963
04 wrx
psm
Is that the coolingmist? How long have you been running it for? Any fail safe or no?
02nismokiller is offline   Reply With Quote
Old 06-26-2014, 06:13 PM   #175
V8Slayer
Member#: 111565
2007 Legacy Spec.B
Hey 02nismokiller. Yeah it's the Coolingmist stage 1 trunk mount kit. I've been running it for the last 2 years without issue. Being that I'm just running a low boost set up I decided against running any fail safes, it's just more for safety then for performance.
Show us your computer setups! Barnacules Off-Topic 436 02-02-2011 03:44 PM
utec and home made water/meth injection help punswrx UTEC 2 11-19-2009 03:51 PM
Water/meth injection water pump question atomic4877 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-24-2009 05:29 PM
Time Attack Setups Run Water/Meth Injection? mannslayer Motorsports 26 05-08-2008 10:36 PM
Monster TD04 and water/meth injection. fastwrx05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-08-2006 11:46 PM
