Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 08-28-2014, 03:59 PM   #1
Member#: 109567
Default overheating with new oem thermostat!!!
Previous owner have removed the thermostat on my 07 sti. Its been this way since I got my car last year. Anyway had zero problem with it but since winter is coming I decided to put new oem thermostat.
I just installed it today. Started the car, let it warm up, all good. Drove for 10 min and then my gauge went up to 226 F. I just hold it there till I got a safe spot to park.
what could be wrong with new oem thermostat and new coolant??? I put my ac to hot and it was blowing really hot hot air so this mean hot fuilds is passing thru and no air lock or whatever???
qtr_wrx is offline   Reply With Quote
Old 08-28-2014, 04:15 PM   #2
Member#: 358782
2013 STi
You probably didn't get every air bubble out. Reburb the system.
Sent from my DROID RAZR using NASIOC mobile app
Razgeiz is offline   Reply With Quote
Old 08-28-2014, 05:01 PM   #3
Member#: 10228
2002 Subaru WRX
Pretty much the above. reburp the system.
mitch808 is offline   Reply With Quote
Old 08-28-2014, 05:19 PM   #4
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Pro tip when burping system: jack front of car up as high as possible. You did put the thermo in the correct way as well? The little air release valve needs to be at the top of housing.
Brother EddieJ. is offline   Reply With Quote
