Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-04-2014, 10:35 PM   #126
B-85
Member#: 60628
1994 Sti.94,Sold 96.
Both rear towers are done ! Did I say it is a pain to weld this stuff !!!
Well, its a PAIN to WELD! But its done.
And here is my idea to help the towers. Going to add a center plate and ties. Then after the cage is in I will tie the L&R towers together at the top.
Ideas ?
B-85 is offline   Reply With Quote
Old 06-05-2014, 09:19 PM   #127
B-85
Member#: 60628
Driver side rear main hoop base installed.
Also installed the tower arm's. this will help keep thing together ? LOL
Kool ! rozets !
Thanks Jon for the link to the DOM. Not bad $2.70 +- a foot. Will start with 5 20' sticks. Then we will see how much I can F#$@ up ? LOL
Randy
Old 06-06-2014, 08:59 PM   #128
B-85
Member#: 60628
Oh, DOM tubing ! Time to do some bending ?
Old 06-07-2014, 05:36 PM   #129
B-85
Member#: 60628
Cage starts with a paper cut out to fit. Then a test bend. This is the old school way.
Old 06-10-2014, 09:55 PM   #130
B-85
Member#: 60628
I started the main cage bar. First some bending from the plan.
Then a test fit.
Then some triming and more triming. Then some tube knoching.
And some welding.
And poof a main bar !
Some more fitting , got it about 1/16" off the main roof side frames. Kool !
And a side shot. Cleared all the door handles .
For now I will just tack the main.Will start on the overhead door bars in the AM.
Randy
Old 06-10-2014, 10:01 PM   #131
lox
Member#: 348423
08 FXT Sports
nice work Randy!
lox is offline   Reply With Quote
Old 06-10-2014, 10:28 PM   #132
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
wowee!
mikeydrives1 is offline   Reply With Quote
Old 06-11-2014, 10:03 PM   #133
B-85
Member#: 60628
Started the front pads for the door bar. And bent a test door bar. Didn't go well. Will try again AM. Long day and hot. Only 102*.
Randy
Old 06-12-2014, 10:37 PM   #134
B-85
Member#: 60628
After doing another door bar,wrong I made a test jig. And I found that I was making right door bars and trying to use them on the left side. What a dolt !:chair:
Also worked on the door bar.
More fitting Fri.
Randy
Old 06-13-2014, 11:08 AM   #135
BrockP
Member#: 379617
1997 Impreza
Olive
Coming together nicely!
BrockP is online now   Reply With Quote
Old 06-13-2014, 09:41 PM   #136
B-85
Member#: 60628
Thanks Brock.
Finished the front base plate. Man,I will be glad when I don't need to weld heavy steel to the body !!! Also bent the other door bar.
So cut up the base plate.
Weld in the bottom plate,all the way around !
Weld in the side and top plate.
And bend a door bar and fit. Easy !
Randy
Old 06-15-2014, 11:03 AM   #137
B-85
Member#: 60628
Got the other side started.
And "HAPPY FATHERS DAY !"
Old 06-16-2014, 09:55 PM   #138
B-85
Member#: 60628
Its funny how just a bar or two can make a car look like it has a cage. Working on the door bars,sill and dash bar.
Randy
Old 06-17-2014, 10:05 PM   #139
B-85
Member#: 60628
On to the dash bar. I will not use the Factory bar,it was in the way.
So,cut and fit. Did some bends to clear the A/C and heater box. Will also need to build a bracket for the steering gear.
Then some dash trimming . Had to cut the dash to make it around the cage.
Test fit the dash.
And pooof ! All done. The cool part is it fit.(This was all luck) And all the vents and defrosters will stay stock,and work ! Now on to the front/top cage bar.
Randy
Old 06-18-2014, 09:07 PM   #140
B-85
Member#: 60628
Top roof bar installed.
Guess its time for me to make a toco bender ?
Randy
Old 06-19-2014, 10:15 PM   #141
B-85
Member#: 60628
Installed the L & R guessets at the windshield and started work on the front roof bars.
Randy
Old 06-21-2014, 03:45 PM   #142
B-85
Member#: 60628
Still have some trimming to do but the drivers roof bar is done. Will need to weld them up and then trim the ends for the main bar welding. Looks like I will need one more stick of DOM (because I made some mistakes,oh test bars!) to finish the door bars. But I was close!
Going to take the weekend off, ran out of flap wheels.
Randy
Old 06-24-2014, 03:26 PM   #143
B-85
Member#: 60628
Now the fun part, welding it in and together.
Old 06-24-2014, 09:14 PM   #144
B-85
Member#: 60628
Almost all welded. Just need to cut the roof. I know,but the roof needs work on the driver side. Looks like it was patched. Maybe a tree ?
And,maybe I have just enough tubing to finish the cage ? Lets hope !
Randy
Old 06-25-2014, 10:56 PM   #145
B-85
Member#: 60628
Main cages is welded and welded to the car. Now I will install the sil and door bars.
Randy
Old 06-26-2014, 09:08 PM   #146
B-85
Member#: 60628
Door and sill bars in and the outer rear bars. Only 4 more to go. But need some tubing ! I missed by 80".
Maybe some paint Sat. ? wish, wish !
Randy
Old 06-27-2014, 09:02 PM   #147
B-85
Member#: 60628
All but one bar cut and just need to weld it up. All most done! This is a real time burner ! I don't know what a cage system cost but it must be a ton !
I don't think the strut towers in the rear are going anywhere ? LOL
Still need to cut 2 holes in the roof to finish the welds.
Randy
Old 06-28-2014, 01:37 PM   #148
kos
Member#: 118334
2005 AW RS + 2006
Time Attack WRX
Looking good Randy!
kos is offline   Reply With Quote
Old 06-29-2014, 12:42 AM   #149
B-85
Member#: 60628
Long day ! Welded up most of the things left. Also you can see how to do the top welding . LOL
You must remember the roof is in bad shape . This is not for the first timer !
Test installed the seats and the dash. After welding,things move around sometime ? Still need to order seats ? big $$$$
Look at all the bars!
Cool, the tracks even work . Their is a RallyX that I would like to go to in 2 weeks, but don't know if things will be done in time ? Mush still to do !
Randy
Old 06-30-2014, 09:57 PM   #150
B-85
Member#: 60628
Last of the bars and only the gussets left. Still need the seats to get here.
Co-drivers bar is 1 3/4" lower because the seat will be lower.
Anybody using a single point chassis jack ? Thinking about add one.
Randy
