Old 06-10-2014, 02:10 PM   #451
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by BeastianSTI View Post
Hot tanking really doesn't do much.
It does but not enough all by itself. Sonic cleaning is def better but regardless I'd still do some cleaning before and after.
What john said to do is something I'd hope any shop would do after the machine work.
Old 06-10-2014, 02:17 PM   #452
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Care to give us a low-down on what the process you guys would perform to prep a block to be assembled? Not just limited to Paul here either. 2Fast4u...
BeastianSTI is offline   Reply With Quote
Old 06-10-2014, 02:25 PM   #453
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
After I am done with machining I take an air gun and blow compressed air through every oil galley, in each bore (including mains) any anywhere else chips might be able to hide. Then we just hot tank, ultra sonic clean, and then I do my wipe down with ATF. Even after all of that I can still go through a whole roll of paper towels cleaning up the bores. Finish with a new microfiber. Never had any contamination failures to date.
2Fast4U1DAY is offline   Reply With Quote
Old 06-10-2014, 05:32 PM   #454
BeastianSTI
Member#: 310506
2005 WRX STi
Good info here for sure.
I feel like I shouldn't have assembled the block before having my air compressor up and running. You really can't just rely on the cleaning from a machine shop; not because they do a crappy job, but it's just not as detailed as what is REQUIRED for assembly.
Old 06-10-2014, 07:13 PM   #455
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I use carb cleaner and an air gun on the compressor. On cylinders I use the same and a sponge slog with a magnet.
spoolinsti05 is offline   Reply With Quote
Old 06-13-2014, 01:38 AM   #456
BeastianSTI
Member#: 310506
2005 WRX STi
Ok - so here is the process I have taken to clean the heads:
1. Removed all allen screws from cylinder head
2. Sprayed through all exposed holes including cam lubrication ports with brake parts cleaner
3. Filled a large bucket with hot water, a bunch of dish soap and a splash of degreaser.
4. Kept pulling head up 75% of the way out and letting it drop back it, etc to swish water through all ports.
5. Flipped head over in bucket and continued swishing.
6. Pulled the heads out of the bucket, allowing any crud to escape. Dunked and repeated.
7. Rinsed the head out through the port holes, etc. thoroughly
8. Brought head downstairs and used the air compressor to spray everything out.
9. Hit everything thoroughly with brake parts cleaner
10. Dry everything using the air compressor.
11. Installed hex plugs and covered the heads up!
All new bearings have been cleaned up as well. Once the crank gets in, she'll be ready to get mostly assembled again!
Old 06-13-2014, 11:59 AM   #457
BeastianSTI
Member#: 310506
2005 WRX STi
Company23 ring compressor came in the mail today. This thing is DEFINITELY going to work so much better than the sheet metal sleeve mechanism. I feel like I could drop a piston in with my pinky lol. Seems very easy to use too; just a worm clamp you tighten with your finger until the ends meet and you're good to go.
Old 06-13-2014, 12:50 PM   #458
uglybetty
Member#: 381907
2005 forester STI
How much crap came off the heads with all of the cleaning??
uglybetty is offline   Reply With Quote
Old 06-13-2014, 01:12 PM   #459
BeastianSTI
Member#: 310506
2005 WRX STi
The heads were professionally cleaned before I cleaned them of any bearing materials, but.. I found all sorts of little goodies in the bottom of the bucket. Not sure if they came from the exterior of the cylinder heads or inside, but I douched em out pretty good lmao
Old 06-13-2014, 02:57 PM   #460
BeastianSTI
Member#: 310506
2005 WRX STi
Well... Now that i've taken all these oil galley plugs oil ( small allen key and larger ones for coolant I think? )....
What are the torque specs for these little plugs? Do I need to apply any sealant etc to them?
Old 06-15-2014, 11:27 AM   #461
BeastianSTI
Member#: 310506
2005 WRX STi
bumpppp
Old 06-15-2014, 12:18 PM   #462
Jameshowlett
Member#: 358936
2004 WRX
Didn't go through the entire thread so I have no idea where you're at or what you're in need of, but Carey Holzman on YouTube has the break down and rebuild process for our engines. Done buy a guy named Mike Bauer he's a master subaru mechanic in AZ.
If you need spec sheets I believe flatirons tuning will send you them, you just have to call and ask.
Jameshowlett is offline   Reply With Quote
Old 06-15-2014, 12:52 PM   #463
BeastianSTI
Member#: 310506
2005 WRX STi
Yar - ive seen that one. Im looking for torque specs for the oil galley plugs on the heads
Old 06-15-2014, 04:31 PM   #464
BeastianSTI
Member#: 310506
2005 WRX STi
Anybody ?? I cant find the torque specs in the manual anywhere
Old 06-18-2014, 01:28 AM   #465
BeastianSTI
Member#: 310506
2005 WRX STi
OK - I guess you seal them up with RTV of some sort.
Next question - I cleaned the crankshaft with soap and water and ended up seeing this haze on the crank pins... Not really sure what's up with it. When I buff the crank pin with a microfiber towel but it doesn't really make a difference:
Old 06-18-2014, 11:05 AM   #466
BeastianSTI
Member#: 310506
2005 WRX STi
Bummpppp. Is this normal? I can't really feel it with my finger, but i'm not sure if the heat treating just went crazy with hot water, etc...
Old 06-18-2014, 11:28 PM   #467
Brown Ops
Member#: 291770
2004 Impreza WRX STI
Java & satin black
Dude, I just read your entire thread and you my friend are not only ballsy (rebuilding your own motor) but you are definitely a problem solver! I wish you the best in getting your ride up and running again. Definitely subscribing.
Brown Ops is offline   Reply With Quote
Old 06-19-2014, 12:01 AM   #468
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
OK - I guess you seal them up with RTV of some sort. Next question - I cleaned the crankshaft with soap and water and ended up seeing this haze on the crank pins... Not really sure what's up with it. When I buff the crank pin with a microfiber towel but it doesn't really make a difference:
Ummm... Please oil it! It is probably rusting....
cueballsi is offline   Reply With Quote
Old 06-19-2014, 12:10 AM   #469
BeastianSTI
Member#: 310506
2005 WRX STi
The crank was just in soapy water, and immediately afterwards, I started rinsing, drying and spraying it down with wd40.
Old 06-20-2014, 05:23 PM   #470
BeastianSTI
Member#: 310506
2005 WRX STi
For anyone looking on a basic break-down of how to clean a block up before assembly, here's an article I found on another forum:
http://www.dsmtuners.com/threads/how...-block.362154/
Old 06-20-2014, 07:13 PM   #471
BeastianSTI
Member#: 310506
2005 WRX STi
OK guys, one of the local builders suggested that the block wasn't machined to the right specifications. He also said that he has had to send blocks back to the machine shop many times because they were incorrectly cut.
I just measured all of the bores, and with my Fowler dial bore gauge, (.0005 accuracy?) each of the cylinder PTW clearances appear to measure .0020-.0022. Could measuring without a torque plate / the cases torqued together cause such an inaccuracy, or do you think it could be incorrectly cut?
Old 06-20-2014, 07:19 PM   #472
uglybetty
Member#: 381907
2005 forester STI
You mean your ptw clearances???
Old 06-20-2014, 07:21 PM   #473
BeastianSTI
Member#: 310506
2005 WRX STi
Yeah, sorry lol. Edited my post as well.
The PTW clearances appear to measure between .0020-.0022 with no torque plate / the cases bolted together.
Old 06-20-2014, 07:42 PM   #474
uglybetty
Member#: 381907
2005 forester STI
Wouldn't of use feeler gauhes to measure ptw clearances and the dial bore gauge to measure the mains with the cases bolted together??
Old 06-20-2014, 07:52 PM   #475
BeastianSTI
Member#: 310506
2005 WRX STi
You would use a feeler gauge between piston rings to check the piston end gap. The dial bore gauge is used to measure inner diameters of rods (w/ bearings), cylinders and main bearing clearances.
