Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 08-24-2014, 06:13 AM   #1
13WRXNoob
Member#: 343037
2013 GR WRX
Default 2013 WRX Brembo Swap Help
Hey fellow Nasioc members, I have some questions about swapping my stock WRX brakes with Sti Brembos. I have researched and asked numerous people about the swap and I got an idea of what setup I want for the brakes. I just want to double check and see if all the parts will be compatible to each other and It will bolt right up.
Front:
2004+ Sti Brembo Calipers
DBA 4000 Series Drilled/Slotted Rotor Pair Front 5x100-Part No. DBA 42656S-10
Hawk HPS Front Brake Pads-Part No. HAW1 HB453F.585
Stoptech Stainless Steel Brake Lines Front-Part No. STP 950.47004
Rear:
2008+ Sti Brembo Calipers
DBA 4000 Series Slotted Rotors Pair Rear 5x100-Part No. DBA 42656S-10
Hawk HPS Rear Brake Pads-Part No. HAW1 HB180F.560
Stoptech Stainless Steel Brake Lines Rear-Part No. STP 950.47504
I was wondering if all these parts would bolt up and work together. Also, I heard that the E-brake needs to be modified. If anyone can recommend a link for the part that I can buy, I would greatly appreciate it.
Sorry for my ignorance, I have a very limited knowledge about brakes and swapping. I am open to suggestions and tips.
Cheers!
13WRXNoob is offline   Reply With Quote
Old 03-16-2016, 07:03 PM   #2
hotsauze68
Member#: 430732
2013 WRX
MBP
So was it that easy!?
Front:
Rear:
Cheers!
hotsauze68 is offline   Reply With Quote
Old 03-16-2016, 09:52 PM   #3
16Rex
Member#: 435405
2016 WRX Limited
Nice bump Jr.
16Rex is offline   Reply With Quote
Old 03-16-2016, 11:53 PM   #4
JDMaccessories
Member#: 442729
You seem to have it all down pat, the conversion is straight through unbolt and rebolt + bleed your brakes & your all set!
You have already done the research and got the parts list in order - No modification required to handbrake aslong as you are using the 08+ STI rear rotors which have been cross drilled to 5x100 from DBA (OR any other brand that offers the Brembo size redrilled to suit WRX).
JDMaccessories is offline   Reply With Quote
