Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 08-15-2007, 07:12 AM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Default Brake Supersticky: brake upgrade FAQ, tech in, Brembo info, and other upgrades:
The OFFICIAL Brake Upgrade / Big Brake Kit FAQ!
http://forums.nasioc.com/forums/show....php?t=1154081
Technical information
Notes on Brake Interchangeability new!
http://forums.nasioc.com/forums/show....php?t=1529797
The STi Brembo Brake FAQ new!
http://forums.nasioc.com/forums/show....php?t=1432536
Brake Tech
http://forums.nasioc.com/forums/show...hreadid=368072
Compiled brake information: Lists of caliper types and rotor sizes for several years of Impreza and Legacy.
http://forums.nasioc.com/forums/show....php?t=1265631
Brake Fluid Info (the reference post)
http://forums.nasioc.com/forums/show...hreadid=159647
Brake Fluid and Cold Temps.
I'll call it, "Mini brake test" (WRX v. BMW braking distance and fade)
Factors that contribute to lost brake pedal travel
http://forums.nasioc.com/forums/show...hreadid=168033
Wanna help me do some brake math? (master cylinder / brake sizing)
For those that like pulling the ABS fuse (also info on brake vacuum boosters)
Brake Performance Vs. Brake Feel
How many suppliers sell brake pads to Subaru?
ABS Variables?
H6 rear brake upgrade compatibility with 04+ cars
http://forums.nasioc.com/forums/showthread.php?t=543512
New: How to read ABS light trouble codes:
http://forums.nasioc.com/forums/show...ight=abs+light
Maintainance
How to rebuild your Brembos
http://forums.nasioc.com/forums/show...php?p=32758868
Where to find Brembo touchup paint
http://forums.nasioc.com/forums/show...brembo+touchup
FYI...Where to apply grease during brake pad install
http://forums.nasioc.com/forums/show...hreadid=409262
Poor mans way of bleeding a system with ABS
spongy brake pedal after SS line install?
how do i know when my pads need changing?
rust on rotors
Flushing Brakes
Adjusting brake pedal free play
http://forums.nasioc.com/forums/show....php?t=1080164
Upgrades
Impreza L to 03 WRX front brake conversion
http://forums.nasioc.com/forums/show....php?t=1138690
Upgrading Rear Brankes '03 TS - Drum to Disc
http://forums.nasioc.com/forums/show....php?t=1153675
Subaru rear brake redux
http://forums.nasioc.com/forums/show...hreadid=243337
H-6 brake upgrade for dummies
http://forums.nasioc.com/forums/show...ad+coefficient
H6 Rear Rotor Options for WRX
http://forums.nasioc.com/forums/showthread.php?t=562057
Upgrading front brakes alone - throw off brake balance?
Way too increase rear brake bias/pressure?
confusion with oem subaru 4-piston front calipers [/quote]
The difference between various 02-03 WRX pad sizes:
http://www.stoptech.com/tech_info/faq_wrxcalipers.shtml[/quote]
Help! My ABS freaks out and the car doesn't stop!
WRX antilocks + bumps = dirty drawers!
Old 04-11-2009, 10:30 PM   #2
Suby0r-nothing
Member#: 208319
1993 Impreza & 03WRX
You have any info on removing an abs module in a 93 impreza and where its located?
Suby0r-nothing is offline   Reply With Quote
Old 06-15-2009, 05:16 PM   #3
BIGbCraig
Member#: 176718
1985 RX-7 GSL-SE
is there a general thread on/about/concerning aftermarket brake pads?
BIGbCraig is offline   Reply With Quote
Old 10-08-2009, 11:35 PM   #4
kurtdaniel
Member#: 156150
wow..a long list of informative writeups..tnx..this will truly be very useful for me in repairing my old oem nissan parts..
kurtdaniel is offline   Reply With Quote
Old 06-01-2010, 02:00 PM   #5
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
Just a random thing to add as I couldn't find it on a quick search and have since found out the info.
The bolt that holds the brake pad carrier(impreza) on to the hub assembly is a m12x1.25. I'll wager as these cars get older there will be a lot more of the "I snapped this bolt....HELP!" posts.
This and it is usually cheaper to buy a loaded early wrx caliper w/bracket once you factor in the core, than it is just to buy the wrx pad carrier by itself, for those with an earlier impreza looking to upgrade to the early wrx brake setup.
sachilles is offline   Reply With Quote
Old 06-29-2010, 03:37 PM   #6
amigabill
Member#: 144210
2007 STI
Urban Gray Metallic
I'd like to know a little more about the brakes that Subaru put on my 07 STI. I've read the article about how to choose different brake pad materials, but I don't know what material Subaru put on my car at the factory. I haven't found talk about that yet here. What material are the Subaru stock pads, as discussed on the Essex article as linked to in this thread. All I ever hear about the STI is that it has "Brembo brakes", which I'm beginning to think may just refer to calipers, not pads, but I don't really know better.
Last week I was in for my regularly scheduled oil change and the dealer says I need new rotors and pads. I'm at 41K miles, and a relatively mild everyday driver, doesn't seem like I'd have worn things down to a complete brake job. I don't hear any terrible noises during braking, nor are there any brake warning lights yelling at me.
But if they really do need replaced, I'm given a choice between two options, first is all Subaru original parts for about $1400, and the second is Hawk pads and whatever rotors for about $700. Are the Subaru parts worth about double the aftermarket kit?
I don't know which Hawk pads exactly this refers to, only the brand name.
I'd like to do an autocross here and there if I ever have time for it, but so far this car is a daily driver and little if anything else, so I don't need a super performance loud brake set, but if that's cheaper than a low-end but still expensive street pad from Subaru then why not.
amigabill is offline   Reply With Quote
Old 03-25-2011, 12:12 PM   #7
Scargod
Member#: 260314
2008 STI hatch
Default Could old FAQs (like this one) get revised?
I sincerely appreciate all the FAQs I find on this forum. I have a 2011 though and it's an STi. Some FAQs go back almost ten years! This makes me wonder what years and models of Subies they apply to...
Thanks for everything you have done and I hope I can lend some informative info from time to time. I just did a (racing), wheel-tire combo on my car and will post details soon.
Scargod is offline   Reply With Quote
Old 07-30-2011, 11:26 AM   #8
bjonga
Member#: 39419
02 WRX
Why is Z32/300ZX not included?
bjonga is offline   Reply With Quote
Old 03-04-2012, 08:16 PM   #9
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
awesome pile of info, found everything i needed
Cr4ckfi3nd is offline   Reply With Quote
Old 07-26-2012, 09:29 PM   #10
SoobieDoobieDoooo
Member#: 156440
-_- I am da wheeler
dealer king! Yeea buddy!!
Quick question. I have an '00 RSTI. I just got a set of '04 STI Brembos along w/slotted '06 WRX rotors. I know the fronts will fit, w/no issues. But as far as the rear, will I only need the adapter brake shoes & rear conversion brackets? If so, will I also need rear '04 STI rotors or will my '06 WRX rotors be fine? Thanks!
SoobieDoobieDoooo is offline   Reply With Quote
Old 09-11-2012, 06:31 PM   #11
synaZaur
Member#: 309842
Rally Blue
Quick question.. What is involved in swamping the sti hubs to a 2012 wrx?
synaZaur is offline   Reply With Quote
Old 09-12-2012, 08:16 PM   #12
sc00by4life
Member#: 97135
You've posted this several times now. Transmission, axles, suspension, etc...
Old 10-24-2012, 01:34 AM   #13
bjonga
Member#: 39419
02 WRX
Can someone tell me more information on what it would take to put subaru 4 pots on a 2010 outback 2.5i?
Old 02-03-2013, 03:23 PM   #14
gianttcr
Member#: 108790
2002 WRX 2.2 Wagon
Ok, how about this? In considering the Brembo upgrade I came across the Infiniti G37s sport calipers. They are MUCH less expensive and use a very similar 5x114.3 rotor to 05+ STi. Plus, they are DESIGNED for a 355mm oversize rotor, commonly referred to as a "big brake" kit rotor for STi. However, doing a little research, I realized that the pad size is almost exactly the same as the Brembos. Does that mean one could use the regular Brembo caliper with the larger front rotor? Does someone offer an adaptor to space the caliper up. Also, what would you do to the rear, preferably something that would work the rears a bit more, besides pad compound. Thanks, and sorry to revive old post!
gianttcr is offline   Reply With Quote
Old 04-01-2013, 12:08 PM   #15
Scargod
Member#: 260314
2008 STI hatch
Originally Posted by gianttcr View Post
... I realized that the pad size is almost exactly the same as the Brembos. Does that mean one could use the regular Brembo caliper with the larger front rotor? Does someone offer an adaptor to space the caliper up. Also, what would you do to the rear, preferably something that would work the rears a bit more, besides pad compound.
I am doing research and here's my take on your questions: Increasing the rotor size alone may do nothing but allow it to run a little cooler and only if you are really pushing the limits. They will be heavier. Without increasing the pad area you won't be accomplishing much, if anything. The rotors need to be a compatible thickness.
For the rear: unless you can affect bias there is nothing to do but better pads. I am trying to find out if there is a simple bias control add-on. It is probably illegal for street-legal cars. See my following post.
Old 04-01-2013, 12:42 PM   #16
Scargod
Member#: 260314
2008 STI hatch
Default Bias control for GR's with ABS?
I am trying to determine if there is a simple "proportioning valve" add-on for front to rear brake bias control. It might require a valve for each rear brake line. Other proportioning orifices or controls might have to be modified or removed in conjunction with adding proportioning valves.
The other thing I don't understand is the effect of removing the ABS fuse and disabling it. One friend racer says he does it on his '09 STi. Could this affect braking bias?
This is pretty good as far as specs go for the '08+ STi.
Does anyone know of a schematic for the brake lines and ABS system as to what goes where?
Has anyone done mods to the braking system for road racing? I'm trying to avoid stripping out all of the brake control system and starting over.
Old 04-04-2013, 12:02 AM   #17
jdmjack
Member#: 248430
2003 PSM Bugeye
This link don't work no mo'. Any working links?
jdmjack is offline   Reply With Quote
Old 04-18-2013, 07:21 PM   #18
Chavo
Member#: 288437
2009 Impreza WRX 5dr
black
Default When to upgrade brakes
I cant find any FAQ about when to upgrade breaks. My 09' WRX hatch is stock right now but next week I will be running Cobb stage 2 with a 3'' downpipe with a high flow cat. Also I will be installing the Eibach anti-roll kit. I am pretty sure I will not need to upgrade my brakes at this point but I plan increasing power in the future and want to know when to work upgraded breaks into my budget.
Please be as specific as you can with how "upgraded" breaks should be with certain levels of power gain. I know this subject has a lot to do preference and opinion but I guess you could say that my main concern is safety.
Any knowledge or recommendations on this subject will be greatly appreciated!
If this has already been discussed somewhere else please redirect me. Thanks.
Chavo is offline   Reply With Quote
Old 04-18-2013, 07:37 PM   #19
Chavo
Member#: 288437
black
Default Doh!
Crap! I skipped over the very first link on this thread...Duh! I thought it was pretty weird that this topic had not been discussed...Obviously i didn'd look very hard
Old 04-19-2013, 09:51 AM   #20
Scargod
Member#: 260314
2008 STI hatch
The reality is that brake efficiency has little to do with how much power you have. It has to do with how you use the power. You haven't said anything about how your current driving habits or how they may change with more power. You haven't expressed current dissatisfaction with your brakes.
Most car brakes can be overwhelmed by a day at the track (HPDE event). So, if you just plan on having a zippy DD then you may not need to do a major brake upgrade... ever. If you drive in any kind of spirited manner and want to be safer, you should start with upgrading to good pads and better brake fluid, and do that now.
Old 10-27-2013, 04:16 PM   #21
Hangtown
Member#: 319071
Default Rear Calipers
Im going to upgrade my stock 06' WRX frount and rear brakes to a BBK, I found a set I like but the rears will only bolt on if my calipers are "floating type" what is this and how do I find out if that is what is on my car.
Hangtown is offline   Reply With Quote
Old 10-29-2013, 09:47 AM   #22
Scargod
Member#: 260314
2008 STI hatch
Perhaps this will help: discussion on floating and non-floating calipers.
Sorry, I am not an expert on GD's, but I can say that for GR's, changing out the rear calipers to something bigger/racier, is not necessary; the fronts, most definitely. I may be wrong, but I want to say there is an adapter available that allows you to put a late model (fixed), rear STI Brembo on your car.
Old 08-17-2014, 05:17 PM   #23
boone1186
Member#: 324804
2010 Impreza WRX
I'm trying to sell my OE calipers from my 2010 WRX. What model/year audience should I be targeting for this sale? As in what older cars are these calipers an upgrade for? I searched a few threads with no luck so far. Thanks in advance.
boone1186 is offline   Reply With Quote
Old 10-04-2014, 07:50 PM   #24
Tha Nubbs
Member#: 312099
Do I need a bracket to mount 2 pots on my 06 lgt?
Tha Nubbs is offline   Reply With Quote
Old 10-04-2014, 07:50 PM   #25
Tha Nubbs
Member#: 312099
2 pot rears*
FS in nova: RS and other parts 4wheelmotion Private 'For Sale' Classifieds 65 06-22-2006 09:39 PM
Lots of popular items back in stock: Helix and others... Gruppe-S Engine/Power/Exhaust 12 07-21-2005 05:30 PM
FS: In-Dash DVDs and other Headunits *cheap!* Deezy Vancouver Impreza Club Forum -- VIC 2 08-21-2004 04:33 PM
What laws apply to driving in parking lots and other non-publicly owned land? Trizzle Off-Topic 9 02-14-2004 01:02 AM
Big meet info and others from Specialty! GS116 Vancouver Impreza Club Forum -- VIC 117 06-14-2001 02:54 PM
