Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-01-2014, 01:51 PM   #1
UnknownAlly
Member#: 277330
2004 WRX
Default Setting level on amplifier amp Jenson XA2250
The manual says to turn down amp "level" knob all the way down. Then turn up the volume until I hear distortion. Turn it down a tad.
Then it says to turn up the amp level until I hear distortion and then turn it down a bit.
My question is am I listening for distortion from the door speakers or subwoofer?
UnknownAlly is offline   Reply With Quote
Old 08-01-2014, 11:05 PM   #2
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
if there's only one level adjustment knob you're listening for whatever distortion happens first.
aerosaaber is offline   Reply With Quote
Old 08-02-2014, 01:45 AM   #3
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
first there is an audio-specific forum on Nasioc.
next: the basic process is simple.
1. choose the type of music you listen too MOST in the format you use most, so if you listen to Metalica/Seven Dust on iPhone then that's the genre and format.
2. set one song you know VERY well on repeat in the format of choice.
3. turn the gain(s) on the amp all the way down.
4. Whatever head unit you have will have a "level range" example Alpine usually goes 1-35. Pioneer 1-40 or 50. Kenwood used to be 1-25... whatever the top level is figure out 75% of max volume. Alpine would be a volume rating of roughly 20-25 of 35.
5. with the amp all the way down take the Head Unit up slowly to 75%.
6. when you hit 75%, now go back to the amp and VERY SLOWLY bring the gain up until you hear audible distortion. back it off 1/8-1/4 turn.
7. Change songs and verify other tracks don't have higher dynamics.
using the "75% rule" leaves you room for more dynamic recordings without worry of trashing speakers.
~Rob
TXwrxWagon is offline   Reply With Quote
Old 08-02-2014, 11:39 AM   #4
bobditts
Member#: 392683
2014 LS hatch
quartz blue
bobditts is offline   Reply With Quote
Old 08-02-2014, 01:05 PM   #5
TXwrxWagon
Member#: 191557
2004 WRX Wagon
huh..... who'd a thunk it... the old guy (me) might have it right...
http://www.wikihow.com/Set-the-Gain-on-a-Car-Amplifier
~Rob
Old 08-13-2014, 02:17 AM   #6
UnknownAlly
Member#: 277330
2004 WRX
my speakers aren't amplified by the amp, only my subwoofer
Old 08-13-2014, 08:52 AM   #7
bobditts
Member#: 392683
2014 LS hatch
quartz blue
you still have to adjust the gain properly. It will be difficult to hear distortion from the sub (unless it is severe) so use the DMM method to adjust your gain.
