Old 06-27-2014, 10:02 PM   #1
rdowner22
Member#: 329284
02 WRX Sport Wagon
Default LCA front inner bushing
From a GC8 WRX. Upgrading to aluminum control arms without having to go wider track like the STi's.
It's been a BIIITCH getting these things burned/pressed out.
Finally to the last part. Need this outerring off so I can smooth and press in new whiteline bushings.
Will hear be the best for this ring? I already have been trying to cut slits in it but still no budge.
Just like this tutorial second post:
http://www.wrxforums.com/forums/13-s...8-wrx-sti.html
Here's a pic of where I'm left with.
rdowner22 is offline   Reply With Quote
Old 06-27-2014, 10:40 PM   #2
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
****ing a dude. you butchered that.
You can either...
A: Take a hacksaw and cut the inner sleeve in two and then separate it.
B: Press it out using a press ( you should of taken this approach before you ruined the control arm)
Regardless of the situation you are going to have to deburr and clean up that mess of a control arm you created.
Cefaln452 is offline   Reply With Quote
Old 06-27-2014, 11:37 PM   #3
SHARP_DAL
Member#: 183247
2005 WRX
Get a reciprocating saw and cut the metal sleeve, be careful not to cut into the control arm.
Once you get a clean cut across the sleeve it will just pop out with a tap from a screw driver...
Then press in new bushings!
SHARP_DAL is offline   Reply With Quote
Old 06-28-2014, 06:53 AM   #4
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
This. IMHO the fronts aren't worth replacing as the bush material is like 1/4" thick. Came to that conclusion halfway thru the 1st and did it anyways. Same item GC LCA's
mhoerath is offline   Reply With Quote
Old 06-28-2014, 11:55 AM   #5
mitch808
Member#: 10228
2002 Subaru WRX
Put the arm in a vise, and a hacksaw can get through that with some effort. Simple and inexpensive if you dont have a reciprocating saw
mitch808 is offline   Reply With Quote
Old 06-29-2014, 12:42 AM   #6
rdowner22
Member#: 329284
02 WRX Sport Wagon
Well PIA had this control arm and they tried to air hammer it out because they couldn't get it to fit correctly in their press. But i have cut the sleeve on one side already and that thing does not want to budge. Thats why it looks so destroyed. You can see those notches at the bottom for every chisel hit
Old 07-08-2014, 09:45 PM   #7
wantsti
Member#: 134764
04 sti
java black pearl
I pressed mine. It took some creativity with different sockets. But the press I used had an open bottom so it aloud me to put the contol arm in a good posistion
wantsti is offline   Reply With Quote
