Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 08-01-2014, 09:47 PM   #26
vicious_fishes
Member#: 158864
2003 GD w/EZ30 swap
here we go...
Old 08-02-2014, 01:01 AM   #27
raggedoutsti
Member#: 255714
2005 STi
psm
what goes wrong with sleeved engines? Forgive me I'm a noob, but i have a Benson sleeved block in my car right now. Havent even done the first start yet.
raggedoutsti is offline   Reply With Quote
Old 08-02-2014, 03:17 AM   #28
communik
Member#: 122112
2005 STi
I have a 560 awhp dd with outfront's closed deck block. no probs so far with about 20k on the block @ 28 psi.
communik is offline   Reply With Quote
Old 08-02-2014, 04:01 AM   #29
2000subie
Member#: 207638
2004 WRX
Yellow
Most common issue is the sleeves dropping. Which leads to no more headgasket sealing.
I say stock sleeves FTW! I'm going to push 33/34psi on mine and hopefully 700whp. I also don't daily my car though.
2000subie is offline   Reply With Quote
Old 08-02-2014, 08:32 AM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by outfrontmotorsports View Post
And a very popular opinion at that.
No closed deck blocks have failed.
I have yet to see a sleeved block with decent power and no sleeve issues over prolonged periods of time.
No doubt, you guys build great engines.
Sleeved engines fail when they are installed wrong or the pre-machining is done wrong. Assuming assembly, components, and tune are correct you should see several seasons (years) and MANY rebuilds from a sleeved motor. Which is something you will not see from a closed deck block given some applications. They are just different animals and each have their own application where they are advantageous IMO.
KillerBMotorsport is online now   Reply With Quote
Old 08-02-2014, 08:54 AM   #31
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
this is brolic, very good to hear
user1029 is offline   Reply With Quote
Old 08-02-2014, 08:54 AM   #32
user1029
Member#: 57064
2008 STi IAG built
Old 08-02-2014, 10:05 AM   #33
DisoDisp
Member#: 187648
2007 WRX
We've seen aftermarket closed deck failures when bored out to 100mm
DisoDisp is offline   Reply With Quote
Old 08-02-2014, 03:29 PM   #34
user1029
Member#: 57064
2008 STi IAG built
Originally Posted by m.bryant View Post
It's only $875 to have the closed deck process done, hardly "paying to play big" in the grand scheme of things. I'm a big fan of the 1/2" studs they can machine for at Outfront too...for anything that will be running 30+ pounds of boost.
I've got 14k on my closed deck DD and now running a Full-Race BW EFR 9180 twin scroll. Should easily get the 900 whp mark on the dyno in a few weeks. With no block failures and no added risk of dropping sleeves, the $875 is a VERY good option and should be strongly considered for a build like this!
Pretty much sums up everything great about the closed deck
Old 08-02-2014, 03:44 PM   #35
m.bryant
Member#: 310077
2007 Legacy GT SpecB
Who's closed deck and what type of failure?
Sent from my iPhone using NASIOC
m.bryant is offline   Reply With Quote
Old 08-02-2014, 06:21 PM   #36
DisoDisp
Member#: 187648
2007 WRX
A local company, their cdbs look like this:
CDB by DisoDisp, on Flickr
Fail at the same place as semi closed decked blocks, the bolt pass through releif into the water jacket.
P.s im pretty sure there are failed outfront cbd's on nasioc too, atleast on the old design.
Old 08-02-2014, 07:13 PM   #37
user1029
Member#: 57064
2008 STi IAG built
Definitely not Outfront's
Old 08-02-2014, 08:18 PM   #38
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
That was the old design. New one supposedly has zero failures.
How much power was that setup pushing that broke??
Old 08-02-2014, 09:00 PM   #39
DisoDisp
Member#: 187648
2007 WRX
Just under 500, wasn't a big power build iirc.
Old 08-03-2014, 12:47 AM   #40
user1029
Member#: 57064
2008 STi IAG built
Could be a tuning thing. Even stock semi closed deck can hold 500
Old 08-03-2014, 01:31 AM   #41
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
ive got almost 2k on my build using an outfront closed deck haha not too bring that back up but jus sayin.... making over 500whp
tyrel.boyce is offline   Reply With Quote
Old 08-04-2014, 12:42 PM   #42
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I think it was JC Meynet failed one of the way early closed decks. I know Jeff and Matt have been super happy beating on their newer version blocks.
Old 08-04-2014, 01:02 PM   #43
actACCORDingly
Member#: 347086
Ok guys, oil feed and return for the turbo, I know someone has done them with a precision turbo. What do I need. Also should I hook up the water lines? Anyone have pics of their setups with what they used to make it work? Thanks.
On a side note. Travis from soulless will be tuning the car, can't wait to see him work his magic. I contacted out front about the closed deck block, just waiting to hear back. The twin disk should either be shipping or here tomorrow; I forgot which it was. 2200cc injectors will be here soon as well thanks to Bruce at fiveomotorsport. Heads are off to getting ported on Tuesday. I'm going to build a double pumper with 2x walbro 450lph's so it's not going to run out of fuel on the dyno and I'm not kicking myself in the ass for not making power due to lack of fuel. I have everything drawn out, (rough summary) gona hook up a 40a relay to factory fuel pump power wire and run 10awg or 8awg to the tank. That way it's still hard wired and the pumps will work like stock. Not sure if that's how travis told me how to do it or not. If so I'm not going to take any credit from him.
actACCORDingly is offline   Reply With Quote
Old 08-04-2014, 01:57 PM   #44
bebesito21
Member#: 176128
5862 ...baby boosted
Originally Posted by actACCORDingly View Post
already have a 6266. got it for $750. lets see you find a 6466 for anywhere near that price.
i probably could get pretty close, some of us can get great prices...but thats neither here nor there. the point was that to make that power, its easier with a bigger turbo (less boost) and its totally possible for the car to drive nicely around town with a 6466 while still meeting your goals. can you even make your goals with the 6266?? its ~74lb per minute....cutting it close no?
I understand that if you want to play big, you have to pay big. It's not my car, I'm just picking the parts and putting it together. A 6266 was in his budget and the 6466 wasn't. This car was supposed to have a built bottom end, stock heads, and a green originally. When we realized it dropped a valve we decided to build the new heads. The build escalated really quickly after that. Speaking of playing big, my personal car is a terminator cobra with a lsx swap, th400, and a borg warner 91mm. In retrospect, you should be trying to play big
LOL @ having a budget on an "at least 700whp" daily driver....why not go for 800whp. smh
bebesito21 is offline   Reply With Quote
Old 08-05-2014, 09:57 AM   #45
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Good choice!
wgr73 is offline   Reply With Quote
Old 08-05-2014, 06:18 PM   #46
actACCORDingly
Member#: 347086
Originally Posted by wgr73 View Post
Good choice!
I think so as well!
It is a street car, faster spool with the 6266. That's why. Not going to make as much power, it's going to run hotter, but it's what the owner wants.
Intercooler came in today.
Old 08-05-2014, 06:49 PM   #47
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Treadstone?
Z0rr0 is offline   Reply With Quote
Old 08-05-2014, 06:56 PM   #48
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Thanks! I cannot wait to see the build in person.
I don't want to bash any product, so i'll say this: I have had much better luck with Injector Dynamics injectors. I feel they are worth the money.
Sounds about right. Each of those pumps will take up to 20 amps at full tilt.. so might want to have 2 relays, one for each. We can also have a hobbs switch that kicks the 2nd pump on once we reach a certain boost..
Old 08-05-2014, 08:01 PM   #49
actACCORDingly
Member#: 347086
Paul's injectors are second to none. I'd use his injectors in every application if I could. Yes, it is a treadstone intercooler.
Old 08-05-2014, 09:01 PM   #50
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by besthaticouldo View Post
I've never understood balancing to a clutch and flywheel assembly. That seems absolutely stupid. What happens if you change clutch, then everything is off.
Also, this seems like a really bad idea for a daily.
I agree with above for a closed deck block instead of sleeves.
Easy, don't change clutches. Pick the right on the first time and when the time comes just resurface the flywheel and PP and replace the clutch disc. Index everything and 're-install the same as you removed it.
