Old 08-12-2014, 08:53 PM   #1
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Obsidian Black Pearl
Default Oil leak issues.
OK let me start this off correctly. I have an EJ22T engine in my 2004 wrx. The other day I was driving down the road and noticed I had an oil leak. I don't know how long it had leaked or the extent of the leak till I parked it (about a mile from home) I noticed I have a threaded hole about 2 inches aft go the oil pressure sensor. It is parallel to the temp sensor in the coolant crossover. It's on the passenger side of the vehicle. I was told it was an additional PCV breather that came on the ej22 blocks? I don't know. Questions are, is this true and if so it was plugged before and now it is not. Any ideas as to what would act as a good plug, being that in order for a shop to touch it they want the actual part they are installing. Any help? Insight? Knowledge to share with a friend?
Sexyrexy1990 is offline   Reply With Quote
Old 08-13-2014, 02:47 PM   #2
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
No help?
Old 08-14-2014, 01:28 AM   #3
CRX7
Member#: 31639
99 Impreza
I don't know what you're describing. There is no oil on the coolant cross over pipe. Are you talking about the oil pressure sensor. No. 1 in this pic:
http://img.photobucket.com/albums/v2...2toilplugs.jpg
also here:
http://i161.photobucket.com/albums/t...z/gallery1.jpg
CRX7 is offline   Reply With Quote
Old 08-14-2014, 02:23 AM   #4
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
It's right where that elbow is behind 1
Old 08-14-2014, 02:24 AM   #5
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
also here:
The elbow behind 1. That's the location. But I don't have any hoses or anything hanging
Old 08-14-2014, 02:43 AM   #6
mikeyc
Member#: 32338
03 WRX Wagon
Yup, the EJ22Ts had a second crank case breather hose. Here's a diagram of the original setup.
Don't know what you would use to plug it though...
mikeyc is offline   Reply With Quote
Old 08-14-2014, 06:42 PM   #7
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Now to find the part to fit so I can find a suitable plug.
Old 08-14-2014, 06:42 PM   #8
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Thanks so much that helps a ton
Old 08-14-2014, 07:21 PM   #9
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
The final question would be is this a probable spot to spew oil from. When I idled it was like a spritz that was constant. I'm assuming if it had a breather it was very similar to valve designed to release pressure and recycle the oil elsewhere. (forgive my for my ignorance)
Old 08-15-2014, 01:40 AM   #10
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
I've read where some people are using freeze plugs to plug it and that's what I've been. Told was in there originally (when it was built) anyone have any guidance as to what size? I am needing to get my car back on the road and need to get a part to plug it or else it'll spew all my oil again
Old 08-15-2014, 07:36 PM   #11
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Bump for answers
Old 08-16-2014, 02:39 PM   #12
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Maybe tap it and put a plug in it?
Old 08-16-2014, 02:40 PM   #13
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Assuming that it isn't already threaded.... (looks threaded to me)
Old 08-17-2014, 01:43 PM   #14
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Bump bump
Old 08-19-2014, 11:53 PM   #15
CRX7
Member#: 31639
99 Impreza
Plug = Go to the hardware/autoparts store and find something the right size. You can either jam something rubber in the exiting hole, or fit an appropriately sized hose over the port and plug the hose with something metal or plastic.
