Old 04-19-2014, 07:13 AM   #201
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by Artizle View Post
No... Maybe I'm doing it wrong. At what voltage is the TGV fully open?
I cant remember off the top of my head. All I know is that I reflashed the rom back to one that used tgvs, made sure the car was idling hot with the valves open via rr, went under the hood and unplugged both tgv motors, shut off the car, and flashed carberry back on. The motors never got plugged back in, or taken off the shafts. The only thing that was touched was the wiring harness.
If you've ever held an assembled tgv assembly in your hands and tried to move the butterflies you'd see my point that the valves snapping shut all by themselves is pretty much impossible.
perhaps the motors got some kind of electrical signal in the cars that have shown the issue? idk. All I know is that I run a lot of boost and I have never had them move.
Old 04-24-2014, 02:04 PM   #202
Artizle
Member#: 251825
2004 WRX
Looks like it's working so far, I let it get nice and warm, took it for a drive and unplugged them.
Artizle is offline   Reply With Quote
Old 05-24-2014, 12:26 AM   #203
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Hey guys, Ive been trying to see some of the changes in 3.8 vs older. Where do you set the air calc mode IE MAF SD or Blend? I didnt see it.
I am interested in taking a current rom and making it a carberry MAF rom while I build a VE table from logging.
Does load/kpa = ve here? Thats how we were doing the evo stuff quick and dirty. I jumped to a Vi-PEC with my evo though
Dubstar112 is offline   Reply With Quote
Old 05-24-2014, 06:08 AM   #204
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
make sure your editor is using the latest defs
Old 05-24-2014, 08:20 AM   #205
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Did that; do I need to modify the cars def XML or can I just add the 3.8 XML location parallel to that?
What section would this parameter be in?
I'm using the speed density base . Hex . Bak file is that appropriate as well?
Thank you for the helps.
Old 05-24-2014, 10:58 AM   #206
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
no, the bak file is the un-carberry patched original grp n SD rom.
Old 05-24-2014, 03:30 PM   #207
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
god im a fool.
spanks!
How do you figure anti lag behaves when on MAF? is the load going to climb and exceed any thresholds?
Old 05-25-2014, 05:56 AM   #208
daverst
Member#: 391778
I've been running MAF based carberry for a month or two and have a few questions that i've asked before but romraider can be very slow to get answers.
is it a definate that injector timing needs to be at 360* for the entire table for a non-avcs wrx.
is there any way i can bring up some more tables for decel like timings ect
i'd also like to be able to edit timings for when the car switches to idle timing on decel
it would be nice to be able to stay in the main fuel and timing tables for a secound or two on decel. it may give some nice afects to gear changes giving you antilag style gear changes without having to run full antilag. like a soft antilag that evo's have.
this may be where i get
daverst is offline   Reply With Quote
Old 05-26-2014, 10:23 AM   #209
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Ok, if I want to run MAF but the axis are still in PSI what do I need to do in order to use airflow and not PSI? Also what then does the VE table accomplish when no SD is running? Im looking for a bit of knowledge on the (maf/sd) blending too. Thank you guys!
Old 05-27-2014, 09:56 AM   #210
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you can't.
some careful logging will show that engine load and MAP are basically lock-step, so you don't need to.
if in 100% maf mode, then nothing.
the maf/sd blend ratio defines how much weight each of the methods to arrive at engine load (ie, x number of grams of air mass in the chamber) will be used to achieve a final number.
ie, 50% blend, sd load is 1.5g, maf load is 2g, final load for fueling calc = 1.75g.
hth
ken
Old 05-28-2014, 01:43 AM   #211
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
sure does help. I was looking for more indepth knowledge as to circumstances which warrant each method, and what the goal is ( aside from calcuating load)
However I think if I decide to go that route, I will see the difference.
You say that engine load and MAP are a lock- Coming from my evo ecu they are not a static link, esp in a situation where you hold 20psi to redline, load (obviously peaks- generally just before torque) then tapers very rapidly even when the manifold PSI is holding. So forgive me if I have a hard time understanding a solid link, albeit the load calc in this rom is obviously quite different than what Im used to. And your answer likely is better understood in practice.
thanks!
Old 05-28-2014, 07:44 AM   #212
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
there are some mechanical setups (cam related) that make calculation of VE extremely difficult: AVCS and/or high overlap configurations.
at idle and/or off throttle these can be nearly impossible to stabilize due to intake charge passthrough and/or reversion.
the maf blend ratio can allow one to fall back on the actual (extrapolated) mass air flow rate which more accurately reflects the cylinder load.
secondarily if one runs full maf you can leverage the other benefits of the carberry rom (nlts, lc, antilag, etc) while not jumping over to speed density.
no, of course they are not precisely and simply related: that's why the VE table (and the IAT/port temp comp table) are necessary. i did say "basically lock-step."
but when you look at the rom and what maps are defined via MAP that would be used in a MAF load based scenario, it's a moot point: you have the primary open loop fuel target and you have base ignition timing. both of those can arguably be linked directly to MAP with excellent results even if the injector pulse width is ultimately determined by MAF.
that said i would absolutely relocate my IAT sensor to post IC so that the temperature compensations for ignition timing have a more useful effect, regardless of whether or not i was intending to run SD or MAF.
Old 05-29-2014, 05:59 AM   #213
Artizle
Member#: 251825
2004 WRX
Wow good call I can't believe I completely overlooked that... I wonder if this is why I am getting worse fuel economy on carberry...
Old 05-29-2014, 01:19 PM   #214
daverst
Member#: 391778
So far I've been running 360* for a week now and all seems fine
Old 06-02-2014, 03:50 AM   #215
daverst
Member#: 391778
Anti lag 'injector duty idle'?
I presume this is the injector duty while in decel fuel cut (over run)?
If so what is the injector duty under normal conditions while in fuel cut? I'm guessing about 2%ish.
The reason i'm asking is i just want to run a very soft anti lag more for the effects on gear changes ext. and have it switchable.
Old 06-02-2014, 04:08 AM   #216
Artizle
Member#: 251825
2004 WRX
My fuel economy and driveability have definitely increased. 360* is the correct amount for non AVCS USDM WRX.
Old 06-23-2014, 01:30 AM   #217
daverst
Member#: 391778
Does Carberry use 2nd lambda? I'd like to use this location for wideband.
Is it the same as front lambda?
Can I use it as a replacement for the 1st/front lambda?
Old 06-24-2014, 09:52 PM   #218
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you do not need a rear o2 sensor to run carberry
Old 10-04-2014, 02:04 PM   #219
mrgravestone
Member#: 403164
Default Hello Guys.
I am new to the group, but I have been playing with the speed density Car Berry tune for a bit now. I recently added a few parts to my 2002 WRX and need some help with the tune. Is there anyone who is willing(and knows their stuff) to help me out in reviewing the tune, logs, and retune? Please let me know! This car has huge potential, but the tune is definitely where it's at!
mrgravestone is offline   Reply With Quote
Old 10-04-2014, 02:45 PM   #220
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you might get more specific help on romraider.com
Old 11-16-2014, 03:54 PM   #221
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
New to this and reading a lot. I don't plan to do any tuning, but have a e tune done.
From what I've read here, it sounds like doing the SD map with a e tune is a bad idea as it takes a lot more work and better to have the tuner in person for extensive logging.
I'm assuming doing the carberry with MAF would be the better route, this way I can still have map switching on the fly. I would then be able to ditch my UTEC. Is this correct?
LIQUIDSK8S is offline   Reply With Quote
Old 11-16-2014, 03:55 PM   #222
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
The longest part is with cruising and into power if full SD. But with MAF/SD Blend its easy.
Just find a tuner is confident to do it.
west_minist is offline   Reply With Quote
Old 11-16-2014, 08:23 PM   #223
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I was speaking with Clark, and for my setup he suggested sticking with the factory ROM (v8 JDM) and staying MAF. I'm assuming carberry would still work in this scenario. I'll talk more with him and see what he thinks, as the last time I was asking him about sticking with a OS and UTEC combo and didn't mention carberry.
Old 11-16-2014, 08:26 PM   #224
west_minist
Member#: 53451
w/ AVCS Silver
Ok. Tuning a number of cars (ALL JDM and 1 EDM) remotely and locally with it and with maf/blend, it depends on what you are looking for.
Once all of your requirements are meet, you can decide on it.
With SD, any flow charges will require a retune, if the flow changes are a little drastic.
Old 11-16-2014, 08:40 PM   #225
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I'm looking for a E85 map along with a 93 map for the occasions when I can't get E85. The car would be a DD that sees the occasional track day. Not a drag strip car.
Looking for a "set it and forget it" setup. I don't want to deal with the constant headache of retuning constantly. Yes if I were to change/mod something then it would need a retune.
Speed Density - OS 16bit Rom - Discuss Here JSarv Engine Management & Tuning 884 07-24-2013 01:39 AM
FS : NM : 05 Mits. Lancer EVO 8 - 2.3L Stroker & Speed density conv. scoobysti05 Private Vehicle 'For Sale' Classifieds 6 04-02-2011 05:18 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 01:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 10:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
