Old 08-23-2013, 04:39 PM   #826
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Add me please. I posted a while back.
Originally Posted by manitou View Post
Vehicle:2006 XTI
Motor:HP Techs, MPS SS LR 2.5
Turbo:Blouch 3.5XTR, 8cm HS
Boost:25 psi
Transmission:2007 STI 6 speed
Redline:8000/ revved to 7600
Upgrades:
[*]HP Tech's big valve, PnP'd, cammed D25 heads[*]Killer B Holy Header w/ custom Tial MVR up pipe[*]Custom 3" Exhaust w/ 1 3/4" Supertrapp muffler EWG exhaust[*]Walbro 465 hard wired FP[*]Perrin TF fuel rails[*]Aeromotive 1000 FPR, 55 psi base[*]ID 1000 injectors[*]ETS TMIC[*]PnP's STI intake, TB[*]Custom 3" Vibrant SRI in customized closed Cobb box[*]Cobb AP SD tuned by Junior2JZ, E85
I ran a log on 4/2/13 and posted a VD graph of it on my thread. I decided to VD graph just the 50-100 mph portion of the log based on my MFactory gear calculations for speed/ rpm's/ gear's. Here is a link to the full pull VD graph.
http://forums.nasioc.com/forums/show...2480570&page=3
Here is my 50-100 mph time based on this portion of the 3rd gear log.
Here is the VD time/ rpm graph
Weight: Full Stock Weight for an XTI+ driver (it's not at all a stock FXT) probably 3600 lbs. with all the crap I had in it not including me!
50-100MPH: 4.19sec
Old 10-28-2013, 03:18 PM   #827
bilt2run
Member#: 134211
Not sure if any of you still follows this thread but I figured I would post this up
2007 sti
built engine (tuned by Dave Brown)- performance auto solutions Deer park NY
turbo: 1.5xtr 10cm IWG
ETS top mount
invidia race elh
indicated 3/4 fuel
63* outside temp
235/45/17 michelin ss 25.4 diameter (gps said 102-103 at an indicated 100mph speedo
Dont know if I should start the clock at 48 mph and end at 98 ? or if that even makes a difference with the tall tires..
Either way approx 3.6 seconds
A little hard to see with the sun glare but, but i have vid with my friend in the car that did 3.7..
bilt2run is offline   Reply With Quote
Old 10-28-2013, 03:23 PM   #828
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
wow that thing is moving. what fuel are you using and what is your motor build if you don't mind asking.
k04sti is offline   Reply With Quote
Old 10-28-2013, 03:27 PM   #829
bilt2run
Member#: 134211
e85 but i didnt test it
I checked with a stop watch but maybe the OP can get us a more accurate time
Heads are ported with gsc stage 1 cams
compression is 8.66:1
also has a custom 64mm TB
stock sleeves as this car only has 24k miles on it
And the typical internal upgrades
Old 10-28-2013, 05:09 PM   #830
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Must be running some major boost.
Edit: here's a timeslip (post 583) which seems to match nicely up with your figures. 29psi on race gas and into the tens.
http://forums.nasioc.com/forums/show...442838&page=24
Old 10-28-2013, 05:32 PM   #831
bilt2run
Member#: 134211
boost is 24psi tapering to 22
Old 10-30-2013, 03:59 PM   #832
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
I'm definitely getting me one of those.
Old 11-01-2013, 05:45 PM   #833
amalgrover
Member#: 183480
New video with VF52 installed...
Vehicle: 2009 FXT Limited
Motor: Bone stock EJ255
Turbo: VF52
Boost: 23psi peak tapering to 17psi by redline
Transmission: Bone stock 4EAT
Redline: 6500rpm
Upgrades: 2012 STI struts, springs, and rear sway bar, 2011 STI wheels and tires, Motorsport-Tech wheel adapters, Megan Racing catless downpipe, SPT catback, Hallman MBC, Walbro 255, DW1000cc injectors, and E85....thats it...
Weight: 3653lbs including driver
50-100mph time: 6.27 sec
didn't fully launch it, have a slight leak at the uppipe to turbo gasket, and was only about 90% done tuning it, but figured it was close enough to get a quick video...
amalgrover is offline   Reply With Quote
Old 04-22-2014, 03:45 PM   #834
flath4
Member#: 331643
Chapter/Region: HIIC
Anyone still testing there 50-100mph times, since this thread has been used in several months. Also would 60-120mph be more ideal?
flath4 is offline   Reply With Quote
Old 04-22-2014, 03:48 PM   #835
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I haven't done any with my new car, but I still do check the thread once in a while. 60-130mph (approx 100-200kmh) is the standard for most lists, but on a 300HP car it isn't very easy to do pulls to 130mph. On 500 to 600+ HP cars it's a much better metric but for slow Subaru's the 50-100mph works well.
Old 04-22-2014, 06:18 PM   #836
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
And if you're gonna be a jackass on public highways, be a safer jackass and do 50-100. Not everyone has the real estate to do proper 60-130mph pulls.
Old 04-23-2014, 04:26 PM   #837
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
that lol ^
Old 05-06-2014, 10:37 AM   #838
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I came across these articles and added a new leader to the production car list. The McLaren P1. This car appears to be extremely fast! 150mph traps from a stock, production car is incredible.
http://www.motortrend.com/roadtests/...on_car_record/
http://wot.motortrend.com/1403_9_gee...claren_p1.html
Code:
Year	Make		Model		Price		LBS	HP	TQ	50-100	0-100	0-60	1/4 ET	1/4MPH	L	Cylinders
2014	McLaren		P1 		$1,150,000	3303	903	664	2.7	4.7	2.6	9.8	148.9	3.8	V8
Old 07-27-2014, 07:35 PM   #839
krisk
Member#: 333048
2013 WRX
VF52+E85+TP Road Tune
Default VF52+e85 - 6.247 seconds
Vehicle: 2013 WRX
Motor: 2.5L Stock
Turbo: VF52 (for now )
Boost: 22psi
Transmission: Stock 5 Speed
Redline: 6800rpm
Fuel: E85
Upgrades:
  • K&N Typhoon CAI
  • Grimmspeed EBCS
  • RacerX FMIC
  • TSUDO Catless Downpipe (DEI Heat Wrapped)
  • AP Equal Length Headers
  • ID1000s
  • DW65C FP
  • Forge V1 BPV (yellow spring)
  • NGK One Step Colder Plugs
  • Stock Catback
Weight: Full Stock Weight + Driver
50-100MPH: 6.247sec
Romraider Log
You can see the FFS in the log around 94 mph...which seems to have saved about two tenth of a second. Did this recently when it was around 80 outside.
Sayonara Synolimit! JK!!!
Custom tuned by Eric at Torqued Performance
krisk is offline   Reply With Quote
Old 07-27-2014, 08:08 PM   #840
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
Originally Posted by krisk View Post
Vehicle: 2013 WRX
Motor: 2.5L Stock
Boost: 22psi
Redline: 6800rpm
Fuel: E85
Upgrades:
  • K&N Typhoon CAI
  • Grimmspeed EBCS
  • RacerX FMIC
  • ID1000s
  • DW65C FP
  • Stock Catback
50-100MPH: 6.247sec
Romraider Log
Cheater.
synolimit is offline   Reply With Quote
Old 08-01-2014, 12:01 AM   #841
rymaggi
Member#: 253442
Default NASIOC 50-100mph List
Can someone let me in on the secret on how to mount the gopro onto the steering column. The suction cup doesn't wanna stay.
Sent from my iPhone using NASIOC
rymaggi is offline   Reply With Quote
Old 08-01-2014, 12:12 AM   #842
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I used the self stick GoPro mount on the steering column in my 2002 WRX.
For the videos in my 2011 WRX I used a suction cup mount (similar to the GoPro one) on the driver's side window and used a Canon G12 camera.
Old 08-01-2014, 12:17 AM   #843
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Flat back or curved back sticky mount. Just clip in the camera when it's "on"
Old 08-01-2014, 12:18 AM   #844
rymaggi
Member#: 253442
That's what I'm working with. My guess is there's some stupid interior cleaner/oil on it and it's not wanting to stick.
User error.
Old 08-01-2014, 12:24 AM   #845
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No. This.
Old 08-01-2014, 12:25 AM   #846
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
This is what you need
https://www.google.com/search?q=gopr...39%3B683%3B426
beat me to it
Old 08-01-2014, 12:29 AM   #847
rymaggi
Member#: 253442
Ah ha! That looks a weeeee bit better.
Old 08-04-2014, 11:54 AM   #848
smokey07
Member#: 151683
Vehicle: 2008 Civic Si
Motor: Stock 106k miles
Boost: ~9psi
Transmission/Clutch: Stock
Redline: 8600
Fuel: 93
Upgrades:
Jackson Racing Supercharger w/ stock 3.2" pulley ~9psi
Hybrid Racing 3.5" cai
Skunk2 Alpha header
Full Race 3" exhaust
Weight: ~3200ish with driver
50-100MPH: 7.4sec
**first attempt at this.. started in 2nd, sloppy shift to 3rd, decent into 4th. Car will go a bit quicker with cleaner shifts but happy with the time considering its a 90-mile per day commuter
smokey07 is offline   Reply With Quote
Old 08-05-2014, 06:43 AM   #849
spoolinsti05
Member#: 108051
2005 WRX STi
I'll have to grace this list soon as I get my gf to record it for me
Old 10-05-2014, 05:04 PM   #850
synolimit
Member#: 225225
11 WRX
Woooohooooo fastest NA over at 370z forum and faster than my WRX!!!!! My dyno and 1/4 mile all suck but at least I have some power. This tells me my dyno reads low and my tires suck for the strip. I'm getting 6.5 seconds on the vid and that's with my tires chirping in 2nd. I figure that's a good tenth or two right there if i can get them hotter. This is ZL1 and C63 AMG territory so woohoo for only 302rwhp.
Vehicle: 2013 370z
Motor: stock 3.7L v6
Turbo: NA
Boost: NA
Transmission: Stock 6 speed
Redline: 7800 rpm
Fuel: 93
Upgrades:
Ported TB's
Ported upper mani
Ported lower mani
Custom 2.75" CAI
Long tube headers
Custom 2.5" true dual CBE with X pipe
18x9.5 and 18x10.5 RPF1's
285/35/18 square RS-3's
Stance true type custom 2 way coilovers with 18k/12k swifts
All SPL arms, bushings etc
synolimit, 2013, Nissan, 370z, 3200*, 3.7, 6 Cyl, All Motor, NA, 93, 302, 244, 14.0, 105.5, 6.5
http://m.youtube.com/watch?feature=y...&v=gDcVViN-n-E
Krisk come to mid ohio I'll be the guy in front
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
