Old 06-26-2014, 05:20 PM   #26
Cobb Tuning
Member#: 4803
Originally Posted by Poopstick View Post
Exactly so when I did the update I went to my car connected it and was going to reflash and it said it was already completed. I assumed it would have taken it some time. Am I doing something wrong?
Were you running the latest beta version of the map (v334 for 08 - 14 STI and v331 for 09 - 14 WRX)? If so, then these maps that just got released are the same maps. The AP will check the map before it reflashes. If it matches, it will skip right to 100%.
Originally Posted by DownhillPhil View Post
I'll have to do some logs but, seem to have lower boost at WOT on my 13 STI Stage2+ NWG from v333 to v334.
There were no changes to any boost related tables from v333 to v334. The change log is in the latest map notes if you want to see what we changed, but none of the changes should have an impact on boost at WOT.
Did it just get hot where you live?
- Chris
Old 06-26-2014, 08:19 PM   #27
DownhillPhil
Member#: 346655
2013 STI SE
TOP
- Chris
Yeah definitely got hotter recently.
Logs I took this afternoon - (and they seem to be ok)
https://drive.google.com/file/d/0B7Z...it?usp=sharing
DownhillPhil is offline   Reply With Quote
Old 06-26-2014, 09:29 PM   #28
VEGAS WRX
Member#: 362867
2013 WRX
Updated today. Thanks Cobb!!
VEGAS WRX is offline   Reply With Quote
Old 06-26-2014, 09:44 PM   #29
Poopstick
Member#: 374035
- Chris
I have a sub001 did those maps change?
Poopstick is offline   Reply With Quote
Old 06-27-2014, 02:56 AM   #30
xgotboostx
Member#: 390623
2013 WRX
How many monitors do you have selected? Try reverting to the default log list. You can select more monitors than that, but if you select too many you will have problems connecting.
-Josh
Thanks Josh that did the trick. I can data log now. Did you limit how many items can be logged now in this firmware update?
While I was logging a 25-30 min drive every time there's a -1.4 hit in FBKC it occupies a lot of cells.
Here's a cruising log with the concerning areas highlighted:
https://docs.google.com/spreadsheets...it?usp=sharing
The log was taken right after the car was flashed (custom tune that I've had for a couple months now). Is this normal with the car in learning mode? A bug or glitch with the firmware? It looks to me it's holding that knock for a long time or there's a long delay before it starts to ramp down to 0. I also logged Knock Sum and there was no increase in the Sum count in any of the cylinders. The FBKC monitor gauge only shows -1.4.
xgotboostx is offline   Reply With Quote
Old 06-27-2014, 10:45 AM   #31
Hatchtastic
Member#: 385574
2014 WRX
Excited to see these maps come out of beta. I have been waiting to flash my hatch to stage 1 Looks like I am in for a treat this weekend!
Hatchtastic is offline   Reply With Quote
Old 06-27-2014, 04:22 PM   #32
Cobb Tuning
Member#: 4803
No, the 02 - 05 WRX maps already got a major update not too long ago (from v300 to v310). We did add support for the COBB 3-port boost control solenoid for Stage1 and Stage2 though.
- Chris
Old 06-27-2014, 04:24 PM   #33
msy5286
Member#: 377629
2013 WRX
Thinking of getting a cobb v3 for my wrx. Will this help smooth out the choking feel in 2nd gear when stuck in traffic?
msy5286 is offline   Reply With Quote
Old 06-27-2014, 04:51 PM   #34
Cobb Tuning
Member#: 4803
Your logs look good. You have that one timing correction in log 4, but it's small and is not consistent so I wouldn't worry about it.
The timing correction looks longer because our sample rate is higher in this latest firmware update. Where before the typical logging rate was 3 - 4 samples per second, it is now roughly 10 - 18 samples depending on the car. Just a ballpark example, if a timing correction took two seconds to go from -1.4 -> -1.05 -> -0.7 -> -0.35 -> 0 that would have been 6 - 8 lines in a datalog. Now that same correction would be 20 - 36 lines with the faster logging rate. Does that make sense?
- Chris
Old 06-27-2014, 05:01 PM   #35
xgotboostx
Member#: 390623
2013 WRX
- Chris
Makes perfect sense Chris thank you! I thought for a moment there that there was something wrong with the tune or a buggy ECU or something.
Thank goodness this is normal logging operation.
Old 06-28-2014, 02:56 AM   #36
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Its s a wonderful thing!
Chris... Bill got back to me on the issue. Its really amazing that it logs that freaking fast.
snoopy_sti is offline   Reply With Quote
Old 06-28-2014, 03:30 AM   #37
Dee_nice83
Member#: 362345
2013 WRX Hatch
"Any map with the exact same name, minus the revision number, will be up-revved during a firmware update. So if there is a Stage1 91 v330 map on there right now, the update process will update it to the latest release map. It will not touch any maps that do no exactly match our naming scheme (i.e. custom maps). "
I've updated the firmware. As you quoted above, I am currently running STG 2 ACN91 v312 SLWG. Now that there is no SLWG mapping, shall I upload STG 2 ACN91 v331 LWG MAP?
Dee_nice83 is offline   Reply With Quote
Old 06-28-2014, 09:36 AM   #38
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
Originally Posted by greenc51 View Post
Cobb Rep,
I was updating my AP last night and it spit back an error during the update process and did not complete the update. The AP itself seems to be functional, but AP manager WILL NOT connect to it now, and therefore, I am unable to add/remove maps or anything of that sort. With that said, I am do not want to connect it to my car in fear it was mess with the ECU. Is there anyway I can force it to install the update again without the need for the AP manager? Or will I have to send it to you all to fix?
Awaiting your reply.
Thank you
this happened to me too. same issues. i tried an older laptop with usb2 ports. i tried my laptop with usb3 ports connected to a usb2 hub. no good. i cant download accesstuner race and cant have my map adjusted and reflashed now. its a ap v2 for my 08 wrx. it logs fine but got an error message while updating and keeps doing the error message now.
Old 06-28-2014, 08:29 PM   #39
Barnold
Member#: 318142
Ok, so even on the HWG map I am only hitting about 16.5 PSI. I am stage 2+SF, target boost is 18 PSI. What do I do now?
Barnold is offline   Reply With Quote
Old 06-28-2014, 09:32 PM   #40
DownhillPhil
Member#: 346655
2013 STI SE
TOP
Was not expecting better MPG.
Old 06-30-2014, 01:15 PM   #41
erik11876
Member#: 275888
2011 WRX Limited
Nor was I, it was a nice bonus!
So far I have noticed the following:
Better mileage
Better low rpm torque in off boost normal driving
A little more violent boost onset, it's kinda fun
Color me confused on this one but my gear changes seem smoother
erik11876 is offline   Reply With Quote
Old 06-30-2014, 04:58 PM   #42
merdok
Member#: 391377
Sweet!! just found this today. Wish be my first flash since I got the car. cant wait!
merdok is offline   Reply With Quote
Old 07-02-2014, 02:48 PM   #43
EDJR_WRX
Member#: 388847
2014 WRX hatch
Ice silver metallic
Ya nice bonus huh! First time I've seen 27+ mpg.
EDJR_WRX is offline   Reply With Quote
Old 07-02-2014, 04:12 PM   #44
JimmyBoyWRX
Member#: 371081
2013 WRX Limited
2006 WRX
I'm still getting 20 ( car reads 21.5 but based on miles divided by fill up gallons) it's 20) all backroads driving.... Might start hitting the highway.
JimmyBoyWRX is offline   Reply With Quote
Old 07-02-2014, 04:32 PM   #45
EDJR_WRX
Member#: 388847
2014 WRX hatch
Ice silver metallic
Ya 27 was the average for a 140 mile highway trip. Bout 21-22 for stop an go.
Old 07-02-2014, 04:43 PM   #46
ragejed
Member#: 76817
2005 WRX
- Chris
By not too long ago, you mean when v310 came out in 2012? Just want to confirm this and that there is no need to flash an "updated" v310.
ragejed is offline   Reply With Quote
Old 07-03-2014, 10:27 AM   #47
Vit0r
Member#: 339989
2013 Base WRX 4DSD
Why do the map notes for v331 Stage 1 maps say absolutely nothing about an aftermarket catback exhaust while the v300 map notes do. Actually, v331 Stage 1 maps specify "stock exhaust". Did something change?
Vit0r is offline   Reply With Quote
Old 07-03-2014, 11:59 PM   #48
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
I am experiencing significantly worse gas mileage. I would average 18-20 depending on driving on the last OTS stage 1 93 octane normal wastegate map... now im at 15 mpg or so.
BTW I drive a 2013 WRX stage 1 v331 93 octane normal wastegate
kdizz781 is offline   Reply With Quote
Old 07-04-2014, 01:17 AM   #49
n_ac
Member#: 284838
2014 WRX STI 5Door
Hi Chris,
I switched to the new map a few days ago and here are a few normal driving logs.
I keep seeing small corrections between ~3100-4200 RPM
I do see these values pop up during freeway driving in 5-6th gear but have seen small values come up around the same range in lower gears as well.
Please let me know if there's anything to further investigate or if this looks normal.
Shorter Log: http://bit.ly/1lYDnZ8
Long Log: http://bit.ly/1zc1gBJ
Thanks,
Ac
n_ac is offline   Reply With Quote
Old 07-04-2014, 08:18 AM   #50
snoopy_sti
Member#: 164942
2015 Porsche Cayman
You have learned fine knock at Low load that is learning itself away. That's normal. At low loads the car is running maximum timing for efficiency. You had a Feedback correction from mashing the pedal also which is also normal. The computer is doing its thing.
Do a WOT pull and see how she looks.
