Old 08-10-2014, 06:37 PM   #1
gettle70
Member#: 312825
2011 Impreza 2.5i
blue
Default Sound deadening
What have you guys used for sound deadening I know there is dynomat and fatmat and others have used rolled roofing. What other possible off brand sound deadening material is out there that works and is at a reasonable price. Thanks in advanced.
gettle70 is offline   Reply With Quote
Old 08-10-2014, 06:48 PM   #2
bobditts
Member#: 392683
2014 LS hatch
quartz blue
bobditts is offline   Reply With Quote
Old 08-10-2014, 11:30 PM   #3
chithead
Member#: 312018
2014 WRX Hatch
Second that ^^^ Used it in three vehicles now with ZERO complaints.
chithead is offline   Reply With Quote
Old 08-12-2014, 01:38 PM   #4
wrxXeN
Member#: 164696
2008 WRX
Lightning Red
I used these guys and their product worked well:
http://www.raamaudio.com/
though they're not quite as cheap as they used to be. I did an install in my '08 about 6 years ago and has held up perfectly. Just had my doors apart a couple weeks ago to upgrade the front speakers and it looked the same as the first day I did it.
-SJ
wrxXeN is offline   Reply With Quote
Old 08-12-2014, 02:11 PM   #5
silvercookie
Member#: 180033
2005 WRX
there is this stuff called zilla mat on ebay. its $100 for 50 sq ft or something like that.
silvercookie is offline   Reply With Quote
Old 08-12-2014, 02:47 PM   #6
bobditts
Member#: 392683
2014 LS hatch
quartz blue
whichever brand you go with... PLEASE dont just go with the cheapest. You really do get what you pay for in most cases. Do your research and choose wisely. Lots of good products out there but there are also lots of products that are just a waste of money.
Old 08-12-2014, 03:46 PM   #7
REX265
Member#: 220084
2009 WRX 265
Spark Silver Metalic
http://www.b-quiet.com/
I used this stuff on my 71 VW Westy and the difference was amazing. Before doing this, while on the road I could barely have a conversation with my g/f. After covering the entire interior paneling with Bquiet it really decreased road, engine, and exhaust noises. Now I can actually talk and have a conversation with passengers in the back no problem.
Highly recommend from personal experience with this stuff. Price is pretty decent if you ask me. I will likely be doing my suby with this stuff to try and eliminate added NHV from poly bushings, group-N mounts, etc.
Cheers,
REX265 is offline   Reply With Quote
Old 08-12-2014, 09:17 PM   #8
El Wray
Member#: 303030
2009 STI
+1 vote for stinger road kill.
El Wray is offline   Reply With Quote
Old 08-13-2014, 12:52 PM   #9
maximus_prime
Member#: 398912
2014 wrx base
wrb
I used second skin in my last car. far superior to dynamat I used dynamat on my trunk didnt do much if anything.
maximus_prime is offline   Reply With Quote
Old 08-13-2014, 04:43 PM   #10
GSXpress
Member#: 95825
2011 WRX Hatch
Originally Posted by bobditts View Post
That's what I used for my project.
GSXpress is offline   Reply With Quote
Old 08-15-2014, 09:46 AM   #11
scoe141
Member#: 357467
2014 WRX
I used a combination of CLD tiles from http://www.sounddeadenershowdown.com/. A 10"x10" or (12"x12") of Dynamat for behind the speakers and then some HVAC insulation material. The Dynamat I bought from Amazon and HVAC material from Home Depot.
I basically mixed and matched from several sites including http://www.sounddeadenershowdown.com/how-tos.
Good luck and keep us posted.
EDIT**
Here's a link I posted a while back. It touches briefly upon the sound deadening materials I used. (As well as the background/organization of the install process.)
scoe141 is offline   Reply With Quote
Old 08-16-2014, 09:52 AM   #12
scoe141
Member#: 357467
2014 WRX
Sorry, here's the link I meant to add to my other post.
http://forums.nasioc.com/forums/show....php?t=2574815
Old 08-16-2014, 01:33 PM   #13
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
when deadening the key is to use the right product to get the end result you want.
If you want Mercedes/BMW "thud" when you close the doors, then you want MASS, aka peel-n-stick tiles. Do a checkerboard and save yourself the $$ you don't need 100% coverage. 100% coverage will be fine, but not absolutely necessary. On the roof of my '04 WRX Wagon, I did 100% and the rest of the floor, doors etc I did a 6" x 6" tile checkerboard on everything. Taking a 12" x 12" tile cutting it into 4 squares. Been doing this for 15+ years and impossible to count # of cars.
Next is the Mass-Loaded Vinyl Barrier. MLVB is basically a non-adhisve backed heavy foam with a vinyl final layer. THIS is your road noise killer. Wheel wells, outer door skins, trunk / lift gates etc. If I could find a MLVB that was adhesive backed like peel-n-stick I would put it on the roof for sure. Since out cars have a board-backed head liner you use CC (see below) spray glued tot he back of the headliner board instead.
Next is the Closed Cell Foam (CCF)which is your road noise/rattle initial barrier.
'showdown has some good hints and information. The original site was TONS more informative. But once he went into business selling product the content has suffered tremendously.
If you REALLY want to go crazy, spray on deadeners for the insides of the wheel wells, and over checkerboard peel-n-stick has proven effective and weight conscious for Jeep owners.
Just depends on what your expectations and concerns are. attack them head on with the correct product.
~R.
TXwrxWagon is offline   Reply With Quote
