Old 06-17-2014, 11:52 PM   #1
Serkan
Member#: 180514
2004 Sti
Default Custom hood vent
I have been working on custom V mount project for a while.
My plan was to use a replica wrc style vent. But than I always wanted a kaminari hood.
I decided I could try a DIY project to make something like kaminari hood.
-I made a template from card board.
-Marked the exact corners and ends on the hood so everything is perfectly symmetrical.
-Cut the hood and the supports underneath.
-Cut the 16ga aluminum sheet. Bend the corners to the required angle.
I measured extra for the part goes beneath the hood so I can trim it so it sits flush with intercooler duct.
It will be molded to the hood skin once it is welded (or panel bonded).
Serkan is offline   Reply With Quote
Old 06-17-2014, 11:53 PM   #2
Serkan
Member#: 180514
2004 Sti
The sloping end of 5" section will be rolled so there is larger opening for air to exit.
Will look something like this
Old 06-18-2014, 02:48 PM   #3
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
Wow, that looks great so far. Can't wait to see it done
bugeyesubie is offline   Reply With Quote
Old 06-18-2014, 02:52 PM   #4
Serkan
Member#: 180514
2004 Sti
Thank you. Just wanted to share the idea. Nowhere near completion.
This is how the intercooler sits
Old 06-18-2014, 04:44 PM   #5
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Looks like a preety nice setup. The car with the kaminari is actualy mine. Im excited to see how yours turns out.
Murphdog is offline   Reply With Quote
Old 06-19-2014, 03:18 PM   #6
Serkan
Member#: 180514
2004 Sti
Very good looking car my friend.
Old 06-19-2014, 04:33 PM   #7
25rsti
Member#: 166324
Nice work so far, as always.
Old 06-20-2014, 09:05 AM   #8
apexanimal
Member#: 170186
08 Fit
looks great
apexanimal is offline   Reply With Quote
Old 06-20-2014, 09:19 AM   #9
ToneWrx02
Member#: 239095
2002 Wrx
Dayum :0 sub 4 sure
ToneWrx02 is offline   Reply With Quote
Old 06-22-2014, 01:27 AM   #10
coleman em1
Member#: 240533
2006 VF48 WRX Wagon
SRR
more!!!
coleman em1 is offline   Reply With Quote
Old 06-23-2014, 02:01 PM   #11
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Are you planning on ditching the scoop once you finished? I only ask due to my personal experience with the rally vent, it pulls lots of hot air out but it sends it right into the OEM scoop.
dangerousatom is offline   Reply With Quote
Old 06-23-2014, 05:33 PM   #12
Serkan
Member#: 180514
2004 Sti
Thank you all for nice comments. Don't have any hopes to see it finished soon. I just started it to see how it would work.
I made this thread to share the idea.
I know what you are saying. I am not sure if I will put a scoop or KS tech vent.
If I go with a scoop it will be the low profile wrx one and I would block the opening to prevent hot vented air back into engine bay.
Hopefully the vents on the sides will keep the engine bay temp low enough
Old 06-27-2014, 02:33 AM   #13
stuiephoto
Member#: 205742
1995 RSTI
Any progress made with this? Interested to see how it looks from far.
stuiephoto is offline   Reply With Quote
Old 06-27-2014, 04:34 PM   #14
Serkan
Member#: 180514
2004 Sti
Sorry, it will be a while until it is finished and painted (4-5 months)
Old 06-27-2014, 09:46 PM   #15
noahguth6
Member#: 353570
1993 Impreza L
Red
Do you care if water gets into your engine bay when you're driving in rain? How are you gonna keep water out if you do care?
noahguth6 is offline   Reply With Quote
Old 06-27-2014, 10:14 PM   #16
Serkan
Member#: 180514
2004 Sti
The vents on the sides will have shrouds underneath them. Plus there won't be any electrical components below the side vents.
Engine bay is cleaned up.
Battery, washer fluid are in the trunk. Fuse box is inside the fender well.
ABS pump and steering reservoir are hidden under the side floor (bumper area), no maf sensor. Air filter is inside the fender well. Etc...
Pretty much nothing on the sides.
As for the big vent in the front. It will have no opening to the engine bay.
Here is a pic of the engine bay
Old 06-28-2014, 01:14 PM   #17
TURBOTOD
Member#: 97130
2004 WRB WIDE STI
COBB/TIC/CUSCO/DSS/TSSFAB
Wonderful job!! I am looking at picking up a Kaminari hood as well. I simply love the design of it. I am also however thinking about contacting Carbon By Design though to implement a NACA duct for turbo cooling. It will be painted WRB with the NACA duct left exposed and the inside of the vent a paint to carbon fade.
I'm loving your engine bay man! Nicely done, especially with the chassis stiffening!
Peace
-TurboTod
TURBOTOD is offline   Reply With Quote
Old 06-29-2014, 04:43 PM   #18
BuellSki
Member#: 385645
2004 wrx sti
That hood is looking good!! Any update on the progress?
BuellSki is offline   Reply With Quote
Old 07-01-2014, 07:01 PM   #19
Serkan
Member#: 180514
2004 Sti
Small update :
I think this was the trickiest part of the project. IMO I pulled it off perfect without warping anything while bending.
You have to be creative with this kind of stuff.
I clamped a 2" pipe under the hood skin where I wanted it to curve in. Took measurements from known point and made sure both ends were at the same spot.
Than I used a piece of angle aluminum piece on top.
So the hood skin is sandwiched between the pipe and angle aluminum.
Measured all points again to make sure everything is square.
Next step requires some experience and muscle because you need to curve the skin with your hands and keep things steady at the same time.
You have to bend little by little going side to side. Not in one shot.
This is the curve I ended up with.
Old 07-08-2014, 12:54 PM   #20
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
looks awesome!!
bigolrig is offline   Reply With Quote
Old 07-08-2014, 12:59 PM   #21
jdm-az-f
Member#: 365969
Nice. Can't wait to see the finsihed product.
jdm-az-f is offline   Reply With Quote
Old 10-16-2014, 11:04 PM   #22
2JZ
Member#: 291949
Any updates?
2JZ is offline   Reply With Quote
Old 10-20-2014, 09:36 AM   #23
Serkan
Member#: 180514
2004 Sti
Yea, I will upload some updates tonight.
Old 10-21-2014, 04:57 PM   #24
wtyree
Member#: 29879
2002 WRX Wagon
Subscribed.
wtyree is offline   Reply With Quote
Old 10-21-2014, 09:55 PM   #25
Serkan
Member#: 180514
2004 Sti
Here are some pics of the little progress.
The aluminum shroud is glued with 3M panel bond. I didn't go with welding route because the hood skin would get warped.
I still have to bend some brackets to glue the front section of the shroud. Than it is time to mold it to the hood so it looks one piece.
The edges are still rough. Everything will be nice and straight when molding it.
Also the hood got sturdier after I glued the shroud. It was getting flimsy after cutting all the supports.
