Old 07-31-2014, 08:45 PM   #1
TurboQueef
Member#: 86700
2005 STI
Silver/Black,[email protected]
Default Drop in oil pressure AVCS suspect?
Good day,
I have been troubleshooting an issue with my engine:
1600 miles ago I was dialing in an E85 tune, I made a pull at 27.5psi and spiked very rich (9:8/1 AFR).. by redline (7500). The engine sputtered (technical term ;-) just before I lifted at red line.
I was datalogging and did not see any knock or abnormal condition with the pull.
Soon after the pull I noticed my oil pressure dropped by 10psi. I pulled a sample and sent to Blackstone.. report came back good (some lead but was due to me cutting pump with leaded fuel before switching to E85. Copper & Tin low to zero ppm.
Engine sounds and runs great ... just lower oil pressure:
Before this issue: cruising at 75mph I had 78psi.. now I have 70.
Peak pressure was 80~83psi before now it is 70~73psi.
My oil pressure is taken from the rear passenger side of block.
Running 20w50 VR1, 11mm pump with 1 extra shim, King XPG bearings.. Oil clearance: Mains = .0018~.0015. Rods .002
I have tried mechanical gauge and confirmed pressure reading is same on both.
Yesterday, on way to work after full warm up the pressure dropped another 10psi. I was catching live data at the time and noticed the AVCS system was not advancing the cams at all in areas where target was 10 degrees. After driving a few more miles after coming to stop.. the AVCS started working again and oil pressure came up 10psi. (no CEL)
I am wondering if the AVCS system is causing my oil pressure drop. I am going to double check but I believe the filters have been removed.
Any leads for areas to check are appreciated.
Thanks,
Jeff
TurboQueef is offline   Reply With Quote
Old 07-31-2014, 09:20 PM   #2
Juice66
Member#: 340526
2004 WRX STi
HTA86
Single or dual avcs?
Juice66 is offline   Reply With Quote
Old 08-01-2014, 04:29 AM   #3
TurboQueef
Member#: 86700
2005 STI
Single AVCS 2005 STi
Old 08-01-2014, 11:29 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Fuel dilution from the dyno/rich fuel would have been my guess, but it sounds like you've done an oil change since.
Single AVCS will not cause the pressure to drop significantly, at least not anything like the 20psi you can see with dual AVCS.
Sounds like something may be starting to go south on you, unfortunately, likely to be something internal. I'd be tempted to pull the motor before it leads to something more catastrophic.
And ditch that 11mm pump while you're at it. They are notorious for aerating once beyond factory redline, especially NOT on a car that needs the extra flow (non-dual AVCS, journal turbo, etc...). It can be enough to skim a bearing for sure, or worse, spin one.
Take your readings off the front of the engine, otherwise you will see lower pressures. The front is going to give the highest most consistent pressures vs after passages start to split and pressure drops.
Good luck!
Old 08-01-2014, 11:44 AM   #5
TurboQueef
Member#: 86700
2005 STI
Thanks for the info KillerB...
I changed oil and sampled three times sense initial drop. Bearing material copper and tin are very low. Lead is slightly higher (6ppm) but I think this is due to the leaded fuel I ran a few changes ago.
Can u tell me how my current oil pressure compares to other builds with similar spec as mine?
Sent from my SCH-I545 using NASIOC mobile app
Old 08-01-2014, 11:57 AM   #6
Juice66
Member#: 340526
2004 WRX STi
HTA86
Originally Posted by KillerBMotorsport View Post
Fuel dilution from the dyno/rich fuel would have been my guess, but it sounds like you've done an oil change since. Single AVCS will not cause the pressure to drop significantly, at least not anything like the 20psi you can see with dual AVCS. Sounds like something may be starting to go south on you, unfortunately, likely to be something internal. I'd be tempted to pull the motor before it leads to something more catastrophic. And ditch that 11mm pump while you're at it. They are notorious for aerating once beyond factory redline, especially NOT on a car that needs the extra flow (non-dual AVCS, journal turbo, etc...). It can be enough to skim a bearing for sure, or worse, spin one. Take your readings off the front of the engine, otherwise you will see lower pressures. The front is going to give the highest most consistent pressures vs after passages start to split and pressure drops. Good luck!
would it be worth it for him to replace 11mm with 10mm first?
Old 08-01-2014, 11:58 AM   #7
TurboQueef
Member#: 86700
2005 STI
My initial thought was I damaged bearing but now I am confused.
I researched the make up for King XPG bearings... Top layer is very thin nickel I believe. Second layer (babbit) is alloy: lead is base, copper is 5 to 10 % and tin is 10% . My oil reports have never had nickel and tin has been zero or 1 ppm... copper is 3 to 9 so based on oil I am struggling to believe it is bearing related.
Any thoughts on this?
Old 08-01-2014, 12:01 PM   #8
Juice66
Member#: 340526
2004 WRX STi
HTA86
Originally Posted by TurboQueef View Post
Thanks for the info KillerB... I changed oil and sampled three times sense initial drop. Bearing material copper and tin are very low. Lead is slightly higher (6ppm) but I think this is due to the leaded fuel I ran a few changes ago. Can u tell me how my current oil pressure compares to other builds with similar spec as mine? Sent from my SCH-I545 using NASIOC mobile app
my clearances are identical to yours but with a 10mm. I too have single avcs and i see around 80 cruising and 87ish redline with 15w50. If youre out pounding it hard, its not uncommon to see about 7ish psi of drop with how hot the oil gets but that also depends on if you have a stock cooler and what oil
Old 08-01-2014, 12:08 PM   #9
TurboQueef
Member#: 86700
2005 STI
It does drop 7 or so under pounding or long 75mph cruise.
I do not run an oil cooler (removed stock)
Old 08-01-2014, 12:10 PM   #10
Juice66
Member#: 340526
2004 WRX STi
HTA86
It does drop 7 or so under pounding or long 75mph cruise. I do not run an oil cooler (removed stock) Sent from my SCH-I545 using NASIOC mobile app
why......?
Old 08-01-2014, 12:47 PM   #11
TurboQueef
Member#: 86700
2005 STI
Remove oil cooler? Axis removed it when built my engine. Ron said for my driving did not need it. He mentioned it restricts flow.
I only drive in summer...no tracking ..other than 1/4 mile every so often.
Old 08-01-2014, 03:16 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No Problem. I really can't tell you how it compares because you're measuring from the back port. Take a read off the front and we can see how it looks. Spending $15 on a mechanical gauge to verify what you're seeing is cheap insurance and an easy way to know if it's coincidentally a flakey sensor/gauge.
IMO this is definitely not an engine built for a 11mm pump. More harm than good can come from running the bigger pump.
