Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 06-01-2014, 01:07 PM   #1
subiedoutlegacy
Member#: 357802
1991 Legacy SS
Mica Red
1991 Legacy Sport Sedan EJ22t
I'm completely at a loss at the moment with this car. I just recently bought it and not long after it through a code with a super rough idle. Code 14 injector one so as any normal person would do I replaced injector one. To my dismay the code and rough idle still remains. This is what else I've checked and done so far, I hope someone can help*
-replaced spark plugs
-replaced wires
-new fuel filter*
-oil change and oil filter
-cleaned MAF sensor*
-checked compression (perfect compression)
-checked timing (good)
-checked resistance to injector (good)
-checked continuity to injector (good)
-checked purge solenoid (good)
-checked fuel pressure regulator (good I believe)
I'm at a total loss and just want to get it through inspection and running good to enjoy it.
subiedoutlegacy is offline   Reply With Quote
Old 06-02-2014, 03:20 PM   #2
slaytalera
Member#: 163816
1999 Legacy Outback
You might wanna port this in the pre 02 turbo sub forum, or check out http://bbs.legacycentral.org/
slaytalera is offline   Reply With Quote
Old 06-05-2014, 12:08 AM   #3
sqc151
Member#: 51432
steph, lmk what happened after we talked.
sqc151 is offline   Reply With Quote
Old 08-24-2014, 09:13 PM   #4
subiedoutlegacy
Member#: 357802
1991 Legacy SS
Mica Red
Hey so found out part of my issues the intake manifold was cracked. I am now in the process of getting that fixed, but the car was definitely in limp mode then.
Sent from my SCH-I535 using NASIOC mobile app
Old 08-25-2014, 12:50 PM   #5
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Good you figured it out. Cracked intake manifolds on a Subaru is pretty rare though
When the intake manifold gaskets on my 93 went bad, it just wouldn't idle for anything, similar to any nasty vacuum leak.
Good luck with it!
Shik is offline   Reply With Quote
