Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Vendor Classifieds
Old 08-17-2014, 09:50 PM   #1
AZP Installs
Vendor Sales Rating: (11)
Member#: 40160
At the Track AZP Aug/Sep Discounts on Major Services & TPMS Cloning!
Great Summer! Get Ready for Fall and Winter!
AZP has had a great summer and we've been cranking out tons of suspension setups including corner balancing and custom alignment settings. We are looking into getting a Shock Dyno sometime before the end of the year which will allow us to test your dampers before install and be able to setup matched sets of dampers. That tool will also let us rebuild your dampers with custom valving as well. Keep an eye out for that this fall. In the meantime, keep the Alignment and Corner Balancing coming!
We also would like to thank everyone who came out to our 2 Track Days at NJMP. Everyone had a blast and we had great weather both days! Be sure to ask about our AZP T-Shirts next time you stop by the shop. They are available for purchase for $20!
TPMS Service & Cloning
We keep acquiring the tools you guys need us to have to help make your lives better! So we jumped in and picked up the ATEQ VT55 TPMS Reader/Programmer. We now have the ability to reprogram your ECU for each season when you swap your winters/summers or summers/race or if one of your sensors goes bad. The even better news is that we will have blank sensors on hand and the VT55 allows us to "clone" your oem sensors that are registered to your car. This means that once complete you can switch between winter/summer/race without having to reprogram the ECU and won't get that stubborn TPMS light.
To kick this off we are offering a complete cloning setup including parts and labor for $350 which is $45 less than our regular price on this service. E-mail for details!
September Sale- 10% off all 30/60/90/120K Service and Timing Belt Services
This month we are offering 10% off all 30/60/90/120K Services or Timing Belt Services. As usual we only do a complete service when doing the timing belt including- Gates Timing Belt, Idler Pulleys, Water Pump, Tensioner, Thermostat (OEM), WP Gasket, T-Stat Gasket, Coolant drain/fill. It's also a great time to add in a Lightweight Crank Pulley since the crank pulley is already being removed for the Timing Belt Service. On the 30/60/90/120K services you can see exactly what we do for it at http://azpinstalls.com/web/index.php...major-services
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 08-18-2014, 11:37 PM   #2
AZP Installs
Member#: 40160
Old 08-26-2014, 08:30 PM   #3
AZP Installs
Member#: 40160
