Old 08-10-2014, 11:14 PM   #4201
streetking
Member#: 244036
Originally Posted by Aquamist View Post
Good to know the flow map was corrupted, a new controller put right. I will confirm when I have received and tested the controller.
I am not sure what caused the WI led to come on. Try increase the FSDL a tad. It may be responding to some spiky error signals. Keep me posted on this. I cannot think of a reason why temperature may affect this.
Richard, I finally have time to look back into this problem. Now that it is summer the gauge just does it more constantly. Whenever during hotter days the w. Injection led on the gauge just lights up. When the system sprays the led would turn off but when it's done spraying the led would turn back up again. Eventually after a 15 minutes drive the problem would disappear. On cooler days it never does it
I thought bubble was building up in hot days when the car was parked but when I touched the flow sensor and turbine they aren't not even hot. They are also mounted at a well ventilated area anyway. I disconnected the 6mm line by the flow turbine thinking may be too much pressure or eventually bubble built up and caused the w. Injection light on gauge to turn on, that didn't solve the problem either. I tried increasing fsdl like you that but that also didn't resolve the problem.
I just worry that something is malfunctioning if the w. Injection light on the gauge is on now that my car is tuned for math injection. I don't want my motor to blow because of that...
streetking is online now   Reply With Quote
Old 08-11-2014, 12:24 AM   #4202
lookylookitzadam
Member#: 348254
2013 WRX
It is not true for us...
The AEM sensor is sourced from GEM sensors:
http://www.gemssensors.com/Products/...ors/Turbo-Flow
It is 95% plastic, subject to high temperature instabilities. I believe another wmi company used it and later abandoned it after a years or twos later. It is not a reliable sensor for the automotive engine bay applications.
The aquamist sensor is solely designed and manufactured by us in house. We do not supply this sensor to any other wmi makers.
That is awesome. Do you sell your flow sensors separately? If the output is a linear 5volt like the old one, I would like to use your sensor. If not , do you guys have a stand alone flow gauge?
Sent from my SM-G900T using NASIOC mobile app
lookylookitzadam is offline   Reply With Quote
Old 08-11-2014, 02:47 AM   #4203
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Please tell me your settings:
1. No of jet and sizes
2. WL, WL and SC
3. Fuel injector size
4. Thres trimmer setting
5. Gain trimmer setting
6. Flwo table.
Aquamist is offline   Reply With Quote
Old 08-11-2014, 02:50 AM   #4204
Aquamist
NASIOC Manufacturer
Member#: 110029
I just read your post on the other thread, it appeared that you have solved the heat related problem
The only thing I have concern with is the calibrations (pulses per cc etc) between the systems. We have sensor with pulse output and 0-5V output.
Old 08-11-2014, 07:50 AM   #4205
TheSTIEvery1Knows
Member#: 308132
2013 Subaru STI Ltd.
Richard pulled the flow sensor apart. Everything internally was clean and the green turbine inside flowed freely in both directions. Still have the same issue with everything together
TheSTIEvery1Knows is offline   Reply With Quote
Old 08-11-2014, 08:08 AM   #4206
streetking
Member#: 244036
2. WL, WL and SC
6. Flwo table.
1. Single 1.2mm jet by the top mount intercooler.
2. WL shows 6-7 bars max, wl at the lowest setting currently. WH at max setting.
3. 850cc injector
4. thres trimmer is at around 24% (10 o'clock)
5. Gain is 150% around 3 o'clock
6. Flow table is at default, 1x
Old 08-11-2014, 11:39 AM   #4207
omgawg
Member#: 304967
2006 frankenSTi
has anyone ran into issues with running a 3port ebcs(grimmspeed) and a hfs3 v1 system?
omgawg is offline   Reply With Quote
Old 08-11-2014, 12:04 PM   #4208
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Why would you, a BCS is a BCS is a BCS. The brand matters not.
kellygnsd is online now   Reply With Quote
Old 08-11-2014, 12:26 PM   #4209
omgawg
Member#: 304967
2006 frankenSTi
Just making sure. Got to recheck my wiring and see if my jumper is setup correctly
Old 08-11-2014, 12:37 PM   #4210
jacky599r
Member#: 137631
2006 WRX
Red
What is the size of your fuel injector?
Responding to your qns Sir, I have 4 DW 750s coupled with Walbro 255 fuel pump. I want to increase flow without altering the slope of the curve. If possible, ill like to spray as soon as possible and still have enough room at full boost.
jacky599r is offline   Reply With Quote
Old 08-11-2014, 02:31 PM   #4211
Aquamist
NASIOC Manufacturer
Member#: 110029
OK, good mechanically. Here is one more possibility, rare but has happened.
1. The wire run from the controller to the flow sensor is not shielded, if the cable is routed along side a ignition wire or the sensor is close to a device with magnets. It will interfere with the readings.
2. The plastic divider between the gold fingers of the RJ connector may be slightly bent, giving inconsistent electrical contacts.
First step, reposition the yellow harness a bit off the normal run is see what happen. Then move the FAV slight of the fire wall ledge. Make sure there isn't a wiper motor near it.
So difficult to trace an intermittent problem. This is the first time I saw the FAV placed in this position.
Old 08-11-2014, 02:35 PM   #4212
Aquamist
NASIOC Manufacturer
Member#: 110029
I believe I have already responded to your pm at the aquamist forum. To avoid CEL, you must activate the DR1 jumper. Before you do this, make sure the wiring is correct. White and brown wire the grey connector.
Post the wiring diagram you followed for the install here.
Old 08-11-2014, 02:40 PM   #4213
Aquamist
NASIOC Manufacturer
Member#: 110029
3. 850cc injector
1. Where is the SC setting?
2. Just for a quick test, Set the Threshold to 11am. Let me know.
3. Can you link the FDC (gauge is hijacked to display 0-100% FIDC) and tell me how many bars is displayed at full power.
Old 08-11-2014, 02:53 PM   #4214
Aquamist
NASIOC Manufacturer
Member#: 110029
750cc x4 = 3000cc/min. Based on M50W50 at 20% to fuel = 600cc/min.
So for DP , you divide the flow between 4x CVJ (90cc/min) jets and 1x post IC jet (300cc/min). You need to order the DP jets from me as we do not advertise smaller than 140cc.
Old 08-11-2014, 05:06 PM   #4215
omgawg
Member#: 304967
2006 frankenSTi
I used the 06 wrx on the aquamist forum- Thank you for replying this morning.
Just about to leave the shop and check my setup when I get home. Hopefully
it was a simple late night mistake and didnt look at the dr1 jumper.
Thank you for replying so quickly.
Old 08-12-2014, 12:43 PM   #4216
Aquamist
NASIOC Manufacturer
Member#: 110029
You have sorted out the safe mode connection with the CLP removed. I wasn't aware you were using both failsafe channels.
Old 08-13-2014, 02:29 PM   #4217
TheSTIEvery1Knows
Member#: 308132
I have moved the FAV valve off the fire wall and i wrapped it in fiberglass heat shield from there FAV to the firewall just for giggles. no change in intermitted operation. also double checked all connections for damage or improper connection and everything looks ok
Old 08-13-2014, 02:47 PM   #4218
Aquamist
NASIOC Manufacturer
Member#: 110029
You still experiencing the intermittent problem?
I suspect there may be some dimensional changes in the internal sensor geometry. I like to send you a new sensor core, if it works perfect, I like you to USPS the current sensor back to me to do some intensive examination. I will paypal you the postage. Pm me your address.
Old 08-13-2014, 02:58 PM   #4219
TheSTIEvery1Knows
Member#: 308132
yes same thing sometimes it works and sometimes it doesn't.
Old 08-13-2014, 05:24 PM   #4220
Aquamist
NASIOC Manufacturer
Member#: 110029
Let's go to plan B.
Old 08-13-2014, 06:15 PM   #4221
TheSTIEvery1Knows
Member#: 308132
whats plan B
Old 08-13-2014, 06:17 PM   #4222
Aquamist
NASIOC Manufacturer
Member#: 110029
swap sensor core, then USPS
Old 08-20-2014, 09:34 AM   #4223
Ronin_STi
Member#: 147969
2007 STi
I'm running Crown denatured alcohol in mine. Just pour the whole thing. Working out well for me. Anyone else use this?
Ronin_STi is offline   Reply With Quote
Old 08-21-2014, 01:11 PM   #4224
Aquamist
NASIOC Manufacturer
Member#: 110029
Just a quick market research, any feedback and impression on the 2015 wrx with DI fueling system?
Any good tunes for it?
Old 08-21-2014, 01:20 PM   #4225
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
COBB Tuning just released Beta tuning software for it this week. I imagine it will be a good 2-3 months before more is known on teh tuning side of the DI Fueling system. As with other car manufacturers that made this change (audi, etc), that the long term effect will be a positive one. It will just take a while for adaptation.
Stephen
IA Performance is offline   Reply With Quote
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 04:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
