Old 08-13-2014, 11:08 AM   #1
mukak
Member#: 395068
Yellow
Default removed factory ubrace now have a question
i have a 02 WRX and just removed the factory UBRACE ( for weight reduction purpose )
after removing the UBRACE i really didnt feel any body flex ( under normal driving ) but i would like to reinforce the bottom by adding a 4 point lower brace
i did some googling on this and 4 point braces require the UBRACE to still be mounted on the car or custom brackets will be needed to fill in the gap
where do i get a 4 point brace that I will not need to modify to fit?
i also dont wanna spend a fortune, any vendors on here got one?
thanks
mukak is offline   Reply With Quote
Old 08-14-2014, 06:54 PM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Leave out the factory subframe, do not buy a 4-point H-brace since it requires the factory subframe, and instead install the GTSpec Front Lower Tie Brace: http://www.rallysportdirect.com/GTSp...2-2007-WRX-STI
Big-E is offline   Reply With Quote
Old 08-14-2014, 09:22 PM   #3
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
That lower tie brace is a replacement for the jacking point and doesn't exactly connect the same points that a H-style brace would.
After researching it enough to realize all GD-chassis Imprezas came with the U-brace, I decided to leave mine in place. Not only did the Spec C come with a U-brace, it actually came with one with 2 additional mounting points (14 vs. 12). If I ever decide to lose mine, it'll be replaced with the HKS Kansei or Beatrush unit.
mrsaturn7085 is offline   Reply With Quote
Old 08-15-2014, 12:11 AM   #4
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
The lower tie brace does replace the OEM jacking plate and it ties in the forward inner mounting points for the control arms, which are a part of the crossmember and could use reinforcing in that area.
Only the USDM 2004 STI had the additional two mounting points at the crossmember to reinforce it with respect to the forward inner mounting points for the control arms.
The Spec-C did does in-fact have a subframe - see post #6 below for a shot from the Non-USDM FSM for reference.
The Beatrush subframe is $750+ and will not work if you have steel control arms or have aluminum control arms with rearward inner offset bushings (e.g. Whiteline ALK).
The Oswald Performance subframe will fit without any interference with the suspension, whether with OEM or offset rearward inner bushings, and most-likely will allow for almost any type of down-pipe configuration, without or with an external waste-gate blow-off.
Last edited by Big-E; 08-23-2014 at 12:15 PM. Reason: To clarify and correct content
Old 08-15-2014, 06:22 AM   #5
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Originally Posted by Big-E View Post
The Oswald Performance subframe will fit without any interference with the suspension, whether with OEM or offset rearward inner bushings.
If I felt the need to replace the U-brace I would only use the Oswald subframe.
A-man07 is online now   Reply With Quote
Old 08-15-2014, 10:29 AM   #6
mrsaturn7085
Member#: 375462
WR Blue
Only the 2004 STI had the additional two mounting points at the crossmember to reinforce it with respect to the forward inner mounting points for the control arms.
The Spec-C did not have a subframe to reduce front-end weight.
Both false; this is a rumor that has been perpetuated for years. All models have the subframe - this includes the Spec C and special-run models like the Type RA and RA-R. Since the Spec C was homologated with the 2 additional reinforcement points, it is highly unlikely that Subaru would have omitted the subframe even on the Spec C 16" wheel model (offered in 2006, and likely other years); this was the stripped down model with steel wheels, FHI brakes w/o ABS, manual rear windows, manual door locks and optional A/C. It was rarely advertised as it was intended for racing teams (the majority being Gr.N) that would be replacing many of the parts. Since the subframe would have been required for Gr.N, it would not have been removed.
Attached is a scan from my 2005 International-version FSM:
Old 08-15-2014, 11:05 AM   #7
mrsaturn7085
Member#: 375462
WR Blue
Here are a few shots showing the subframe was indeed homologated and used on the N12 (2006) car:
Old 08-15-2014, 01:30 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
My understanding is it's for crash protection, so if you like that, keep it. It really isn't intended in any way for structural rigidity (a big U shaped thing isn't exactly an optimal design for such things, nor is anything in front of the front suspension).
Old 08-15-2014, 01:57 PM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
I can tell you that it absolutely does add rigidity by coupling the rear lca mount point to the crossmember. without it the bottom of the xmember is just floating out in space.
Sent from my SCH-I545 using NASIOC mobile app
Old 08-15-2014, 01:58 PM   #10
Bikelok
Member#: 254851
2002 WRX wagon 5mt
This is my understanding as well. It's meant to "swing" the motor down and not back onto your lap in a front impact.
mrsaturn 7085, nice info!!!
Sent from my iPhone using NASIOC
Bikelok is offline   Reply With Quote
Old 08-15-2014, 02:31 PM   #11
mrsaturn7085
Member#: 375462
WR Blue
It is partially for crash protection, yes.
I look at the U-brace in a different way. Imagine the brace with the front part (the section spanning the width of the radiator) removed. This would produce two beams running front to rear along the car. Each beam then has 4 bolts connected to the chassis and 1 bolt (2 on the Spec C) connected to the front crossmember. These beams also then bridge the large gap in the bottom of the wheel well, while locating the crossmember fore/aft to the chassis.
The RA-R used a 2-point brace (ST205104S020) between 2 bolts on the U-frame. I believe this was used rather than the H-style brace because it would have interfered with the transmission aero panel (added in 2006+ JDM models).
The SPT (H-style) 4-point brace (SOA8431070) uses 4 bolts and ties the U-frame to the rear transverse link mount.
Lastly, STi offered a 3-point brace (ST205104S000) that ties the U-frame to the jacking point. This only works on the jacking point of the 2005 and earlier model STi, if I'm not mistaken, as the 2006+ plate resembles the JDM WRX model, rather than the reinforced STi 2-piece unit, but I believe the USDM plate had some reinforcement added to the top side.
The jacking point actually had a number of revisions as well (the international service manual has a multitude of configurations). The brace that Big-E linked replaces this part and ties the front transverse link mounts together essentially making it a 3-point mount. It's a well designed brace in that it connects points that will affect wheel alignment, but with the subframe already pretty stout between these two points, I doubt it would reduce movement much as there likely isn't very much here to begin with. This brace will work if you decide to ditch the subframe, however - Beatrush offers a bar for this location, as well. I've got no reason to push Beatrush other than the fact that everything I've purchased from them has completely blown me away in terms of quality.
Old 08-15-2014, 03:08 PM   #12
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I removed my U brace and replaced it with a Carbing subframe brace, never looked back.
Anyone wanna buy a U brace?
Brought to you in part by: My Thumbs
EvileyeZ88 is offline   Reply With Quote
Old 08-15-2014, 03:21 PM   #13
mukak
Member#: 395068
Yellow
ok i took the car for a few twisties ( freeway on ramps ) and the car definitely feels more softer and twisty around the corners especially at 45-60 mph
guess i will be putting back the UBRACE and getting a 4 poing HBRACE ( ebay special )
any reviews or comments on the H BRACE from ebay?
or shoudl i get a NAME BRAND 4 point brace? and if so what kind?
and i appreciate all the feedback
Old 08-15-2014, 05:19 PM   #14
mrsaturn7085
Member#: 375462
WR Blue
What have you done to the car otherwise? I can think of a lot better uses for the money than the H-brace...
Old 08-15-2014, 05:43 PM   #15
mukak
Member#: 395068
Yellow
suspension wise not much just Tein green lowering springs ( stock shocks ) Cusco rear adj sway bar, stock front sway bar and 17x8 2014 Wrx wheels and tires
Old 08-15-2014, 11:42 PM   #16
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Oh boy, green Teins huh, look here:
Tein S-Tech FAQ:
http://forums.nasioc.com/forums/show....php?t=1267918
Tein S-Tech reviews:
http://forums.nasioc.com/forums//sho...d.php?t=523585
I don't want to change the subject of the post, but in case you don't know PLEASE look at the links.
Old 08-16-2014, 12:15 AM   #17
mukak
Member#: 395068
Yellow
Tein S-Tech FAQ:
thnks for heads up.. i bought the car this way with stock shocks and green tein springs.... i am currently looking into coilovers...
and the car is a total grandpa mobile... i can push my wife toyota camry harder into corners
Old 08-16-2014, 02:55 AM   #18
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I'll just add that you may be used to the current ride height now and mistakenly install the next set up as low. In general Subarus do not like to be lowered without lots of other work to make it work right.
Keep the drop to no more than an inch from stock and you should be fine. Your car currently sits much lower than that.
Old 08-16-2014, 05:58 PM   #19
mukak
Member#: 395068
Yellow
i measured it today and it sits 14.2 inch front 14.0 inches in there rear from center of wheel to the fender lip
Old 08-16-2014, 06:39 PM   #20
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Stock US 2002 WRX is 15.59 sedan and 15.24 wagon.
Old 08-18-2014, 08:27 AM   #21
EvileyeZ88
Member#: 233501
99 outback sport
I ran the eBay h brace for about 2 years with out the u brace, I just made some spacers out of round stock and put them where the u brace would be.
Worked great, noticed a difference in stiffness
Old 08-18-2014, 09:00 PM   #22
_MADMIKE_
Member#: 251743
Just to add a data point.
'02 WRX, Ubrace bolts loose, car had sloppy steering response, steering wheel vibration at highway speeds.
'02 RS, Ubrace bolts loose, car had sloppy steering response/vague/lazy steering wheel return after turning.
'03 WRX Ubrace bolts loose, car had sloppy steering response, and a persistent knock retarding timing, one of the bolts under the rear plastic cover was no longer threaded in place.
Tightened bolts and all the above problems went away.
Also in the Service Manual there is a note to check suspension bolts every 30K miles. I now include subrame(front/rear) bolts into this.
If you feel no difference after removing your U brace, reinstall it and make sure all the bolts are torqued to the correct values, per mrsaturn7085 posting. You will feel a difference.
_MADMIKE_ is offline   Reply With Quote
Old 08-23-2014, 11:01 AM   #23
mukak
Member#: 395068
Yellow
so after driving without the UBRACE i noticed that car didnt handle as good, so I reinstalled it, took it for a drive and could tell the diff in handling right away
to any1 thinking about removing it for weight reduction its not worth it, unless u get an aftermarket brace to reinforce the bottom
my next move is to get an H BRACE, thinking about Cusco or whiteline or maybe just a simple cheapo EBAY brace
also another question, i have a 3 inch downpipe and a 3 inch HKS exhaust, will i have any clearance issues?
Old 08-23-2014, 12:12 PM   #24
mrsaturn7085
Member#: 375462
WR Blue
Whiteline's is a GC8 brace IIRC. You can make it work, but an eBay brace will likely 'feel' the same.
Doubtful but maybe? I'd probably buy a cheap-o eBay brace or one from a vendor with a good return policy because of this.
Old 08-23-2014, 11:45 PM   #25
ok....hd cowl stays!!!!
i'll say that again....HD COWL STAYS!!!
they make a HUGE difference....and you can make some easy spacers to make ANY 'h' brace fit and work just fine
and add a one piece front strut bar and ya got the golden triangle
move the battery and get a lw front bumper beam and its SHOCKING how much nicer the car is to drive
once ya get rid of the junk tein springs, that is....oh..and the garbage stock front strut tops
