Old 02-28-2014, 09:08 PM   #551
loboilermaker
Member#: 380420
2014 WRX
Ice Silver
Pro tune catted invidia down pipe. I am in Houston.
loboilermaker is offline   Reply With Quote
Old 02-28-2014, 09:16 PM   #552
rexblake
Member#: 178426
2010 S4
Gray
Originally Posted by WhatsASubie View Post
does catless or catted matter?
I know people say catless makes more power, is it a lot more?
Yeah, it doesn't make much of a difference, maybe 5-10whp.
rexblake is online now   Reply With Quote
Old 03-01-2014, 12:31 AM   #553
thenewrick
Member#: 240649
2004 WRX STi
My advice if you want real power real cheap is this:
1- find out if you can get e85 regularly in your area, if so you're golden. Injectors, pump and a tune will get you more power than you can handle on the road for under a grand.
2- if you can't get e85 and still want stupid power you'll need a turbo upgrade. This means injectors, inter cooler, downpipes a turbo and a tune. This will cost about 3 grand.
You'll need a couple minor little bits like boost controllers but that's the simple, "get stupid power you'll never really use on the road" guide.
thenewrick is offline   Reply With Quote
Old 03-01-2014, 12:49 AM   #554
07STifastashell
Member#: 291793
2007 STi Dom built
*sold*
Originally Posted by rexblake View Post
Buy a different car. You are looking at 40-60k in mods and questionable reliability.
I've seen a build hit that horsepower for about $30-35k. You will need a fully built block, upgraded/modified heads, modified intake and exhaust valves, rotated gt35r, fmic, injectors, fuel pump, fuel rail top feed conversation, etc. As far as reliability is concerned, just because you're making huge power doesn't mean it can't be reliable... To a certain extent. Contact Maxwell Power Services if you want the best built blocks.
07STifastashell is offline   Reply With Quote
Old 03-01-2014, 01:20 AM   #555
rexblake
Member#: 178426
2010 S4
Gray
I still say it will be more than that. Regardless, I have yet to see anything in that power range that would be considered "reliable".
Old 03-01-2014, 10:10 PM   #556
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Werd. When my old STi blew a tuner offered to 'build' it. I'm glad I didn't do it now... whole nother can of worms unless you've got deep pockets.
joek92 is offline   Reply With Quote
Old 03-27-2014, 04:46 AM   #557
RavingLunatic
Member#: 76673
2006 Impreza WRX STi
Crystal Grey Metallic
What do you think I will hit when I finally get on the Dyno (mustang).
MY06 STi
KS Tech 83mm Type 2
Perrin 3in Turbo Inlet
FP Green HTA Turbo
Process West Intercooler w/splitter
Cobb BPV
TGV Deletes
GrimmSpeed Phenolic Spacers 8mm
DW300 Fuel Pump
Aeromotive Fuel Pressure Regular
Stainless Steel Fuel lines w/-6 AN Fittings
ID 1000cc Fuel Injector Kit (Top Feed Conversion)
Misimoto Radiator
RallySpec Block with forged pistons and rods
11mm Oil Pump
Gates Timing Kit
Group N Mounts (ENG/TRANS)
Pitch Stop
GrimmSpeed Up-Pipe
Tial 38mm External Wastegate
Turbo XS Turbo Back Exhaust (high flow cat)
Stainless Steel Clutch and Brake Lines
GrimmSpeed EBC
Car is getting suspension mods at the moment, but what am I missing. I would like to be around the 400hp level safely. What do you think?
RavingLunatic is offline   Reply With Quote
Old 04-06-2014, 06:36 PM   #558
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
We don't guess dyno numbers.
Old 04-06-2014, 11:12 PM   #559
RavingLunatic
Member#: 76673
I will post it when I get it. And the thread title implies that you do guess
Old 04-14-2014, 09:35 PM   #560
Mason_sti
Member#: 387778
2007 Wrx STi
Great post!
Mason_sti is offline   Reply With Quote
Old 05-04-2014, 02:54 PM   #561
Nasastrums
Member#: 389887
2013 Sti
ISM
Great Post
Nasastrums is offline   Reply With Quote
Old 05-07-2014, 03:35 PM   #562
TurBaja05
Member#: 360425
2005 baja turbo
Below you see what i have already: the shop i bought the car from said it makes 300hp at the crank on pro-street tune with 1.5 psi over stock. Could this be an accurate number?
What would i need to do to get 300-330 hp at the wheels?
Located DFW Texas
93 pump gas
mustang dyno
2005 subaru baja Turbo Ej255 automatic
cobb intake and MAF
no cats
up-pipe
downpipe
turbo is aftermarket without but looks stock size.
sti injectors
some type of upgraded oil pump (i'll have to check the spec sheet)
hardened crossdrilled crank
arp headstuds
sti heads
sti rods
sti lifters
sti injectors
car runs quick but would love a little more out of it. i hear the auto-tranny is reliable to 400hp
my thoughts are i will need a bigger turbo (blouch td05 18g or td05 20g-xt), fmic and a re-tune.
TurBaja05 is offline   Reply With Quote
Old 08-17-2014, 03:58 PM   #563
radominguez2
Member#: 399254
Nice
Sent from my HTC6525LVW using NASIOC mobile app
radominguez2 is offline   Reply With Quote
Old 10-24-2014, 08:03 PM   #564
NickM95
Member#: 404723
2002 WRX STi
Wow. Answered so many questions I didn't even know I had questions about haha
That's some really great info. I'll be sure to take that into account!
NickM95 is offline   Reply With Quote
Old 11-10-2014, 12:10 AM   #565
gfdbcvbc
Member#: 405947
I'll put it up for a little while.
gfdbcvbc is offline   Reply With Quote
Old 11-16-2014, 12:15 AM   #566
fdsdsgf
Member#: 406417
Now I know what I can take note of when I consider my goals for the future.
fdsdsgf is offline   Reply With Quote
Old 11-16-2014, 06:24 AM   #567
imjohn_subaru
Member#: 399228
Default what im looking for on a dyno
I want to reach 300 hp at the crank
im shooting for 300 hp on a dyno jet
3. Its in Kansas city don't know the name of the shop the guy I bought my Subaru from he take all of his subarus there and he told me they will take care of me
4. I live in Kansas city MO If
5. I will be using 93 octane (octane level)
MOD list:
3' catback exaust
STI uppipe downpipe
exedy clutch
kartboy short shifter
perrin short ram intake
imjohn_subaru is offline   Reply With Quote
Old 11-16-2014, 06:52 AM   #568
maximus_prime
Member#: 398912
2014 wrx base
wrb
Car is stock 2014 WRX gonna spoil her for Christmas.
1. I want to reach 350 WTQ 350 WHP
2. Dynajet not 100%
3.yimisport
4. I live in Southern California dyno is at sea level
5. E85- 91
6. I'm brand new to modding so I will be listening to my tuner. I'm all about that early spool (at the moment)
Thanks for the help in advance
maximus_prime is offline   Reply With Quote
Old 01-07-2015, 03:22 AM   #569
kalpalsti
Member#: 410265
Hey new here.
Looking for some opinions.
2006 sti
1. I'd like to hopefully hit 320 whp.
2. Mustang dyno
3. Good speed phx az. Clark tuner
4. Phoenix AZ sea level
5. 91 octane (az, cal, NV **** gas)
Mods are as followed
Cobb intake and box
No name turbo inlet
Invidia divorced waste gate DP no cat
Invidia exhaust race series no cats
Perrin up pipe
Mishimoto 3 core radiator
Mishimoto intercooler hose kit
Turbo smart recirculating bov
Grimmspeed boost solinoid
Fuel pressure regulator
Accessport v3
Ptp turbo blanky
Cobb heat shield
Stock top mount
Stock turbo and injectors.
Walbro 255 fuel pump
Stickers (+5 hp per sticker)
I know I'll be pretty much maxing out both injectors and turbo. So I'm not sure if my goal is achievable but I've read of people doing it. My engine isn't very tired. 62k miles
I get tuned in a month, appointment has been made and deposit paid.
Let me know of any recommendations to hit my goal (besides turbo, injectors, e85) just small stuff that won't break the bank.
Thank you
Kalvin
Sent from my SM-N910V using NASIOC mobile app
kalpalsti is offline   Reply With Quote
Old 01-07-2015, 03:45 AM   #570
rexblake
Member#: 178426
2010 S4
Gray
Originally Posted by kalpalsti View Post
Hey new here.
2006 sti
2. Mustang dyno
Cobb intake and box
No name turbo inlet
Perrin up pipe
Accessport v3
Ptp turbo blanky
Cobb heat shield
Stock top mount
Thank you
Kalvin
Turbo, injectors, and E85. You won't come close to your goal. Change your goal or change your turbo, injectors and possibly fuel. Call Clark Tuner and see what it takes to hit 320whp there. You can bolt on anything you want, but your turbo and especially injectors are maxed out.
Dude, you can even check Goodspeed's website and look at dyno graphs. To hit 320whp on 91 octane you would need a gt30. Not a vf39.... http://www.goodspeedperformance.com/...rin%20gt30.pdf
You might hit 270whp. Maybe. http://www.goodspeedperformance.com/...4st%20vf39.pdf
Old 01-07-2015, 08:21 AM   #571
kalpalsti
Member#: 410265
Yes I've seen those dyno sheets but I've also seen higher hp numbers on there and on here. So I was curious if anyone here has hit anywhere close to those numbers I'm looking for with a mustang dyno. I will be eventually doing the turbo and injectors and water meth. Not e85 (can't get it up here)
And I'll probably be getting the gt30 as well. I feel like that's a pretty big turbo to only make less 100whp then stock. But oh well.
Old 01-07-2015, 01:02 PM   #572
rexblake
Member#: 178426
2010 S4
Gray
Yeah, that's a true heartbreaker of a dyno. I'm not sure how much boost rey were running with those gt30 or what size they were either. Could be an old school 3071.
Old 02-12-2015, 11:14 PM   #573
bansheeracer2003
Member#: 413310
2006 STI GDB EJ207
RALLY BLUE
Good Post!
bansheeracer2003 is online now   Reply With Quote
Old 07-23-2015, 08:26 AM   #574
JTSWRX777
Member#: 425348
What would it take to get the 2016 wrx to be about the same speed as the 2016 sti?
JTSWRX777 is offline   Reply With Quote
Old 08-31-2015, 01:28 PM   #575
Jake Subie
Member#: 397369
13 STI
Default approx hp?
car is a stock 2013 sti hatch with 32xxx km
1. HP at the WHEELS (whp) or hp at the CRANK (chp)?
approx hp with these supporting mods. agency power mufflerless catback cobb catted dp,v3 accesport,grimspeed 3pbs, grimspeed aos,cobb heat shield, cobb sf intake, 1000cc injectors, Deatschwerks 65c fuel pump. on a pro tune
2. What type of dyno are you going to be shooting for this number on?
it will be on a dyno dynamics 450 ds dyno
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads.
the shop is airboy tuning in calgary alberta canada. the elevation for edmonton alberta canada is (2,201 ft)
4. Where do you live? If not a well known city, what is the elevation?
i live in edmonton alberta car will be tuned in calgary
5. What kind of gas will you be using? (octane level)
husky 94 oct
Jake Subie is offline   Reply With Quote
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 51 02-04-2016 10:19 AM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
