Old 06-25-2014, 01:53 PM   #26
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Originally Posted by AFBeefcake View Post
buy a used cluster harness and steal some pins out of it. That's what I did.
I did this.
It was making sense to me that these would be included though.
When you say that the DCCD Pro is not powerful enough, are you referencing you experiencing mechanical binding?
Old 06-25-2014, 05:58 PM   #27
Shifter Kart
Member#: 219740
2000 Sti Type R
Yes, I believe it does. When I installed mine there is a wire you connect to the parking brake switch.
good stuff. only thing is im using a hydraulic handbrake should be able to make it work though
Shifter Kart is offline   Reply With Quote
Old 06-26-2014, 02:45 PM   #28
Subifantastic
Member#: 381700
Yes dccdpro controller has a wire that connects to parking switch and when I pull handbrake the wire goes to 12V and shuts off the controller. Works pretty well.
Subifantastic is offline   Reply With Quote
Old 06-26-2014, 04:17 PM   #29
Subifantastic
Member#: 381700
Oops, sorry it is not 12V and actually shorts to ground.
Matt
Old 10-19-2014, 10:40 AM   #30
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Anyone using the tuning software?
Does the unit need to be sent back to DCCDPro, for rewiring, for the $100 option?
I noticed a big difference in the handling of the car under full torque, while in auto, vs while in manual with half lock.
In auto, as the torque builds, and the dccd decides whether to increase lock, the rear end feels like "it's pushing over the front" and you have to correct from the steering.
The worst is during turning, when you give gas past the apex, the front end gets initially no lock and the rear becomes unsettled.
In manual with half lock, it feels very planted.
I'd like to tune the unit to respond more aggressively to acceleration.
Old 10-19-2014, 05:41 PM   #31
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Have you adjusted the knob?
Did you program it?
west_minist is offline   Reply With Quote
Old 10-28-2014, 08:51 AM   #32
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I've read the manual again and finally found in the troubleshooting manual a reference where the knob has a function in Auto, just like it has one in manual.
I'm not too optimistic, because I keep the knob half way locked. I'll try to keep it fully locked, to see what that does in auto mode.
And I'll try a calibration too.
Old 11-23-2014, 08:35 AM   #33
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
So this is partially fixed.
I did the calibration with the accelerator slightly pressed, to get the DCCD to lock faster. Also, I made sure the car was horizontal.
Now, driving in auto with the rotary knob more than a third into lock, at parking lot speed brings binding.
At speed, trying to take a turn say at 60 MPH, looking for neutral behavior, the knob needs to be 2/3 into lock.
I have a new 6 speed, possibly the clutches in the DCCD are more grabby maybe this requires different settings.
The amount of gas at calibration seems to control the amount of gas at which it starts to lock.
What this fixes is launch or sharp in gear acceleration, with a more aggressive setting, these feel safe now.
Or maybe the problem is the lack of a speed input: At speed this would increase the sensitivity of the lateral g meter in the dccd, while at parking lot speed, this would release the dccd.
Old 02-25-2015, 01:46 PM   #34
Spoolin6er
Member#: 311726
It seems this was asked before but not answered (as far as I can tell):
If i buy the base kit plus the VSS and accelerometer today and I want to program via USB later can I do this by simply buying the $100 cable/software?
Or does it have to be sent back for a firmware upgrade??
Spoolin6er is offline   Reply With Quote
