Old 11-07-2009, 02:10 PM   #1
jacksonjrs
Member#: 213043
Default How do I datalog to sd card using tactrix 2.0?
I'm trying to datalog onto my sd card using a tactrix 2.0 cable but its not working right. I found instructions that say to setup a log file on the sd card, remove just the tactrix adapter that plugs into the obd port, and plug it into the car. I will start the car, hit the defogger button to start logging, and than turn everything off and connect to my laptop. So far the only thing that appears on the sd card are the log.xml file and a logcnf.out file. Shouldn't I be getting a csv file??
What am I doing wrong??
jacksonjrs is offline   Reply With Quote
Old 11-07-2009, 06:34 PM   #2
my02turboWRX
Member#: 68448
2008 WRX STi
Cobb tunned by Surgeline
There is a specific thread on the tactrix website in regards to this.
Lets just say there is more to it and it is not plug and play ready yet
my02turboWRX is offline   Reply With Quote
Old 11-07-2009, 08:54 PM   #3
Web Foot STi
Member#: 39086
2004 STi
Not quite ready for prime time:
http://forums.nasioc.com/forums/show....php?t=1868026
If you want to be guinea pig...
Web Foot STi is offline   Reply With Quote
Old 11-07-2009, 10:36 PM   #4
my02turboWRX
Member#: 68448
2008 WRX STi
I wish it was ready for PNP!!
Old 11-08-2009, 03:43 PM   #5
STiAlain
Member#: 134565
Chapter/Region: HIIC
2006 STi
me too
STiAlain is offline   Reply With Quote
Old 11-09-2009, 11:38 AM   #6
SenseiL2007
Member#: 219696
2004 STi
I have the cable and wanna do this too how big a card did you get? Is there such thing as too big?
SenseiL2007 is offline   Reply With Quote
Old 11-13-2009, 09:32 PM   #7
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
write speeds can slow down on larger cards, i doubt you would ever need anything bigger than a 2gig card though, 2gig should be way more than enough
dan az is offline   Reply With Quote
Old 11-16-2009, 03:29 PM   #8
Sicarius
Member#: 207229
2006 WRX wagon
Graphite
Use this link to download the config tool for setting up a config file for your sd tactrix. Once downloaded just pick your ecu from the dropdown and then check off the parameters you wish to log, then save the file to the main directory of your SD card.
http://forums.openecu.org/viewforum....e11a45c31f7470
Sicarius is offline   Reply With Quote
Old 06-10-2011, 02:51 PM   #9
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
So it works now?
Old 06-22-2014, 03:25 AM   #10
wrxb12
Member#: 394245
Hi guys,
I'm new here and have a 2012 ausdm wrx
I know it's an old thread but I need help..
I have done heaps of reading and plan on doing one of Eric's tunes but am datalogging stock first..
I have done all the below but still nothing gets logged, no files except for the logcfg file:
-tactrix 2.0
-2gb micro sd card
-used sample logging txt file found in openecu folder for can system and renamed logcfg
(Made sure it's not logcfg.txt.txt
-uncommented and commented defogger trigger as instructed in file
-went for a drive and tried to log using rear defogger
I have tried so many times am I missing something ??
wrxb12 is offline   Reply With Quote
Old 06-23-2014, 11:19 AM   #11
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Originally Posted by wrxb12 View Post
Hi guys,
-tactrix 2.0
-2gb micro sd card
Have you tried this?
http://verticaltier.net/configtool/logger.php
ProfessWRX is offline   Reply With Quote
Old 06-23-2014, 02:38 PM   #12
fenix-silver
Member#: 231700
2004 WRX Wagon
A log file should be created once you plug the tactrix into the OBD2, regardless of if you press the defogger switch or not. If it's not being created, either the Tactrix isn't getting power (does it light up when you plug it in), or there is an issue in the logcfg.txt file.
fenix-silver is offline   Reply With Quote
Old 06-24-2014, 12:03 AM   #13
wrxb12
Member#: 394245
Will try this on the weekend and let you know thanks !
Old 06-24-2014, 12:04 AM   #14
wrxb12
Member#: 394245
Hey I haven't tried this but the lights are definitely on and I'm sure it's getting power
Old 06-24-2014, 04:36 AM   #15
wrxb12
Member#: 394245
I will try this on the weekend and keep u guys posted thanks for the reply
Old 06-25-2014, 06:50 AM   #16
wrxb12
Member#: 394245
hi guys thanks for your help..my ecu wasn't supported on the logcfg creator page but I tried a new logcfg.txt file and just used the standard rpm>0 trigger and it worked..so maybe the defogger one doesn't work ? im assuming its the rear defogger button ?? I triple checked the trigger and I uncommented/commented the old/new trigger correctly.
anyways thanks for your help I will just have to log via laptop for now I think
Old 06-25-2014, 06:53 AM   #17
wrxb12
Member#: 394245
I'm thinking maybe my ecu has a different paraname for defogger maybe ?
my ecu is AZ1G900C
Old 06-25-2014, 12:05 PM   #18
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
my ecu is AZ1G900C
You can name it whatever you want. That doesn't matter.
Old 06-27-2014, 06:39 AM   #19
wrxb12
Member#: 394245
Ok guys Logging through laptop all ok but annoying when I'm by myself..I have an idea is it possible to log to sd card and make a trigger for it to start when throttle is say 90 or 100% ?
It sucks my defogger doesn't work for sd card so if anyone can write Me up a trigger for throttle it would be appreciated
Old 06-27-2014, 08:32 AM   #20
fenix-silver
Member#: 231700
2004 WRX Wagon
With romraider logging to your laptop you can use the defroster to start/stop logging.
Old 06-27-2014, 11:24 AM   #21
mikeyPSF
Member#: 236475
...is it possible to log to sd card and make a trigger for it to start when throttle is say 90 or 100% ?
If you installed EcuFlash in the default location, you'll have a variety of sample files here:
C:\Program Files (x86)\OpenECU\EcuFlash\samples\logging
The sample file "subaru k-line adc lc1" in particular has a good selection of samples, including:
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
which you could change to some other RPM value
mikeyPSF is offline   Reply With Quote
Old 06-27-2014, 02:30 PM   #22
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
action = start
action = stop
Or change it to tps instead of rpm.
Log tps, whatever it's exact name is copy/paste it where rpm is and change it to desired rpm numbers instead of the zeros.
Unable to connect with Tactrix 2.0 and ECUFLASH DeathKing Open Source Reflashes 1 01-25-2010 02:20 PM
Tactrix 2.0 Cable New used once $150 shipped macker01 Engine/Power/Exhaust 3 10-31-2009 08:33 AM
FS: Tactrix 2.0, barely used JasonLI25T Engine/Power/Exhaust 7 02-03-2009 07:05 PM
When are they going to make Micro-SD cards bigger than 2 gigs? jargon Off-Topic 7 10-21-2008 08:18 AM
How do I use AccessPort 2.0 for 2006 WRX? wonsin83 Newbies & FAQs 10 05-08-2007 08:36 AM
