Old 07-31-2014, 10:04 PM   #1
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
Default adding another aux port
I currently have 2010 impreza with a OEM radio with an Aux Port in the center console, I want to add another AUX port behind the oem headunit so I can connect this bluetooth Unit below for music streaming through the aux port an NOT the FM antenna
Isimple Blu
I know this is for a 20052009 outback/legacy would this work for me? while still retaining the oem aux port?
an Finally has anyone heard from svxdc? its been quite a few days since Ive emailed him
MikeMiranda is online now   Reply With Quote
Old 07-31-2014, 11:06 PM   #2
millertime359
Member#: 393302
2014 Impreza Sport
For your question on svxdc read here: http://forums.nasioc.com/forums/show....php?t=2627068
He would probably be able to make you something if he doesn't have it already. Need to be patient with him. It is worth it though, he does good work.
millertime359 is offline   Reply With Quote
Old 08-01-2014, 10:23 AM   #3
LIChuck
Member#: 266122
2007 WRX Limited
UGM
If the head unit only has one aux port you can use either the aux port in the center console or the aux port INPUT you add. You are not adding another port, just another input to the same port.
I would just check where the center console port connects to the HU and replace it with what you want. It may be as simple as unplugging the existing input and plugging in your new input. To find out, pull the head unit and look at the back of it.
LIChuck is offline   Reply With Quote
Old 08-01-2014, 09:29 PM   #4
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
Yes you are correct sorry for not being more specific I want to tap into my current aux port an add RCA's so I can install the a device above
