Old 07-29-2014, 09:26 PM   #26
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
sounds like you gotta play w/ a multimeter to track down the wire that's loose and or in the process of breaking completely.
Does the light on the radio change when you're wiggling stuff to get sound back?
If you have sound (static) you ought to be having radio too?
hmmmm electrical gremlinz, you haz 'dem
Also, that pic on the back of the 2011 radio was probably just a ground connection for the radio. some OEM radios have them and some don't. I don't remember if the back of my 2006's deck had one or not.
aerosaaber is offline   Reply With Quote
Old 07-30-2014, 12:05 AM   #27
143subaru
Member#: 157982
2002 Impreza WRX
Light doesn't change... No radio or at least none that I can pick up... The only thing that works is the volume knob, all other buttons are useless... And I suck with a multimeter... I'd rather change a transmission than F with electrical issues...
143subaru is offline   Reply With Quote
Old 07-30-2014, 01:08 AM   #28
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
did you wire in the radio amplifier wire too? it's basically the same as a power antenna or amp turn on wire but it power the antenna amplifier thing. (which may not be on an 02?)
I would almost say start from nothing, run new power, ground, illumination, and use the existing speaker wires.
test the speaker wires w/ a battery (9v or maybe a AA) on the +/- and see if the speaker clicks when you do it.
that will prove that the speaker wires are (probably) ok.
or just burn the damn thing to the ground (don't do that)
Old 07-30-2014, 01:34 AM   #29
143subaru
Member#: 157982
2002 Impreza WRX
Where would that be at? All I have is my big plug, antenna, and ground... And that extra little two prong plug that we don't know what goes too...
And wire from where? Meaning where to, like obviously the plug but where to from there?
PS: THANK YOU TO EVERYONE FOR HELPING SO FAR!!!
Old 07-30-2014, 01:45 AM   #30
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
do you have a regular antenna on the car or is it the antenna that's integrated into the window glass. if you have a regular antenna you might not have the amplifier thing.
Where the hell does that 2 wire plug go anyway? dig in and find that damn thing
you can get an add-a-circuit in the fuse box to get 12 volts for the radio. ground can go straight to the chassis.
Old 07-30-2014, 02:08 AM   #31
143subaru
Member#: 157982
2002 Impreza WRX
I do NOT have a power antenna, get the awesome one to pull out by hand
And I got a pic of the 2plug guy up in the thread but definitely nowhere in the head unit for it to go... Someone posted a link form I'm pretty sure a 2011 but I don't have **** to plug it into...
Old 07-31-2014, 12:52 AM   #32
143subaru
Member#: 157982
2002 Impreza WRX
Still need to get a multimeter to it and try what aero said but still gonna bump in hopes of... Well... In hopes somebody just knows what the ****s wrong.
Old 08-04-2014, 09:05 PM   #33
143subaru
Member#: 157982
2002 Impreza WRX
Said **** it and wired up an aftermarket radio... And guess ****in what? Works flawlessly....
Yeah NASIOC and buying used radios... Cause apparently I had two **** ones...
