Old 06-07-2014, 10:04 PM   #426
mcdrama
Member#: 85083
2015 WRX Premium
World Rally Blue Pearl
Has anyone tried this mod with the 2015 WRX?
The stock lights on the 2015 WRX are considerably better than the stock lights were on my 2004 WRX. I would still love to have HIDs.
mcdrama is offline   Reply With Quote
Old 06-08-2014, 11:42 AM   #427
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
It will work on any car accepting H9s - and in this case it's ~500 more raw lumens of light. You can't beat physics
As a side note, one has to remember when considering bulb upgrades is that at the, end it is (pretty much) only lumens that count. Allt he hypergigawhite 100W=10W, often seen in advertising, POS bulbs is total bovine excrement. If you can't find the output in lumens, don't buy.
As for LEDs - they're still far from matching the output of fully blown halogen headlamp bulb filaments (asides from dedicated LED lamps which often use an array of LEDs). Not to mention that since many LEDs are used on one "bulb", the beam pattern becomes completely coo coo, if you do a direct replacement.
Old 08-05-2014, 02:17 PM   #428
wrxnh
Member#: 393998
/// WRx ///
Oh thank goodness for Google I found this...just bought stock Philips H9 on Amazon, going to make this a WEEKEND PROJECT
No seriously, my dash cam would also love the much needed light output. Until I can afford a $500+ retrofit project this will do...
wrxnh is offline   Reply With Quote
Old 08-05-2014, 04:25 PM   #429
WilR
Member#: 343078
2013 WRX Hatchback
Retrofit can be done for considerably less if you learn to shop around and can do the work yourself.
Sent from my SCH-I535 using NASIOC mobile app
WilR is offline   Reply With Quote
Old 08-05-2014, 10:39 PM   #430
wrxnh
Member#: 393998
/// WRx ///
Ya I've done retro's in the past but finding the time to do it is another matter.
Do you or someone know other plug & play HID projector other than the Mini D2S that TRS has that won't require cutting? I know they're okay but was hoping to fit something else...
Old 08-06-2014, 08:28 AM   #431
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Any projector from an 06-14 STi will work. Bolts right up.
bicycle_wreck is offline   Reply With Quote
Old 08-06-2014, 08:41 AM   #432
wrxnh
Member#: 393998
/// WRx ///
Nice! Now if I can find them for cheaper
Old 08-06-2014, 09:50 AM   #433
wrxnh
Member#: 393998
/// WRx ///
n/m...I guess if I go with mini D2S and a kit from TRS.
Old 08-10-2014, 11:59 PM   #434
wrxnh
Member#: 393998
/// WRx ///
Here's the result! First night I realized that the metal tab on the H9 needed to be shaved off (which I didn't realize until today). Easy 30 second tweak and took the photos. I did meter the lighting to the stock H11, ISO800 0.3" f5.6 custom white balance to somewhat match the actual light output color and took the second shot with the H9. No post processing adjustments so it's fairly accurate.
Right away I noticed a difference in the driveway I was happy
Philips H11
Philips H9
Old 08-11-2014, 09:30 AM   #435
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Nice pictures, did you leave the fogs on in the first pic or is there that much difference in the beam between the two bulbs? I am talking about all the foreground light in the first pic.
Sent from my iPhone using NASIOC
frederik is offline   Reply With Quote
Old 08-11-2014, 10:43 AM   #436
wrxnh
Member#: 393998
/// WRx ///
Good question actually; more than likely I left it on now that I think about it
Made a video last night as well on the better night time recording on the dash cam.
Old 08-11-2014, 11:43 AM   #437
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Philips H11
[IMG]http:jpg[/IMG]
Philips H9
[IMG]http:af.jpg[/IMG]
Great pic but too bad you left fog lights on in H11 pic pic and turned them off in the H9 pic. That's the only thing that messes up the pic.
If not for that it would be the best pic I have seen of the comparison between the tow different bulbs and it is exactly what I see in my experience. At a quick glance other people might argue that the H9 isn't that much better because the fog lights skew the results.
I've been running H9 only for years now. Great conversion. I even bought an adapter so the next time one burns out, I do not have to file anything down. I filed down the part in the adapter instead.
BWX is offline   Reply With Quote
Old 08-11-2014, 11:47 AM   #438
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Default H11 to H9 conversion. DIY with temps
The fogs on are a bit confusing at first but if you ignore the foreground you can still clearly see the difference where the low beam actually is, quite a bit further than where the fogs are. You could probably trim the two pics to remove the foreground, only keep the upper part of each pic and it would be even clearer.
Old 08-11-2014, 11:59 AM   #439
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I hope you dont mind I just quickly edited the pics to crop out the foreground area to show what I meant:
Old 08-11-2014, 02:12 PM   #440
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah you can definitely ignore the fogs in the one pic..
It just throws off the results a little. I think the difference would be even more dramatic w/o the fogs in the one pic..
Old 08-11-2014, 02:34 PM   #441
wrxnh
Member#: 393998
/// WRx ///
Actually H11 was taken the night before until I realized why the H9 didn't fit properly but did record the setting for the H9 shot.
I can try to do an overhead shot from middle of the car next time.
There's an old empty lot not far from me so I'll probably shoot there. That should give people better idea on the spread as well.
Old 08-11-2014, 03:02 PM   #442
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
Quick question; how old were the H11's?
Tha Chakal is offline   Reply With Quote
Old 08-11-2014, 05:42 PM   #443
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
That'll be cool.
That location you shot in already is really good though. You can compare a lot of the things off to the side like the pole, and grass, the concrete curb thing sticking up, even the tar stips on the road.
Would be hard to beat that. It is "real world" use too.
Old 08-12-2014, 02:04 PM   #444
wrxnh
Member#: 393998
/// WRx ///
Good question; it was in there since I bought the car. Some say it's 500 and up to 700 lumens brighter with the H9. It's VERY noticeable though either way. Haven't been flashed by any oncoming cars. YET
Originally Posted by BWX View Post
That'll be cool.
That's very true; in fact I know few roads I can do this without a lot of obstruction but with street signs and intersection. Will check that area out next.
Old 08-19-2014, 11:48 AM   #445
jboulay87
Member#: 399414
On a 2014 Wrx if I want to make the daytime running lights white light do I replace the 9005 high beam light for that?
jboulay87 is offline   Reply With Quote
Old 09-08-2014, 11:22 AM   #446
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Does anyone know if the added 10w over stock (55w vs H9's 65w) will cause issues over time with the LIN Battery Sensor in the new 15' model year subarus? It's the reason why I ripped out my HIDs today.
Robstunner is offline   Reply With Quote
Old 09-08-2014, 12:46 PM   #447
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No issues with mine and the H9 conversion is one of the first things I did when I got the car back in May.
Mulder is offline   Reply With Quote
Old 09-08-2014, 01:33 PM   #448
Robstunner
Member#: 134222
2015 WRX Limited
ISM
awesome, glad to know. Which bulbs are you running? I see the Philips OE are on sale for $9 each on amazon prime.
Old 09-08-2014, 02:02 PM   #449
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
They're either Philips or Hellas, I had them lying around as spares from the GTO.
Old 09-08-2014, 09:43 PM   #450
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
OSRAM H9 bulbs are cheap and in-stock at Auto-Zone most of the time.
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
