Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 04-23-2013, 11:59 PM   #126
WheelsCSM
Member#: 20765
2008 Forester XT
6mt/18g-xt
Originally Posted by WheelsCSM View Post
I have had mine in for about 1 year and 20,000 miles in my Forester XT with no problems, vibration, or other issues.
Took forever to find some 02 WRX sedan rear axles though since the ones from my 08 FXT would not work. The ones I found had something like 170,000 miles on them, so I'm wondering how much longer the outer joint will last?
Ahem..
If you have an 04 Forester you should be okay with your axles. Any other year and good luck finding 02-04 WRX SEDAN axles. Wagon axles may work, but they are shorter and Foresters have a wider rear track than WRX sedans so I would not risk it.
04-08 Forester XT rear axles are identical to 02-07 WRX sedan rear axles.
WheelsCSM is offline   Reply With Quote
Old 04-24-2013, 12:11 AM   #127
RX7LS1
Member#: 94163
Ahem..
So my 04 FXT outers with any 04-07 STI inners/bars will work okay?
Thanks,
Jason
RX7LS1 is offline   Reply With Quote
Old 04-24-2013, 12:44 AM   #128
WheelsCSM
Member#: 20765
2008 Forester XT
6mt/18g-xt
Thanks,
Jason
I think so. When I was looking for WRX axles I was also looking for 04 FXT axles - I just knew they would be harder to find. I can't remember if they switched the spline count on the inner CV joint in late 04 or beginning of 05. You can check opposedforces to get an idea.
Check with SuberDave, but there may be a difference from the 04 STI axles to the 05-07. I can't remember. If I remember correctly, when I got mine he had parts that could deal with either STI axle, just tell him which one you need. It was just the WRX axle that was limited to 02-04 or some older models.
Old 04-24-2013, 07:23 AM   #129
Driveshaft shop
Member#: 306253
im not sure about races, im sure they will let you know. we should have complete axles if you know the lengths
Driveshaft shop is offline   Reply With Quote
Old 04-27-2013, 01:26 AM   #130
suberdave
Member#: 101865
88 GL-10 STi
04 (and JDM V7-V8) STi inner joints are 6 ball races. 05+ are 8 ball races. i know the 08+ STi shafts are different. but the inner joint is the same. i bought an 11 STI rear shaft, and the inner joint was the same as any other 05+.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 05-07-2013, 03:32 AM   #131
Rich_D
Member#: 244913
2006 440hp WRX wagon
Hey mate,
Have sent you an email regarding these.
I got it wrong in my email though, I have 06 WRX outers with 02 STi inners but don't know the spline count because they are on my car..
Rich_D is offline   Reply With Quote
Old 05-08-2013, 01:15 AM   #132
RX7LS1
Member#: 94163
Any tips or tricks to get the OEM races off after you take off the snap ring?
Thanks,
Jason
Old 05-08-2013, 03:37 AM   #133
JonnyV2889
Member#: 197384
2006 WRX Ltd
Thanks,
Jason
If you're referring to the inner joint they should come straight off (up) if you have the axle vertically. The inner race should just slide off after circlip removal.
I put zip ties around the bosses to keep the bearings from sliding off during degreasing.
JonnyV2889 is offline   Reply With Quote
Old 05-14-2013, 11:49 PM   #134
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
Any race that will allow an outside Sti axle with a wrx inside that still maintains the R160? I need the opposite of the R160/R180 hybrid. Because I wan 5x114, bigger bearings, sti coilovers without changing the rest of everything.
SoCal_Scooby is offline   Reply With Quote
Old 06-05-2013, 07:43 AM   #135
mike280
Member#: 161437
02 WRX Wagon
EJ207
Does anybody have any sti outer joints left over from this swap they can sell?
mike280 is offline   Reply With Quote
Old 06-05-2013, 07:55 AM   #136
imprezive one
Member#: 16906
2k3 wrx wagon
I do but one of them is missing its baffle plate (part #23233GA091, see this thread: http://forums.nasioc.com/forums/show....php?t=2495985) You can reuse the baffle plate from the wrx outer joints though. Let me know if you're interested.
imprezive one is offline   Reply With Quote
Old 06-05-2013, 08:27 AM   #137
monkiboy
Member#: 202958
2008 wrx
what year STI outer joint do you need?
monkiboy is offline   Reply With Quote
Old 06-05-2013, 08:38 AM   #138
imprezive one
Member#: 16906
2k3 wrx wagon
FYI mine r from a 2005.
Old 06-05-2013, 10:18 AM   #139
RX7LS1
Member#: 94163
yes, 05.
Old 06-13-2013, 12:32 PM   #140
mike280
Member#: 161437
02 WRX Wagon
EJ207
Well I have 04 axles but the inner cups are 8 ball and the spline count is 32. So they must be late 04 but it is very odd because my front axles are female. they all came from the same 04sti but as we know the 04 is a bastard child of parts.
If you have outers please PM me as I don't want to clutter the thread.
Old 06-15-2013, 06:43 PM   #141
bman76
Member#: 353205
slightly off topic but, I've been doing a bunch of research and wanted to make sure I had my information right. If I already own an 04 STi (r180) I would still need custom axels, massaging of the gas tank, and to figure out the rear diff mounts right?
OR since my diff is already larger than the r160 would there not be as much of an issue?
bman76 is offline   Reply With Quote
Old 07-18-2013, 05:23 AM   #142
thejaredhuang
Member#: 86206
2006 WRX Wagon
So any word on the reverse hybrid? 5x114 hubs with a R160? I have a 06 WRX so theres no R180 that I can use until I get a 6spd.
thejaredhuang is offline   Reply With Quote
Old 08-11-2013, 05:12 PM   #143
Saabaruski
Member#: 365089
Hey I was wondering if you still had a set of the inner race for the r180 swap? I am very interested in buying a set. I am almost done with my 05' 6 speed STI swap into my 06 Saabaru but I am keeping my stock hubs and wheels so I was looking into buying legacy spec b rear axles until I saw your thread. Please email or pm me and let me know if you do or don't have any left.
Saabaruski is offline   Reply With Quote
Old 02-12-2014, 11:00 AM   #144
FlyingDisk
Member#: 139557
06 VF39 WRX TR
V9 JDM STI Trans Silver
Has anyone used these races on a 2006 wrx using the stock rear axles? What was the spline count on the wrx shaft?
FlyingDisk is offline   Reply With Quote
Old 04-07-2014, 04:08 PM   #145
flawlessrides
Member#: 283340
great post…another sticky!
flawlessrides is offline   Reply With Quote
Old 05-06-2014, 12:34 PM   #146
flawlessrides
Member#: 283340
I tried to leave feedback but couldn't get it to work so...Dave sent me the races overnight, I installed them on Thursday and went to the track Sat and Sunday, they performed flawlessly. Save yourself some money and convert your axles so you can use your R180 diff. The races are great quality and I would not hesitate to purchase them again! Thanks Dave!!!!
Old 05-07-2014, 06:15 PM   #147
Storm
Member#: 5218
96L Most Over-
Developed Beater
This is exactly what I intend to do!!!
Jay
Old 05-17-2014, 03:29 PM   #148
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
So Dave still does these!!! Awesome
superblkwrx is offline   Reply With Quote
Old 05-20-2014, 01:38 PM   #149
yakmastermax
Member#: 352649
2006 Subaru
SGM
Same question. How would this work with my factory 2006 wrx axles and what STI transmission and axles would i be looking for
V7
V8
yakmastermax is offline   Reply With Quote
Old 06-26-2014, 05:09 PM   #150
Nitro350Z
Member#: 200357
2003 Baja Classic
Regatta Red
PM sent
Nitro350Z is online now   Reply With Quote
Hybrid axles Jpizzzle Transmission (AT/MT) & Driveline 7 02-22-2010 01:55 PM
"The Missing Link" Discovered in Germany? Jard Off-Topic 55 05-21-2009 04:21 AM
How did I miss "The Wire" for so long? Rice & Gravy Off-Topic 19 01-05-2007 06:56 PM
WTB:SOCAL: Hybrid Axles xplane Private 'Wanted' Classifieds 0 05-23-2006 12:25 PM
Do you miss "the monkey?" obyone General Community 6 11-15-2002 06:01 PM
