Old 03-26-2014, 06:57 PM   #151
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
Originally Posted by sgoldste01 View Post
If his e-brake shoes are seized to the inside of the drums, wouldn't you expect that backing off the brake adjuster wheel won't have any affect, since the shoe is stuck to the drum?
Yeah, not 100% that loosening the adjuster will work, but it might... I see heat, 8mm bolts and a BFH in this guy's future.
Originally Posted by LIChuck View Post
The drums have two (2) threaded holes in them. If you put a bolt in each one and slowly tighten them evenly, the drum will come free.
Prolly not if the shoes are stuck to the rotor... hammer time!
OK, good to know. Thanks for the info.
But I don't know how comfortable the OP is with doing brake work. Before he could remove the rear rotors to expose the parking brake shoes (using your two-bolt technique), he would also need to remove the main calipers and pads. He will need to decide if he's comfortable with that process.
this
oaklandish_WRX is offline   Reply With Quote
Old 03-27-2014, 12:29 PM   #152
Udigod
Member#: 384258
05 Impreza WRX
Obsidian Black
I got them unstuck!!! I took off the ABS fuse and rocked the car a bit without turning it on. They broke free right away!
Udigod is offline   Reply With Quote
Old 03-27-2014, 12:35 PM   #153
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Nice!
Why did you have to remove the fuse?
Old 03-27-2014, 12:48 PM   #154
Udigod
Member#: 384258
05 Impreza WRX
Obsidian Black
Well, I rocked the car at first for a while but it wouldn't budge. Then I took off the ABS fuse and turned the key on and off a couple of time. Rocked it again for a bit and CRACK. The brakes came unlocked. I then put the fuse back on and now it's fine. I think the fuse had something to do with getting them unstuck
Old 03-27-2014, 02:32 PM   #155
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
My guess is that they would have gotten unstuck even if you hadn't removed the fuse, but I could be wrong.
Regardless, good job.
Old 03-27-2014, 03:07 PM   #156
oaklandish_WRX
Member#: 267339
MBP LongRoof
^ this
ABS != e-brake
Old 04-08-2014, 05:26 PM   #157
KBrownLGT
Member#: 386261
Default Sti brembo
does any one have sti brembo brakes for sell
KBrownLGT is offline   Reply With Quote
Old 05-05-2014, 04:27 PM   #158
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Just browse the classifieds, they pop up quite often. I just found a set last week.
jester8798 is offline   Reply With Quote
Old 06-29-2014, 01:49 PM   #159
cbeaum14
Member#: 211526
2004 STI
JBP
I'm looking for new pads for my 04 STI's 90k service time. It's my DD probably looking at sintered pad. I'm not looking for specific suggestions (unless you want to suggest some), but rather a yelp for break pads.
Can anyone point me in the correct direction?
cbeaum14 is offline   Reply With Quote
Old 07-31-2014, 08:07 AM   #160
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
KNS Brakes (vendor WRXBrakes on NASIOC) has a lot of pad options and knows a lot about what they sell. Give them a call and they can both suggest and sell you a pad that fits your needs.
Scooby921 is offline   Reply With Quote
Old 11-01-2014, 11:03 PM   #161
Sebar34
Member#: 398962
2014 New WRX
Blue Galaxy
very good information
Sebar34 is offline   Reply With Quote
Old 12-25-2014, 08:33 AM   #162
JoeNick14Sti
Member#: 407660
2014 Wrx Sti 4dr
Ok, I have been noticing on my 14 Sti sedan that there is ALOT of break dust on the front wheels and the brakes also sound like there grinding? Car only has 10k on it. No track days just DD. Will different pads fix this? Idle the breaking power but dirty rims right after I wash the car😢. Thanks for the help.
Sent from my iPhone using NASIOC
JoeNick14Sti is offline   Reply With Quote
Old 12-25-2014, 11:14 AM   #163
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Your car is still under warranty. Let the dealer check it out first.
Old 12-25-2014, 11:53 AM   #164
JoeNick14Sti
Member#: 407660
2014 Wrx Sti 4dr
Good idea
Old 01-23-2015, 08:03 PM   #165
Swampdonkey
Member#: 89800
2010 STi Hatchback
Default Brakes on a Budget
So I got laid off this last month and now have to do all 4 rotors and pads on my new/used 2010 STi wagon, but am on a budget. I am currently running bone stock and basically just doing aggressive street driving in a major city. So with that being said, I need to find the best replacements for the price and my current usage. Was hoping I could get some help from you guys on this, as I have searched the net so much and have come across nothing exactly useful. Any particular thoughts on this: https://www.knsbrakes.com/c/car-seri...mic+Brake+Pads or any other recommendations?
Swampdonkey is offline   Reply With Quote
Old 01-24-2015, 01:04 PM   #166
oaklandish_WRX
Member#: 267339
MBP LongRoof
Package seems overkill for you. Check reviews on the pads too. City driving may not fit the hawks. Email kns for advice.
I run centric premium and stop tech street pads; love it. YMMV
Old 01-26-2015, 10:51 AM   #167
NASIOC Storefront Vendor
Member#: 406718
On a budget, I think you could go with the Centric Premium rotors and the Centric Posiquiet pads.
If you wanted to save even more money, the Centric Standard C_Tek rotors with the Centric Posiquiet pads would be the next option.
-Nick
nick@knsbrakes is offline   Reply With Quote
Old 02-08-2015, 09:48 AM   #168
Missconstancejulia
Member#: 407832
2004 Impreza WRX
Java Black Pearl
I've got an 04 wrx with the 4eat in it. Idk if that matters but I was wondering what to do or what I would need to buy to be able to run sti brembos
Missconstancejulia is offline   Reply With Quote
Old 02-08-2015, 10:17 AM   #169
KNS Brakes
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Wheel Clearance
Brembo's
5 x 100 rotors
Rear caliper adapter
Pads
http://www.knsbrakes.com/c/kns-bracket
Old 03-10-2015, 10:14 PM   #170
Devon06EJ
Member#: 393664
2006 Impreza 2.5i
steel grey metalic
Default constantly replacing brakes
shortly after I bought my 06 Impreza I did pads and rotors on the front and rear I've had no issues with the rear brakes however the fronts seem to keep going through pads.. Shortly after I out the front brakes on (2,500 miles) my pads started squeeking and then shortly after that nocking around I then replaced pads and rotors and hardware again and still have the same issue each time I used brake grease anyone have similar issues ? I'm on my 3rd set of pads rotors and hardware on the front luckily under warranty
Devon06EJ is offline   Reply With Quote
Old 05-29-2015, 04:04 PM   #171
San Holo
Member#: 422374
Default Upgreading my 2004 wrx brakes
I want to upgrade my brakes, I believe the current setup is original OEM. I will only be street driving. I have read all about how my tires are what stops the car not the brakes but I want to upgrade my brakes system and will have good tires so I need to know what is best for a street driving upgrade over stock on a 2004 wrx. Do I really need big brake? and if not what would a good quality set-up. thanks!
San Holo is offline   Reply With Quote
Old 05-29-2015, 04:13 PM   #172
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
No big brake kit necessary for street only. In fact, it will just cause more headache and make maintenance more expensive. Stainless brakes lines will help improve pedal feel and modulation. Bleeding/flushing the fluid every year will keep the crisp, tight feel from fading over time. I like the stop tech street performance pads. They feel as good or better than stock on initial bite and should hold up to anything you will throw at them on the street. Even the occasional track day is fine unless you are making significantly more power than stock. Cons are that they wear rotors a bit faster than stock pads and apparantly can cause some corrosion issues on rotors if you let it sit for extended periods without driving.
Old 05-29-2015, 06:15 PM   #173
oaklandish_WRX
Member#: 267339
MBP LongRoof
+123456789
Old 06-01-2015, 10:22 AM   #174
KNS Brakes
Member#: 125739
2015 WRB WRX
Centric Premium rotors are a great OEM type replacement rotor. StopTech pads are good, but we've been having a problem with them. People tend to get them based on recommendation and not based on application and their own driving style. Lots of people who have gotten then don't necessarily drive the car hard. If you have the StopTech pads, they like to be used often and hard. When they're underused they are prone to uneven pad deposits. I get 3-4 phone calls a week about it.
Lots of people have been using the newer Hawk HPS 5.0 pads. They are definitely way better than the original HPS pads. We have them installed on our bone stock 02 WRX.
-Nick
Old 06-01-2015, 11:28 AM   #175
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
how do the Hawk 5.0 pads compare to STSP pads in terms of:
1. Price
2. Initial Bite
3. Dust
i've been using the STSP pads on my 2010 WRX (with FHI 4-pots) for well over 100,000mi. I really like the price/performance. the only thing I don't like is the dust. they get very messy quickly.
front pad life seems to be about ~30,000mi
front rotor life about ~60,000mi (i replace rotors every other pad change).
rear pads lasted about 55,000mi
havent replaced the rear rotors yet.
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS MWSOC Vendor Classifieds 10 09-10-2007 10:43 AM
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS Suspension/Brakes/Handling 10 08-13-2007 01:43 PM
Brakes Brakes Brakes cool13b Legacy Forum 2 03-22-2002 05:08 PM
Brake Lines, Brake Lines, Brake Lines: Rate malaki Brakes, Steering & Suspension 0 05-03-2001 06:55 AM
brakes! brakes! brakes! greg Mid West Subaru Owners Club Forum -- MWSOC 16 12-07-2000 08:36 AM
