Old 06-18-2014, 09:04 PM   #1
bluerex8586
Member#: 389075
2013 wrx
wrb
Default feedback knock?
Once in awhile I'm seeing a reading of -1.4 and sometimes a reading as high as -4.2 should I be concerned? It's only at low rpms right before boost. Never get any reading at wot. And it's completely random some days I don't get anything. And my dam or fine knock never change.
bluerex8586 is offline   Reply With Quote
Old 06-18-2014, 09:38 PM   #2
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
Often times, engine noise and quick changes in load (I.E, Spoolup) can be picked up as knock by the sensor. Most times it isnt actually knock. If your getting some during spoolup, it may be a tip-in enrichment fix, but if your not seeing any once your WOT and in full boost, thats the sign of a healthy tune. From time to time you should see noise getting picked up at lower loads. Its a good sign that your knock sensor is working as its supposed to.
Try and capture this knock in a log and post it up here for further analysis.
mikeydrives1 is offline   Reply With Quote
Old 06-18-2014, 10:11 PM   #3
bluerex8586
Member#: 389075
2013 wrx
wrb
I will try and get a log tomorrow and post it. Thank you.
Old 06-20-2014, 08:03 AM   #4
bluerex8586
Member#: 389075
2013 wrx
wrb
It never does it when I log of course but it does seem to do it under a load just before boost and never in full boost under wot.
Old 06-20-2014, 04:55 PM   #5
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Could also be some bad gas maybe? Where do you normally fill up at?
Subian is offline   Reply With Quote
Old 06-26-2014, 01:37 AM   #6
Rayek
Member#: 394395
2013 STI Limited
I am getting the same -1.4. I was able to duplicate it in 5th gear when accelerating about 1/2 throttle as the turbo is spooling. Running Stage 1 cobb (91 oct stock intake, stock exhaust setting) until I install my downpipe/intake. I always fill up 91 supreme at chevron.
Rayek is offline   Reply With Quote
Old 06-26-2014, 01:58 AM   #7
Rayek
Member#: 394395
2013 STI Limited
To the OP of this thread. I just read this
HTML Code:
https://cobbtuning.zendesk.com/hc/en-us/articles/200025084-Knock-Monitoring-FAQ
and it was very informative. I would suggest taking a look so that you can be at ease.
