Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 02-21-2011, 01:38 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default It aint gon fall apart no more; Welded cir-clip phase2 centre diff
Here is a center diff taken out of a WRX tranny fitted with PPG straight cuts. I was doing the tranny swap because his OEM WRX tranny blew 3rd gear. The setup is a '02 WRX, TD05H 18G 7cm, EWG, E85, EJ257 shortblock swap.
As some of you may know, the center diff LOVES to fall apart. I have seen this in a '00 2.5RS, '00 Outback, and '03 WRX. To service the center diff you have to replace it. Subaru doesn't sell rebuild kits for the center diff. It's a sealed unit. Well.... then might as well weld the cir-clip that holds it together so you don't have to worry about it coming off ever again.
Old 02-21-2011, 07:21 PM   #2
mowgli29
Member#: 203438
Holy cow, never knew center diffs were known for coming apart.
At the very least, those welds will make sure no human ever catches a whiff of the horrid stench contained in that thing!
mowgli29 is offline   Reply With Quote
Old 02-22-2011, 01:31 PM   #3
MRF582
Member#: 48219
. Always drive
the race line .
This is sound logic. Kudos.
MRF582 is offline   Reply With Quote
Old 02-22-2011, 05:00 PM   #4
grafton
Member#: 187936
97 Legacy w/12:1CR
07 WRB STi
how would this effect on road handling?
grafton is offline   Reply With Quote
Old 02-22-2011, 05:05 PM   #5
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
not sure if this is a dumb question or not, but will this mess up the balance? I think I would have paid someone a few bucks to just put a few short tig weld beads instead.
UP2MTNS is offline   Reply With Quote
Old 02-22-2011, 05:34 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If I had a TIG welder, that's what I would have done.
We'll find out in the long run. This is why I welded both sides... I know a little off...
Old 02-22-2011, 07:04 PM   #7
BenGSX
Member#: 210061
Only question I would have is how the VC juice liked that heat.. Since it is the heat created by friction that drives it towards the semi-solid state - I wonder how extreme heat could potentially damage it.
BenGSX is offline   Reply With Quote
Old 02-22-2011, 07:22 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is how the GUTS look like if you where to take one apart.
This center diff was taken apart, gutted and used as an OPEN diff for a hybrid final drive setup; 3.900tranny and 4.444 rear diff.
Old 02-22-2011, 08:13 PM   #9
BenGSX
Member#: 210061
So - by these pictures, you're saying you opened it up - drained the VC's "fluid" and put it back together dry? Thats kind of like letting the magic smoke out.. It's not going to work anymore.....
And this is what I'm talking about..
Those plates are extremely thin - the fluid that is trapped in there, directly next to the weld is heat sensitive - and the O-ring is right there as well..
The VC has to remain sealed with its fluid intact in order to work....
Old 02-22-2011, 08:32 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
sorry I didn't describe anything....
but that's how it looks like INSIDE the VLSD center diff. The one with the welded c-clip was NOT taken apart.
Old 02-22-2011, 08:37 PM   #11
BenGSX
Member#: 210061
Gotcha!
Old 11-18-2013, 01:15 AM   #12
turkeylord
Member#: 89016
2005 Legacy GT Wagon
ABP
Bump...
Lookie what I found today.
Had no idea this was semi-common?
Can I buy a new circlip from Subaru?
turkeylord is offline   Reply With Quote
Old 11-18-2013, 06:53 AM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Buy a new center diff. You'll enjoy a fresh VLSD with a happy c-clip.
http://forums.nasioc.com/forums/show....php?t=2432712
Old 11-18-2013, 10:06 AM   #14
turkeylord
Member#: 89016
ABP
Oof, that ain't in the budget. May try welding with or without the ring first...
Old 03-16-2014, 07:08 PM   #15
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Weld it, problem solved. Broken? Buy a new one.
Old 03-18-2014, 05:05 AM   #16
subi400
Member#: 216984
1996 Impreza outback
Green
Bought a 2001 outback 5 spd 4.11 tranny last year, found the thread about this cir clip getting itchy feet and decided to look at the center diff in my replacement tranny. Both rings were in place, but had a local shop put 3 small tigs at equal lengths apart from each other on the inside part of the rings. Not going ANY where now...
Not that much work to do it right the first time around though other than a bunch of cleaning...
Old 06-21-2014, 01:26 PM   #17
bluewrx21
Member#: 364391
Fuji, how did you get the diff all the way apart?
bluewrx21 is offline   Reply With Quote
Old 06-22-2014, 10:46 AM   #18
KamekazeSTI
Member#: 379237
2010 GRB STI
By the looks of it he didn't actually take it apart. It's a pic from some other opened up diff.
KamekazeSTI is offline   Reply With Quote
Old 06-24-2014, 03:04 PM   #19
bluewrx21
Member#: 364391
Oh, i see. Well if anyone has managed to get one apart themselves id love to know how, but i dont see it happening without some kind of press.
Old 06-27-2014, 12:03 AM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
give it a couple of wacks
Old 06-27-2014, 01:43 AM   #21
OK Houston
we have an Uncle
axles seal/ cir clip problems 5x114 swap I'll paypal you cash to help me figue it out mesa50w Transmission (AT/MT) & Driveline 1 10-08-2009 05:23 PM
Well... it aint no broodwich daveB Off-Topic 30 05-03-2007 05:08 AM
Say it aint so! no more pr0n! HighWayDrifter Off-Topic 27 04-16-2004 04:26 PM
Billet RWD Conversion centre diff chiraoka Transmission (AT/MT) & Driveline 14 01-08-2002 09:04 PM
Centre diff on the Legacies and Imprezas.. Garvinator Normally Aspirated Powertrain 3 02-04-2001 04:31 PM
