Old 08-03-2014, 05:46 PM   #5126
soundbomber
Member#: 230136
soundbomber is offline   Reply With Quote
Old 08-03-2014, 06:28 PM   #5127
Oaf02Z
Member#: 263219
2010 Mugen GE8 Fit
2012 Flared STI (SOLD)
crappy instagram photos
Oaf02Z is offline   Reply With Quote
Old 08-04-2014, 12:11 PM   #5128
ryce84
Member#: 210466
2005 STI
More pics please
Originally Posted by soundbomber View Post
ryce84 is offline   Reply With Quote
Old 08-04-2014, 01:26 PM   #5129
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Sex ^
Supa LA is offline   Reply With Quote
Old 08-04-2014, 03:39 PM   #5130
Jive Turkey
Member#: 219492
Originally Posted by _adam View Post
This setup is turning out to be a pain in the ass. First I didn't have enough camber and it rubbed everywhere, now the rears have too much and the fronts still rub bad around turns, even after a decent pull front and rear.
Going to order rear camber plates so I can dial that in (I only have bolts now and it's such a pain trying to adjust) and hopefully turning up the damping will help the rubbing in the front (still 8k/6k springs). They're 18x9.5 +38 with 245/40/18 and 12mm spacers (I have ARP studs and my lugs won't tighten without the spacers).
barnburner was 18x9.5 +38 (WITH spacers) with a 265/35 MPSS and didn't rub. pretty sure he had stiffer rates than you. make sure all 4 corners are rolled flat!
Jive Turkey is offline   Reply With Quote
Old 08-04-2014, 04:00 PM   #5131
avidworks
Member#: 144415
They're rolled and we pulled the fronts and rears a decent amount. I think the 40 sidewall is most of the issue (half inch taller than a 35). I'm going to pop the front wheels off and beat the hell out of the inner tubs. I think it's rubbing more on the inside than the outside. Also going to turn up the front damping.
Here's a non cell phone picture...
DSC_4068 by AVIDWORKS, on Flickr
avidworks is offline   Reply With Quote
Old 08-04-2014, 05:37 PM   #5132
Wirtz
Member#: 286408
WFC #952
Function:error!
The 40 series is your issue hands down. Swap to a 35 series and enjoy
Also I'm surprised you're not at full stiff for dampening already. That will help a lot
Wirtz is offline   Reply With Quote
Old 08-04-2014, 08:19 PM   #5133
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
I don't get what's going on here. This is a simple setup to fit. The 40series is fine I run a 215/40/18 on a 18x9.5 +13 and I tuck to rim lip no issue. Also yes go full stiff that will help. Rolled pulled fenders, more camber and rip out the fender lines. Also you can tub with a hammer and torch I did this too but you don't look low enough to be rubbing in there yet. Just add some camber and call it a day. Easy fix
under0athh51189 is offline   Reply With Quote
Old 08-04-2014, 08:50 PM   #5134
avidworks
Member#: 144415
You're running a 215/40. I'm running a 245/40 and likely a bit less camber (my coils are maxed but I don't have front camber bolts) so there's a lot more tire to hit things...
I pulled the front wheel off. It's obviously rubbing bad here as the metal is freshly polished. The fender itself looks fine.
I hammered there and behind the fender liner there (there were rub marks too) as much as I could, but I'm probably going to go back and hit it again when I have access to a heat source.
I was also 9 clicks from full stiff. I put it 3 from full stiff for now, we'll see how that does.
Old 08-04-2014, 11:43 PM   #5135
under0athh51189
Member#: 193959
2001 Lexus IS300
Just go full stiff..and even with your tire size your fine. I could still tuck hard. And you don't need front camber bolts you have stock ones and should have front camber bolts. Im running -5.5 front camber and -6.8 rear
Old 08-05-2014, 01:22 PM   #5136
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Here's a quick cellphone shot. Still needing a slight adjustment, but you get the idea.
Old 08-05-2014, 01:58 PM   #5137
besthaticouldo
Member#: 279660
IMG_8846 by b3sthaticould0, on Flickr
Wheels and suspension for sale.
besthaticouldo is offline   Reply With Quote
Old 08-05-2014, 07:04 PM   #5138
Chasewrx
Member#: 290616
I'm ready for a new set of wheels, and will be selling these soon. Someone send me a PM if interested, Work Meister S1 3P BBF 4.5" rear lips, clears BBK 5x114.3. PERFECT fitment. Took home Best Stance from Stance Nation at Blox Evolution a couple weeks ago with these wheels.
Have the original boxes and all packaging to ship.
Chasewrx is offline   Reply With Quote
Old 08-05-2014, 09:14 PM   #5139
Oaf02Z
Member#: 263219
2010 Mugen GE8 Fit
what are the actual specs on them?
Old 08-07-2014, 01:11 PM   #5140
05Massacre
Member#: 149178
2005 WRX v7 STi swap
Blue WFC #231
Just going to leave this here.
05Massacre is offline   Reply With Quote
Old 08-07-2014, 01:13 PM   #5141
thxem
Member#: 393790
2013 WRX
Ice Silver Metallic
Those wheels :hearteyes:
thxem is offline   Reply With Quote
Old 08-08-2014, 09:44 AM   #5142
avidworks
Member#: 144415
Hammering and stiffening the coils helped a ton. The only time I rubbed yesterday was on the bottom of the fender if I'm turning on an incline... which isn't that much of a bother.
I do need to pull a little camber out of the rear, though... what did you guys do about trimming the lip on the inner part of the rear bumper? The plastic should be easy enough to cut, but there's a metal bracket behind that. Did you just take it out?
Old 08-08-2014, 09:55 AM   #5143
Silver Sedan
Member#: 259220
2005 RWD STi
Silver Sedan is offline   Reply With Quote
Old 08-08-2014, 09:56 AM   #5144
GarrettKing
Member#: 234802
95 Imreza L
Glacier White
_adam your bugeye is one of the only ones I have ever liked with an STi wing on it. Looks good man. Love SBC RPF1's as well. Very nice.
GarrettKing is offline   Reply With Quote
Old 08-08-2014, 10:10 AM   #5145
avidworks
Member#: 144415
Thanks! Hopefully dialing in the alignment this weekend so I can start driving the damn thing.
Old 08-08-2014, 10:11 AM   #5146
avidworks
Member#: 144415
Originally Posted by Silver Sedan View Post
Hell yes.
Old 08-08-2014, 10:47 AM   #5147
Ultimateone
Member#: 48025
15 Mustang GT
Wheels are insane but do people look over everything else all banged up and falling off? I don't get it
Ultimateone is offline   Reply With Quote
Old 08-08-2014, 01:45 PM   #5148
05Massacre
Member#: 149178
Blue WFC #231
nah not really. i usually get "oh what happened there?" im buying a new bumper soon because this one has been through hell and will just be the winter beater one. my splitter got trashed when i ripped my lip off and it came back and rubbed on the tire on the highway. skirts, you can thank new york roads for that one haha. but he what can you do when you are hammered on 17s and still daily drive it normal. ****s bound to get ****ed. car wont stay like this too much longer hopefully. its been on the ground for awhile now. plan on a rwd swap and drifting it next year.
Old 08-08-2014, 01:45 PM   #5149
05Massacre
Member#: 149178
Blue WFC #231
hi kyle!!
Old 08-08-2014, 02:00 PM   #5150
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
Shipman is offline   Reply With Quote
The "My Lunch Could Beat Up Your Lunch" Thread markman Off-Topic 780 08-01-2016 01:55 PM
Pare it down or beef it up? AVANTI R5 Non-Subaru News & Rumors 2 05-03-2012 02:01 PM
B6D Wrap It Up and Photo Thread I25 Off-Topic 1051 07-06-2010 02:50 PM
Is it bump your own thread day... allanak Off-Topic 12 02-11-2009 05:29 PM
Post pics of Rota Attacks on your WRX Here! wrx.jeus Brakes, Steering & Suspension 1 09-04-2002 02:20 PM
