Old 06-20-2014, 11:29 PM   #476
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Originally Posted by BeastianSTI View Post
OK guys, one of the local builders suggested that the block wasn't machined to the right specifications. He also said that he has had to send blocks back to the machine shop many times because they were incorrectly cut.
I just measured all of the bores, and with my Fowler dial bore gauge, (.0005 accuracy?) each of the cylinder PTW clearances appear to measure .0020-.0022. Could measuring without a torque plate / the cases torqued together cause such an inaccuracy, or do you think it could be incorrectly cut?
If it was machined with tq plates, then you have to measure with said tq plates or your readings will be off from that of the machinists. That said it doesnt mean that it has the right PTW even if you used the plates to measure your bores
However you had bearing issues so the PTW would be the least of your worries ATM
2Fast4U1DAY is offline   Reply With Quote
Old 06-21-2014, 12:24 AM   #477
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I've already cleaned up the mess from da bearings. New oil pan, pump, cleaned avcs lines, oil galleries, cleaned block and heads.. turbo, etc.
I want to make sure my block isn't going to need a rebuild in 5k lol
BeastianSTI is offline   Reply With Quote
Old 06-21-2014, 02:53 AM   #478
SUB-Z3RO
Member#: 369426
At the Track
In the beginning of this thread I was super excited because I just started experiencing what I believe to be rod knock and had planned on doing all the work that I can myself. Now after reading about your issues after assembly I'm super nervous, but I really want to do all the work myself for the experience and to save $$ as well. I'm digging the thread though! Sorry about your luck. I have learned a lot so far!
SUB-Z3RO is offline   Reply With Quote
Old 06-21-2014, 10:33 AM   #479
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Excessive PTW wont make you have to rebuild it in 5k. Itll wear the rings faster but its not gonna destroy the bottom end. Itll be a little more noisy and the rings will wear faster like i said previously but its not going to be detrimental. IMO its worse to be Too tight, than to be too loose
Old 06-21-2014, 12:09 PM   #480
BeastianSTI
Member#: 310506
2005 WRX STi
Excessive PTW wont make you have to rebuild it in 5k. Itll wear the rings faster but its not gonna destroy the bottom end. Itll be a little more noisy amd the rings woll wear faster like i said previously but its not going to be detrimental. IMO its worse to be Too tight, than to be too loose
Thats what im concerned about - potentially having a piston seize up in a bore when it heats up for the first time. I need to bolt the case halves together and measure the ptwc again
Old 06-21-2014, 12:26 PM   #481
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
If you dont have tq plates your measurements are worthless. When you bolt the plates to the block the bore will open up more
Old 06-21-2014, 04:59 PM   #482
BeastianSTI
Member#: 310506
2005 WRX STi
Do you know, roughly, how much it could open ? E.g.) .0005 more maybe when all torqued together
Old 06-21-2014, 07:34 PM   #483
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Every one is different
Old 06-22-2014, 01:39 AM   #484
Jameshowlett
Member#: 358936
2004 WRX
I thought I had problems just having my heads machined. Turns out the spark plug holes were cracked, so I found a set for $400. Turns out they need to be machined too, not as much as it would cost for a new set but damn close.
Jameshowlett is offline   Reply With Quote
Old 06-22-2014, 03:49 PM   #485
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Thread jack much? Start you own build thread, dont clog up somone elses
Old 06-22-2014, 04:17 PM   #486
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
it sucks but if you really want to measure the PTWC correctly you'll have to throw tq plates on and measure.
I've seen a couple people say they have ran down towards .002 PTWC with 2616 pistons so I bet your fine depending on how much HP/racing you plan on doing with this block. Although it would be good piece of mind to get some plates on there and check it out
Old 06-22-2014, 07:53 PM   #487
ap1luis
Member#: 320729
2004 WRX STi
Been quietly following this thread for a while now. Awesome for others like myself who want to go this same route.
Goodluck to OP. Subscribed, cant wait to see it run
ap1luis is offline   Reply With Quote
Old 06-23-2014, 11:16 AM   #488
BeastianSTI
Member#: 310506
2005 WRX STi
OK - got some nice piston cleaning brushes last night and started going through the heads again now that I have the proper length and diameter brushes. Took all of the oil gallery plugs out of the heads, used soap and HOT water. Afterwards, put the heads on a decline and sprayed brake parts cleaner from the high side to the lower side. Also sprayed the cleaned through the camshaft oil feed holes / the couple of oil galleries randomly about the head.
Old 06-23-2014, 12:50 PM   #489
uglybetty
Member#: 381907
2005 forester STI
^^^ where did you get the brushes?
uglybetty is offline   Reply With Quote
Old 06-23-2014, 01:21 PM   #490
BeastianSTI
Member#: 310506
2005 WRX STi
We went to a local fleamarket with my pops haha.
He said that most tool shops should have them. They were only $2.14 for 4 brushes. Also picked up some brass brushes but they seemed pretty abrasive.
Old 06-23-2014, 02:17 PM   #491
uglybetty
Member#: 381907
2005 forester STI
I think I will just go and get another set of gun cleaning brushes
Old 06-23-2014, 03:31 PM   #492
BeastianSTI
Member#: 310506
2005 WRX STi
Yar - that's what they were labeled as. Seemed to be the perfect outer-diameter for the oil gallery holes.
Old 06-23-2014, 03:49 PM   #493
uglybetty
Member#: 381907
2005 forester STI
I got that idea out of the "tricks of the trade" thread. I think it was mentioned by nasioc member Team Scream.
Old 06-23-2014, 07:01 PM   #494
BeastianSTI
Member#: 310506
2005 WRX STi
Oh true. Never saw that one ha ha. I just looked for brushes of the right diameter and length gonna put the case together tonight I think
Old 06-24-2014, 12:13 AM   #495
BeastianSTI
Member#: 310506
2005 WRX STi
Cleaned up all my parts again today for installation / assembly rather of the shortblock. Sprayed everything down thoroughly with brake parts cleaner and hit it with compressed air pretty well. Re-lubed up the cylinder walls with some atf as well.
Tomorrow i'll put the rods on the crank and more likely seal the cases together!
Old 06-24-2014, 01:08 AM   #496
Jameshowlett
Member#: 358936
2004 WRX
How about you quit the flaming. Especially when I was agreeing with the headaches of a build.
Old 06-25-2014, 03:33 AM   #497
BeastianSTI
Member#: 310506
2005 WRX STi
And the case is back together! And I took some videos!
Old 06-25-2014, 11:53 AM   #498
uglybetty
Member#: 381907
2005 forester STI
Definitely want to see your videos. This thread has helped a ton in prepping for when my motor gets back to me. In doing all of that extra cleaning, how much extra gunk did you find?
Old 06-25-2014, 02:45 PM   #499
BeastianSTI
Member#: 310506
2005 WRX STi
So even after I cleaned out the heads with hot water, soap etc... The day before assembly I took the new pipe cleaners and put them in hot soapy water in a cup. I continued to scrub the galleries from the inside out. I took a tiny pipe cleaner and pushed it through the tiny holes used to feed the cams.
When I finished scrubbing, I put the heads on a slant so that any liquid inside of the cylinder head would leak out because gravity said so. I sprayed brake parts cleaner through all of the holes strategically (from cam holes first, then through the large passages that go from front to back). There was quite a dirty puddle of cleaner in the bottom of the cleaning tray I used, which was pretty surprising. The brushes + soapy water breaks the surface tension like a champ. I continued cleaning until nothing else came through.
I actually filmed each part of the assembly process (shortblock). I'm not a pro, but I followed the FSM and used it as a reference before giving any information in the videos. It'll take a while to chop them all up, but I think it'll be useful to the community.
Old 06-25-2014, 05:53 PM   #500
Razgeiz
Member#: 358782
2013 STi
Please post them this is awesome!
Razgeiz is offline   Reply With Quote
