Old 06-20-2014, 07:16 AM   #126
2slofouru
Member#: 90539
95 340whp impreza
05 Raven R6, 07 2.5i
So what you're saying is that lighter oil gave you higher oil pressure?
Does this sound bass ackwards to anyone else? Not that I'm not glad you've got decent pressure, but the logic doesn't make any sense.
Seems like it would be the reverse but maybe there is another factor with the oils that isn't being considered. Either that or a bad batch of 15/40
2slofouru is offline   Reply With Quote
Old 06-20-2014, 09:31 AM   #127
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ highly improbable. Unless some one put the wrong oil in?
Old 06-20-2014, 08:01 PM   #128
2slofouru
Member#: 90539
95 340whp impreza
Maybe someone should offer to pay for him to run the 15/40 again for a short time, just to verify? Unless someone else added the oil and used 0/20 I'm not sure how he could have mistaken the oil used.
I never run shell, quaker state, royal purple, etc. I've used castrol and valvoline since my first vehicle and never have had a spun bearing or low pressure issues. Those two brands seem to have had good quality control over my driving life.
Old 06-26-2014, 09:48 AM   #129
sexyyrex
Member#: 128022
2015 Mustang GT
this. confused as well.
sexyyrex is offline   Reply With Quote
Old 06-26-2014, 06:24 PM   #130
MPS-Dom
Member#: 204421
All too often people ignore the suction pressure as a function of final oil pressure. This is due to the location of our oil pump reliefs and where they get their reference pressure.
What oil pressure does with different oils will depend on what is causing the low or high pressure in the first place. If the clearances are large, then using thinner oil would increase flow through them with a fixed supply flow resulting in lower pressure.
If the oil pressure was low due to a weak relief spring, the thicker oil would cause the relief to lift sooner due to increased suction forces (more negative pressure/vacuum). Lifting thicker and heavier oil from an oil pan creates a lower pressure at the reference point of the relief.
MPS-Dom is offline   Reply With Quote
Old 06-26-2014, 07:55 PM   #131
2slofouru
Member#: 90539
95 340whp impreza
/\ Great point, there almost always another variable that people miss or ignore.
Old 06-30-2014, 04:54 PM   #132
SuchCar_MuchPower
Member#: 387773
Glad I found this...bought a 12mm oil pump for my EJ257 rebuild....
SuchCar_MuchPower is offline   Reply With Quote
Old 08-03-2014, 03:51 PM   #133
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
I was about to, I guess I'll stick with a 10mm though.
RooTBeeRthe1st is offline   Reply With Quote
Old 09-02-2014, 02:54 AM   #134
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Since this thread is filled with about all the oiling info you will need I have another question. When you add a large oil cooler with -10 hose does that play a role oil pump size.
Sent from my iPhone using NASIOC
Murphdog is offline   Reply With Quote
Old 09-02-2014, 06:21 AM   #135
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No. From the setups we've done and recommended, the pressure drop is typically very very small if it's even gauge measurable at all. Use high quality products and you'll be fine. Also, when you add an aftermarket cooler, remove the OEM cooler. This will help you gain back some losses, and also free up a bit of cooling system capacity.
Old 09-03-2014, 04:03 PM   #136
Murphdog
Member#: 75414
2004 STi
Its the Blue one
So what tools are you guys using to port and polish your oil pumps
