Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 05-24-2014, 11:50 PM   #101
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
Originally Posted by Saabaru81 View Post
all of this home modifying looks like a quick way to void the warranty If anyone is looking for a Subaru Nav unit fujitsu ten FM601US I have one in really good condition that I would like to sell. email me here
Price
pkluong is offline   Reply With Quote
Old 05-25-2014, 05:01 PM   #102
Saabaru81
Member#: 391186
Originally Posted by pkluong View Post
Price
400$ shipped
350$ local pickup
item is local to los angeles, ca
Saabaru81 is offline   Reply With Quote
Old 06-14-2014, 08:37 PM   #103
AleksanderSuave
Member#: 391196
2014 WRX Hatch
quick question, which of these parts are optional if you are not looking to do camera and satellite radio?
obviously skip buying a camera,
but do you still need all of these?:
(1) 10+6-pin reverse harness (w/ illum.-)
(1) 20-pin forward harness (w/ illum.- & long 3 SWC)
(1) 28-pin harness assembly (w/ VSS, r.gear, SWC, 16-pin>aux/mic)
(1) Subaru USB cable (to male USB A)
(1) GPS Antenna ($12) http://www.ebay.com/itm/231020270302...84.m1439.l2649 (this one Im guessing obviously yes, to have gps function)
(1) FM Antenna Adapter ($13) http://www.ebay.com/itm/400494961719...84.m1439.l2649
(1) Lexus reverse USB adapter ($10) http://www.ebay.com/itm/190850462942...84.m1439.l2649
mostly confused about the usb listed components on here.
Im in the same situation as you, 2014 wrx premium hatch.
going to be buying a 2012/2013 F10 head unit for nav but not looking to do the camera at this time, (maybe later?)
would it make sense to have all the wiring harnesses done for the camera now and just add a camera later or is it the same regardless?
AleksanderSuave is offline   Reply With Quote
Old 06-19-2014, 10:43 PM   #104
FunRuSSkiMAN
Member#: 372043
15 sti
Default Svxdc
Has anyone managed to get in contact with svxdc? I have been trying for a while without any luck. Is he ok?
FunRuSSkiMAN is offline   Reply With Quote
Old 06-19-2014, 10:51 PM   #105
FunRuSSkiMAN
Member#: 372043
15 sti
Originally Posted by luan87us View Post
Not at all. SVXdc's instructions are clear as day. As long as you're following it you'll be good. Now that he has EVERYTHING you need to complete it, this should be cake. I had to figure a lot of stuff on my own lol.
Could you share the instructions please?
Old 06-20-2014, 01:00 AM   #106
AleksanderSuave
Member#: 391196
2014 WRX Hatch
I am in the same boat, waiting on a response back regarding a harness, havent heard anything yet..
Old 06-22-2014, 12:58 AM   #107
FunRuSSkiMAN
Member#: 372043
15 sti
Originally Posted by tonymontana1204 View Post
Completed on the XV. Everything works just waiting on the Nav bezel from the dealer.
Could u post wiring instructions?
Old 06-23-2014, 07:47 PM   #108
FunRuSSkiMAN
Member#: 372043
15 sti
I got a response today! He sounds busy. He has made a new page for this instal
http://ae64.com/FT_nav_transplant_harness.htm
Old 06-27-2014, 08:45 PM   #109
AleksanderSuave
Member#: 391196
2014 WRX Hatch
I have as well, I replied promptly to place the order, but have not heard back since.
Old 07-01-2014, 09:19 PM   #110
Zack sti
Member#: 372079
Good evening everyone . I really need to get this kit so I can finish my install . Is there another supplier beside my man Dave
Zack sti is offline   Reply With Quote
Old 07-07-2014, 08:19 PM   #111
TwinWRX
Member#: 391119
I'm in the same boat. I need Dave's harnesses but he's beyond busy. Any other options out there?
TwinWRX is offline   Reply With Quote
Old 07-13-2014, 10:10 PM   #112
Ar2422
Member#: 396048
As anyone bought a HU from china? I saw this site and I could get a HU that is plug and play just not sure how good it is.
http://www.smartauto24.com/subaru-fo...radio-gps-1680
Ar2422 is offline   Reply With Quote
Old 07-31-2014, 12:43 AM   #113
AleksanderSuave
Member#: 391196
2014 WRX Hatch
got all my wiring stuff from Dave, everything works awesome. BT integration, USB, Nav, etc.
a few questions:
1.is there a place on the F10 HU to hookup the old redundant chassis ground? on the clarion unit it plugged into a metal tab sticking out of the middle of the back, between the USB input, and all the other inputs.
2. I did not splice the VSS and reverse yet, as it was too dark out by the time I was done, however, I hooked up the stereo without that, and all the functions (including menu input while driving) seemed to have worked fine.
Without a camera, what effect is there on the operation without the splicing? And with the camera, how does it change?
Also, where did you do the the actual splicing? the 2 cables from the harness are pretty short, few inches in length really, do I need to run additional cable down the side to where the passenger kickpanel is, or is there a way in that taped up wiring to splice in there once unraveled?
Old 07-31-2014, 12:36 PM   #114
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
Default 2012+ OEM Fujitsu Ten Navigation HU to Non-Nav WRX transplant!
Can someone do a step by step install with photos please?
Sent from my iPhone using NASIOC
Old 08-01-2014, 04:25 AM   #115
AleksanderSuave
Member#: 391196
2014 WRX Hatch
Im not sure that you need a 'step by step' for just the transplant)
it was a matter of simply taking off the bezel, unplugging the old radio, and plugging the new one in (once you soldered up the matching colored wires on Dave's harness)
I think its the other parts (where you add camera, etc) that you may run into some confusion, as I did, with the splicing. However, I think even that, as evident in this post, can be avoided.
Old 08-13-2014, 02:34 PM   #116
BDKonig
Member#: 378573
2013 WRX Limited
Ice Silver Metallic
I just installed my FT Nav unit out of a BRZ into my 2013 WRX. Install is fairly straight forward. SVXdc got back to me in about two weeks after my initial email, and after I payed for the harness it came 3 days later. Keep in mind, he is in Atlanta and I am in Jacksonville, FL, so your shipping time may vary.
Splicing the harnesses together is a matter of matching colors together. It seems he ran out of wire for my illumination (-) but he marked it clearly and it wasn't an issue hooking it up. I used some Raychem environmental splices for my harness only because I have them readily available.
As for the GPS antenna, I found a cheap Forester Antenna on Ebay and mounted it in the stock spot. I didnt hook up VSS or Reverse yet, but on my test drive the GPS was spot on.
Also, when you read reviews about this unit from BRZ owners they talk about display lag and GPS problems, neither of which I have experienced. A big thank you to SVXdc, without him this wouldn't be a practical upgrade.
BDKonig is offline   Reply With Quote
Old 11-19-2014, 09:27 AM   #117
Ericksti
Member#: 329459
Where does the antenna mounts in the car??
Sent from my SM-N910T using NASIOC mobile app
Ericksti is offline   Reply With Quote
Old 11-19-2014, 09:28 AM   #118
Ericksti
Member#: 329459
Also does the factory mounted usb works without having to buy a harness ?
Old 11-19-2014, 02:13 PM   #119
BDKonig
Member#: 378573
2013 WRX Limited
Ice Silver Metallic
The antenna in the pictures I posted above mounts in the stock location, which is in the dash above the gauge cluster. All the other information you would need can be found here
Old 01-05-2015, 06:27 PM   #120
DiscoGsus
Member#: 47646
0211 RallyWagon
DGM Sedan
A question for anyone who has done this swap:
Do all the other car info displays work on this transplant? Things that the HU displays on 2012 cars like boost, oil temp, etc etc.
DiscoGsus is offline   Reply With Quote
Old 01-07-2015, 03:54 PM   #121
JoeyD215
Member#: 314196
2015 Impreza WRX STi
Lightening Red
I Emailed The Seller For The Harness And He Has Yet Gotten Back To Me, Cant Wait To Do This.
JoeyD215 is offline   Reply With Quote
Old 01-10-2015, 04:10 PM   #122
ckrockets
Member#: 408963
2014 WRX Premium
5-door WR pearl blue
Nice!
ckrockets is offline   Reply With Quote
Old 01-11-2015, 11:09 PM   #123
g00b86
Member#: 338023
2013 Base WRX Hatch
CBS
^ Good Luck. I have emailed svxdc once a month for the last 3 months with no reply. I'm at the point where I might just sell my unit and not even install it. :FRUSTRATED:
g00b86 is offline   Reply With Quote
Old 01-11-2015, 11:17 PM   #124
Ericksti
Member#: 329459
I emailed him a while back also havent heard anything back ..
Old 01-12-2015, 01:24 AM   #125
sheep shagger
Member#: 410714
Unhappy
I have had a similar experience with svxdc. So I've spent some time sourcing all the connectors and making my own harness. I've just finished it, and will install next weekend. If it works, ill post the details. Everything was super easy to get. one of the USB connectors I had to source from china, (through ebay), so that took a few weeks to get, everything else is available from Amazon, and one $5 plug from Toyota dealer. About $80 for everything.
sheep shagger is offline   Reply With Quote
