Old 06-20-2014, 01:34 PM   #1
Dip Dungles
Member#: 383168
2017 STI
MS
Default Compound removal
Long story short I was an idiot and left the compound on for 30 minutes. Took most of it off before polish and wax.
Now there are areas that still have compound residue. What would be the best way to remove this? I tried quick detailer and elbow grease without decent results. Would claying it again take care of this?
Dip Dungles is offline   Reply With Quote
Old 06-20-2014, 10:29 PM   #2
JustinTimeBoost
Member#: 389296
2015 WRX Limited 6MT
ISM
Did you wax over the compound residue?
You can try an isopropyl alcohol solution to remove the stubborn areas.
JustinTimeBoost is offline   Reply With Quote
Old 06-20-2014, 11:43 PM   #3
Dip Dungles
Member#: 383168
2017 STI
MS
Yes I did. 10PM and my garage makes for some poor lighting. I honestly thought I had gotten it all. So after compound I applied polish and wax.
I keep thinking I should pretty much start over with the clay/compound/polish/wax, but I thought I would ask if there was a work around.
Old 06-21-2014, 06:25 PM   #4
JustinTimeBoost
Member#: 389296
ISM
I would try removing the wax first with something like Chemical Guys Citrus Wash (Red), then try again to remove the compound without the presence of a LSP.
Old 06-21-2014, 09:43 PM   #5
Wellyea
Member#: 287314
08 Sti
methyl ethyl ketone (MEK) will take it off for sure
Wellyea is offline   Reply With Quote
Old 06-23-2014, 06:05 PM   #6
Billboard2001
Member#: 210085
2005 wrx sti
WRBlue
Best I've seen to remove it is to just recompound/polish that area. It was recommended to me once (as I did the same thing, it happens) and it worked easily. Then just remember to wipe it off this time
Billboard2001 is offline   Reply With Quote
Old 06-25-2014, 04:05 PM   #7
Dip Dungles
Member#: 383168
2017 STI
MS
Gotcha. I was thinking that is what I would have to do rather then applying some chemical that I wouldn't be sure how it would react with my paint.
Guess I know what I will be doing this weekend.
Old 06-25-2014, 04:17 PM   #8
TalldaveSTI
Member#: 394508
2008 WRX Impreza STI
Grey
Unfortunately if you have already waxed over it best bet is to get on it with some high concentration wash to remove the wax and start over again. you may be able to skate by with only doing a polish though, check a spot before you go compounding. USE A DA and it wont be long at all!
TalldaveSTI is offline   Reply With Quote
Old 06-26-2014, 08:26 AM   #9
Dip Dungles
Member#: 383168
2017 STI
MS
I already ordered some chemical guys to use for prewash so hopefully that takes care of it.
I'm going to clay/compound/polish/wax afterwards just to be sure.
Let you know the outcome.
Worst part is I don't see the compound residue until after the paint is completely dry so this will be interesting.
Old 06-27-2014, 10:35 PM   #10
fistv
Member#: 350063
2013 Impreza sport
Buy some lights
fistv is offline   Reply With Quote
Old 06-28-2014, 10:41 AM   #11
Dip Dungles
Member#: 383168
2017 STI
MS
Originally Posted by fistv View Post
Buy some lights
Using my buddies flood lights this time. Not taking anymore chances.
Old 07-13-2014, 12:24 AM   #12
Dip Dungles
Member#: 383168
2017 STI
MS
Today was the day.
1.) chemical guys red series wash
2.) Mothers clay bar
3.) Poor Boys polish/sealant
4.) Dodo blue velvet pro
This took care of the compound residue and I must say the finish is drop dead gorgeous. The work paid off.
Thank you for the recommendation. If it freaking rains in the next few days I'm going to be pissed.
Thanks again!!
Old 07-13-2014, 12:33 AM   #13
m71owner
Member#: 332321
1998 2.5rs
wrb
Let's see some pics of your hard work.
m71owner is offline   Reply With Quote
Old 07-13-2014, 12:57 AM   #14
Dip Dungles
Member#: 383168
2017 STI
MS
Will do tomorrow morning. Fair warning it will be from a iPhone so pic quality will not be up to par.
Old 07-13-2014, 04:55 PM   #15
Stabile11b
Member#: 395607
for starters your suppose to do a isopropyl alcohol rub down after polishing. Then you apply wax
Stabile11b is offline   Reply With Quote
Old 07-13-2014, 09:04 PM   #16
Dip Dungles
Member#: 383168
2017 STI
MS
Here they are
Old 07-13-2014, 10:07 PM   #17
19DB794
Member#: 396149
2006 Lancer Evo 9 MR
Graphite Gray
Looks great. I love that shade of blue, definitely one of the best colors IMO. Did you apply everything by hand or use a Porter cable?
19DB794 is offline   Reply With Quote
Old 07-13-2014, 10:59 PM   #18
m71owner
Member#: 332321
1998 2.5rs
wrb
Very good job dude. It's definitely something that I need to get done before winter.
Old 07-14-2014, 12:53 AM   #19
Dip Dungles
Member#: 383168
2017 STI
MS
All by hand. Would love to have used a buffer but,
1.) I don't own one
2.) scared sh$tless about burning thru the clear because of no training.
Non the less I am happy with the results.
Old 07-14-2014, 08:11 AM   #20
19DB794
Member#: 396149
Graphite Gray
Originally Posted by Dip Dungles View Post
All by hand. Would love to have used a buffer but, 1.) I don't own one 2.) scared sh$tless about burning thru the clear because of no training. Non the less I am happy with the results.
As long as your not using a rotary you'll be fine. I've polished my evo a few times before as well as a handful of other cars with my flex and it's very hard to burn through the clear with it. You just have to watch for the signs of the polish breaking down so you know it's time to stop. I keep my paint meter handy for the cars I detail that aren't mine since I have no idea what the paint has been through or how thin it is. It looks great though. Especially done by hand.
Old 09-15-2014, 01:43 PM   #21
GotBoost94
Member#: 361628
2013 WRX
Clay bar, works every time theres hardened compound
GotBoost94 is offline   Reply With Quote
Old 09-16-2014, 03:27 PM   #22
kingsalami
Member#: 206257
2009 WRX 5-door
To save yourself buttloads of effort in the future:
- Buy some Meguiar's Ultimate Compound (Walmart). This stuff works great at removing swirls & polishing your clear coat. And it's super easy to apply & buff off.
- Buy a Dual-Action orbital polisher from either Harbor Freight (cheap, when on sale with a 20% off coupon) or Porter-Cable (more expensive, but higher quality).
- Buy a polishing pad for the DA buffer (Meguiar's or Harbor Freight)
- If you've got fairly significant scratches, you can pick up a cutting pad, too.
Details here:
http://www.meguiarsonline.com/forums...5-and-a-G110v2
Just use Ultimate Compound in place of the M105.
kingsalami is offline   Reply With Quote
Old 09-16-2014, 07:50 PM   #23
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
1.) I don't own one
As long as your not using a rotary you'll be fine. .
19DB794 is right. Grab a DA polisher and you're good to go. No more burning paint.
The first car I ever learned how to buff on back in the late 80's was some old Chevy Chevette at the garage I worked at. One of the guys came and asked me something and I stood there listening to him, with the rotary buffer still going, on the edge of a fender He laughed and told me that's why you start out on junk
In any case, your car looks fantastic! Sounded like a bunch of time/effort, but well worth it!
Shik is offline   Reply With Quote
Old 09-25-2014, 10:58 AM   #24
GotBoost94
Member#: 361628
2013 WRX
Try a clay bar, we've all been there
