Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 06-21-2014, 02:51 PM   #1
Andrewscottrobot
Member#: 381592
Default 02 wrx transmission in 06 wrx tr?
I just found out my 06 WRX TR transmission is toast, however I found a transmission I was going to go look t locally, it's a 02 WRX, will it be compatible? Anything that will be needed to make it compatible?
Andrewscottrobot is offline   Reply With Quote
Old 06-21-2014, 03:52 PM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
No. The 06 has a 3.70 rear and the 02 is a 3.545. You would need a 3.545 rear diff to make it work with the 02 otherwise you will trash the center diff and have binding problems
2Fast4U1DAY is offline   Reply With Quote
Old 06-22-2014, 12:38 AM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
it CAN be done....but the cost/bs level would make getting the broken one rebuilt a better option...
it is FAR easier to find an 06-07 wrx trans
Old 06-22-2014, 04:49 PM   #4
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
I'll have my 06 WRX trans out of my car in a month if you're interested and close to CT.
VinceCarter is offline   Reply With Quote
Old 06-27-2014, 10:44 AM   #5
GM_ND_GTP
Member#: 394732
That 02 tranny would also have the external stubs for the front axles so you would need front axles. I would never go down this path to downgrade to an 02 tranny.
GM_ND_GTP is offline   Reply With Quote
