Old 04-14-2013, 11:25 PM   #1
gsla72
Member#: 224573
2002 Wrx Wagon
Midnight Black Pearl
Default Drivetrain Knocking Sound
Lately my 02 wagon has started making a horrible knocking banging sound when decellerating from about 50-30 mph. The noise definitely feels like it's coming from the rear of the car, and it goes away if the clutch pedal is pressed in. It also occasionally clunks when shifting gears normally. I've taken it into a shop after making sure everything was tight, and they guessed it might be the rear dif but weren't sure. Any ideas before I start throwing parts at it?
Relevant mods/info:
Kb outrigger bushings (comfort)
Tic rear diff bushings (comfort)
Gear oil changed in dif 6 months ago (extra-s)
Stock driveshaft/rear end
Cv joints had no torn/damaged boots
Update: Noise was coming from the transmission or the clutch/flywheel assembly. All three were replaced and the decel noise is gone.
gsla72 is offline   Reply With Quote
Old 04-15-2013, 07:40 PM   #2
dkmImpreza
Member#: 318115
2007 Impreza 2.5i
Pearl Blue
I'm having the same problem, especially when it's cold. When I down shift and go through a bit of a bumpy road. I hear a knocking sound somewhere in the hand-break and glove box area.
I wonder what is causing this sound?
dkmImpreza is offline   Reply With Quote
Old 04-15-2013, 08:29 PM   #3
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Check drive shaft joints
Umadbroej26 is offline   Reply With Quote
Old 04-15-2013, 08:30 PM   #4
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Relevant mods/info:
So the diff is tight? Check trans mount and drive shaft joints
Old 04-15-2013, 08:43 PM   #5
gsla72
Member#: 224573
2002 Wrx Wagon
The rear end seemed ok when I popped the inspection cover, and the fluid was in decent shape with no metal flakes. Is there any other check I could do? Is there any procedure for checking the driveshaft out?
Old 04-15-2013, 09:56 PM   #6
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Just check to see if the joints have any play
Old 04-15-2013, 10:02 PM   #7
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
Also check to see if the diff is loose in the mounts
Old 04-19-2013, 12:03 AM   #8
gsla72
Member#: 224573
2002 Wrx Wagon
Just an update. Replaced the rear diff with a used unit and I'm still getting the noise. Either the used differential I bought is also bad, or the driveshaft is out. I'm going to find a used driveshaft and see if that fixes it.
Old 04-19-2013, 10:03 AM   #9
Umadbroej26
Member#: 352405
1996 Mutt
Exotic sea
It's the last thing left
Old 04-22-2013, 02:05 PM   #10
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
it sounds like you're on the right track but also check your outrigger bushings. If a rock or something gets jammed in there it can make one hell of a racket while decelerating and shifting... Also the metal plates that bolt the outriggers to the chassis can bend if you put jackstands under them. It can really sounds like your diff is exploding.
Zefy is offline   Reply With Quote
Old 05-22-2013, 02:13 PM   #11
gsla72
Member#: 224573
2002 Wrx Wagon
Driveshaft just replaced, still making noise. It seems to get worse the hotter it gets. I geuss I'll try replacing the outrigger mounting plates next.... Either that or the replacement rear diff is bad.
Old 05-23-2013, 10:23 AM   #12
South Bend Clutch
Member#: 269525
2005 350z
black
get the car up on a lift and have someone inside with the car running. Have them shift through gears. You should be able to see trans, engine, diff movement if it's a mount.
South Bend Clutch is offline   Reply With Quote
Old 12-29-2013, 10:47 AM   #13
gsla72
Member#: 224573
2002 Wrx Wagon
Update on this. I replaced the rear end with a low mileage R180 and hybrid rear cv joints (I had wanted to do this with plans of upgrading to a six speed later on). The noise is still there but dosent seem as bad. It's still definitely located in the rear of the car. I'm guessing outrigger bushings or something along those lines. I'm slowly running out of parts to change out, and no one seems to know what it could be.
Old 06-27-2014, 04:53 PM   #14
gsla72
Member#: 224573
2002 Wrx Wagon
Update for anyone interested. I'm beginning to think this is a failed/failing center diff or center diff bearing. Since my 4th gear grinds a little when it's warm anyway, I've decided to go six speed. I've wanted to do a 6mt since I bought the car, so it will all work out.
I have a low mileage 06 sti transmission, brand new clutch, flywheel, etc all waiting to go in. I'll update this once it's up and running with the new equipment. Hopefully this takes care of the noise.
Old 07-16-2014, 10:30 PM   #15
gsla72
Member#: 224573
2002 Wrx Wagon
Update: It seems the noise was in the transmission or in the clutch for anyone having the same issue. No longer have a knocking sound when decelerating. However, I'm worried my 6 speed has a different issue, but I'll address that in a new thread.
