Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Vancouver Impreza Club
Old 06-29-2014, 02:19 AM   #1
njshred
Member#: 379030
2013 impreza sti
metal flake grey
Default accessport trouble
So i just got an AP for my 2013 STI. It is completely stock so i used the stock map. I use 94 octane but put on the 91 map cause thats what i heard was best. I was looking through the data and in my knock sum cylinder 1,2,3 i had around 30 counts, cyl 4 i had 100 counts. Thats obviously not good, i dont understand what the issue is cause i dont have any mods. Any suggestions would be appreciated. Thanks
njshred is offline   Reply With Quote
Old 06-29-2014, 06:46 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Using 91acn?
Old 06-29-2014, 02:12 PM   #3
njshred
Member#: 379030
2013 impreza sti
metal flake grey
No just 91, i will try 93 map but it didnt seem any better. Its actually pretty disapointing, the stock map seemed more responsive.
Old 06-29-2014, 04:43 PM   #4
DIGGYGV8
Member#: 313558
2011 STi Sedan
our gas apparently is crappy enough to warrant using the 91ACN-OTS maps as they're fairly aggressive (yet the ACN map is more conservative than just 91) from what I've seen. Even the stage 1 maps should be a world of difference in terms of throttle already.
DIGGYGV8 is online now   Reply With Quote
Old 06-29-2014, 05:01 PM   #5
KamekazeSTI
Member#: 379237
2010 GRB STI
I try not to use the knock sum feature on the AP. I find it to be too sensitive and doesn't really tell a true health of the engine and tune. Try seeing if any fine knock learn numbers show up. Anything between -1.4 and 0 should be normal for an OTS map. Of course it would be nice if you could log a 3rd gear pull for us to look at too!
KamekazeSTI is offline   Reply With Quote
Old 06-29-2014, 06:33 PM   #6
njshred
Member#: 379030
2013 impreza sti
metal flake grey
Fine knock sum was -1.4-0 and yeah i will do that shortly and post it
Old 06-29-2014, 07:14 PM   #7
njshred
Member#: 379030
2013 impreza sti
metal flake grey
Should i still use the 91 map if im using 94 octane gas?
Old 06-29-2014, 09:09 PM   #8
mrjason
Member#: 110929
2004 STI
I went down to Blaine to grab some 92 octane from chevron.
My car runs so much better.
I always user Chevron 94 - which, I hear isnt actually that good,
Next fill up (when I dont feel like going to the US) will be at Shell.
From what I hear, Shell 91 should be better than chevron 94.
mrjason is offline   Reply With Quote
Old 06-29-2014, 10:05 PM   #9
njshred
Member#: 379030
2013 impreza sti
metal flake grey
Interesting, so best to run shell 91 with a 91 map rather than chevron 94?
Old 06-29-2014, 10:18 PM   #10
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Subscribed for updates on cheaper/better canadian gas idea
Wrgb is offline   Reply With Quote
Old 06-29-2014, 11:10 PM   #11
DIGGYGV8
Member#: 313558
2011 STi Sedan
yes 91ACN (make sure it's the Arizona California Nevada(?) map, as it's made for crappier gas) w/ Canadian Chevron 94 seems to give best results for stability. Keep in mind, you may just have had a ****ty tank of gas. I find the further you get from the city (even out to Maple Ridge), and the gas starts getting crappier.
The consensus is:
-US 91 > Canadian 94. Most tuners in the states for example will de-tune you a bit knowing that our gas will knock.
Canadian 94 (as I can't be arsed to fill in the states) from Chevron is the only non-eth gas available locally, and I've never had problems with it. Shell is technically "top tier" gas as well, and I would have no problems throwing in my tank in a jam or something.
Old 06-30-2014, 10:03 AM   #12
mrjason
Member#: 110929
2004 STI
The consensus is:
Ethanol does help keep the engine cooler, which is good in a turbo car. That was something that also came out in all my research.
Old 07-01-2014, 03:22 PM   #13
danny_d19
Member#: 180748
2005 STi
According to Cobb:
"Knock sum can be difficult to interpret. Most of the increments you see will happen at low loads, where the knock feedback system is not very accurate. I usually don't pay attention to the actual number itself, just whether it is increasing when you go WOT."
danny_d19 is offline   Reply With Quote
