Old 06-26-2014, 11:28 AM   #1
richy_21
Member#: 58670
2005 got muuuuu?
Default Wrx Sti Forester swap ecu dilemma
I have a 05 wrx with a jdm sti forester motor swap DBW the whole shabang. Run but what i think is the jdm sti forester ecu 22611AJ542. Is there anyway to confirm that this? Like any markings on the motherboard etc?
Does anyone have or know where I could find the ecu pinouts for the jdm sti forester?
My main issue is the car has ecutek on it. I'd rather not run it anymore. Wonder if I could use a usdm ecu?
richy_21 is offline   Reply With Quote
Old 06-28-2014, 11:46 AM   #2
mikeydrives1
Member#: 262117
Well, whatever ECU you run, it has to support a Drive By wire setup.
What are the specs on the motor... 2.0liter? 2.5liter? There were only a few JDM forester STI models out there
mikeydrives1 is online now   Reply With Quote
Old 06-28-2014, 07:36 PM   #3
richy_21
Member#: 58670
2005 got muuuuu?
Originally Posted by mikeydrives1 View Post
Well, whatever ECU you run, it has to support a Drive By wire setup. What are the specs on the motor... 2.0liter? 2.5liter? There were only a few JDM forester STI models out there
2.5L
Off a 05 forester sti. That's why I'm wondering if a usdm sti 05+ ecu would work.
Old 06-28-2014, 09:20 PM   #4
Artizle
Member#: 251825
2004 WRX
The 05+ STi ecus use immobilizers so that could be a potential problem. I would just look into getting the EcuTek software removed from the ECU you have since there doesn't seem to be much info on the JDM Forester STI ecu pinout.
Artizle is offline   Reply With Quote
Old 07-01-2014, 07:03 PM   #5
richy_21
Member#: 58670
2005 got muuuuu?
If I'm not mistaken the Forester sti has a immobilizer so it's already wired then
Old 07-02-2014, 12:10 AM   #6
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
Just buy a 04 FXT ecu. Auto is easier to find and cheaper. they have no immobilizer and u can just flash the 5spd rom to it. it works ive done it
New2Sube is offline   Reply With Quote
Old 07-02-2014, 07:57 AM   #7
richy_21
Member#: 58670
2005 got muuuuu?
my is wired for the immobilizer tho.
Old 07-02-2014, 08:40 AM   #8
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
Oh okay. So does the immobilizer check the ecu then tell the car to turn on? Not familiar with them. I have 2 USDM 04 fxt's both without immobilizers.
Old 04-30-2015, 01:32 PM   #9
richy_21
Member#: 58670
2005 got muuuuu?
back from dead. It is wired with immobiler and has the halo ring etc that is tucked behind the glovebox.
Old 04-30-2015, 03:01 PM   #10
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
U should try the 04 auto ecu....it might work. Then just flash the 5spd rom to it
Sent from my SM-N910V using NASIOC mobile app
