Old 08-12-2014, 10:47 AM   #776
Kmir
Member#: 398843
Default Photoshop please
Could someone please photoshop these on a white WRX please? my skills are severely lacking. Thanks! They are the Forged Niche Invert H73.
Here's my attempt. What do you guys think (I know it needs to be lowered)?
Kmir is offline   Reply With Quote
Old 08-12-2014, 07:51 PM   #777
802Shaun
Member#: 397547
2015 WRX
Question Enkei TSP6: Offsets 35, 45, and 50
I'm strongly considering copying Bellipotens and going with Enkei TSP6. I would be wrapping them in 235/40-18 Michelin Pilot Super Sport tires and will leave the car at stock height. It seems I have four options:
18x8 +35
18x8 +45
18x8.5 +35
18x8.5 +50
I love the way the +35 offset looks with the 235 tire, but am concerned about the steering feel vs the offsets that are closer to the stock value of +55.
Which size/offset would you choose?
Will +35 rub since Pilot Super Sports are said to run wide?
For those that have experience with the stock offset vs an offset like +35 or lower, how does handling compare?
802Shaun is offline   Reply With Quote
Old 08-12-2014, 07:57 PM   #778
quantum13
Member#: 389143
2015 WRX Limited
18x8 +45 is what i'm running and it's what i'd suggest. good size, not too wide. tires are more affordable in this size range; it's basically the same as the stock wheel diameter w/ 235/40/18 as you suggest
18.8.5 +50 probably would be a good choice too but you'd lose some of the curb protection running a 235 on the slightly wider rim; it would probably look great tho. 245 is well suited to that rim size but your speedo would be off by 1.6% or something like that
+35 should not rub, esp if you're not doing a drop.
+45/50 is closest to stock and will change your suspension geometry the least; id stick with those offsets if possible; 18x8.5 ET 50 is quite close to stock; its only 5mm different from the stock STI setup
quantum13 is offline   Reply With Quote
Old 08-12-2014, 09:14 PM   #779
pwong26
Member#: 386021
I'm interested in the Enkei RPF1 18's and will not be changing the stock suspension. What's the best option if I do not want any rubbing or fender rolling?
I saw from previous pages that RaceComp Engineering had 18x9.5 +45 with 265/35 tires. Is this the best option? Or should something more conservative be used for what I'm after? I do like the flush look but not at the sacrifice of functionality.
pwong26 is offline   Reply With Quote
Old 08-12-2014, 09:23 PM   #780
Biomusic74
Member#: 398020
15 WRX
Dark Grey
http://www.tirerack.com/wheels/Wheel...sort=DiscountR
Sent from my SM-G900T using NASIOC mobile app
Biomusic74 is offline   Reply With Quote
Old 08-12-2014, 09:24 PM   #781
Biomusic74
Member#: 398020
15 WRX
Dark Grey
I'm planning on getting these rims. What do you think? Also with the tires I would get extreme continental dws. Would these match up clean on Grey 15 wrx?
Old 08-12-2014, 09:38 PM   #782
Nmullin11
Member#: 353683
2015 Wrx limited
Wrb
Originally Posted by x SLYC x View Post
Thought the same thing myself. Might as well save up a little more and BAM, helluvalot nicer wheels that the stock ones
I got a set of four 20mm for 120 in the classifieds to hold me over until I at least go through these dunlops.
Lowering springs going in this weekend.
Sent from my iPhone using NASIOC
Nmullin11 is offline   Reply With Quote
Old 08-12-2014, 09:47 PM   #783
x SLYC x
Member#: 392588
2015 WRX Premium
CWP
You get the RS-R springs?
x SLYC x is offline   Reply With Quote
Old 08-12-2014, 10:40 PM   #784
jjablo6
Member#: 265697
2015 STi
Ligtening Red
i did this reaalllllyy fast for you so you can get an idea lol.. not really a fan. thanks rallysportdirect for the pic
jjablo6 is offline   Reply With Quote
Old 08-13-2014, 12:14 AM   #785
802Shaun
Member#: 397547
2015 WRX
Yeah, I feel like 18x8.5 +50 is what I *should* go with, but I'm tempted to go with +35 for the look. I'd love to hear from others in regards to the handling difference between the two.
Old 08-13-2014, 01:55 PM   #786
MRREX71
Member#: 381862
I have an ISM WRX. Living in Canada, I will be using the factory rims for winter and getting new rims for the summer. Likely Nurburgrings. As such, I have been checking in on this thread regularly. The question above about 235/40 18 vs 245/40 18 is something I was wondering about too. I note Tirerack recommends 235/40 18 as the go to size in 18s for the WRX. But isn't the factory size tire for an STI 245/40 18? If so, does that mean that the speedo for the WRX is set up differently than on the STI?
MRREX71 is offline   Reply With Quote
Old 08-13-2014, 03:21 PM   #787
Biomusic74
Member#: 398020
15 WRX
Dark Grey
That's what I was reading about and was a bit curious. Maybe I should I call subaru about that. Because like I said bout to order 235/40/18..
Old 08-13-2014, 04:54 PM   #788
kbeau
Member#: 331992
2015 WRX Limited 6mt
Ice Silver Metallic
Default Ra Flaps
Just installed RA mud flaps... they look amazing and don't question it.. just do it. They look 200% better on the 2015 then the 2012
kbeau is offline   Reply With Quote
Old 08-14-2014, 01:09 AM   #789
quantum13
Member#: 389143
2015 WRX Limited
based on the different tire sizes (not to mention the fact that the cars come w/ different wheels), i'd assume that yes, the cars are going to be different. shouldn't be too much of a surprise; the cars are alike in look but have different engine, transmission, suspension parts - even a different center console. given that the vehicle has the advanced controllable differential as well, it doesn't seem all that odd to me that the car's computers would be set up to accommodate a different size wheel.
Old 08-14-2014, 01:11 AM   #790
quantum13
Member#: 389143
2015 WRX Limited
it is very unlikely they will have anything to say about this topic; order w/o any hesitation; that's the ideal size for an 8" rim
Old 08-16-2014, 08:15 AM   #791
Crazy_Diamond
Member#: 230269
2015 WRX Limited
Lightning Red
How come I can't find this vendor (Heuberger) on eBay anymore? They had listed a black set of 18x8.5 ET 55 "STI special edition spec C" wheels I wanted for my red 2015 WRX.
Crazy_Diamond is offline   Reply With Quote
Old 08-16-2014, 02:45 PM   #792
Canon
Member#: 386402
2015 WRX
I just bought work Kiwamis for my wrx. They're 18x8.5 +47. What size tire should I be looking for?
Canon is offline   Reply With Quote
Old 08-16-2014, 02:57 PM   #793
silverf0x
Member#: 147664
2015 WRX Limited
235/245 would fit best
silverf0x is offline   Reply With Quote
Old 08-16-2014, 03:34 PM   #794
Canon
Member#: 386402
2015 WRX
What about sidewall height? Also if the wheels were mounted and balanced to a '13 sti, should I have them rebalanced for my car?
Old 08-16-2014, 04:00 PM   #795
Spider96
Member#: 156059
2015 WRX
Crystal White Pearl
I still see them listed...
Spider96 is offline   Reply With Quote
Old 08-16-2014, 04:20 PM   #796
silverf0x
Member#: 147664
2015 WRX Limited
I personally use 245/40 on 9"
Old 08-16-2014, 05:45 PM   #797
masosoup
Member#: 396737
2015 WRX Limited
CWP
Found these for you:
http://m.ebay.com/itm/131269776560?nav=SEARCH
That also had the gunmetal ones
masosoup is offline   Reply With Quote
Old 08-16-2014, 09:54 PM   #798
Crazy_Diamond
Member#: 230269
2015 WRX Limited
Lightning Red
Yes, these are the wheels I had seen. Thanks. Can someone photoshop these on red WRX? Anyone know how much each wheel weighs?
Old 08-16-2014, 10:31 PM   #799
quantum13
Member#: 389143
2015 WRX Limited
no. balancing has nothing to do with the car it's mounted on. balancing is per-wheel and makes sure there are no heavy spots in the wheel. a balanced wheel is a balanced wheel no matter where you mount it.
as for figuring out things like sidewall height, use www.willtheyfit.com and compare the stock overall diameter to whatever you're looking to do; ideally the diameter of the wheel is similar to the wheel you're replacing
Old 08-16-2014, 11:11 PM   #800
Junon
Member#: 389997
2015 WRX STi
http://forums.nasioc.com/forums/show....php?t=2639411
I tried browingfor a similar setup, and I'm pretty ignorant with wheel/ tire sizing. Would these fit a 15 on stock suspension?
Junon is offline   Reply With Quote
