Old 08-27-2014, 02:49 PM   #626
redmy
Member#: 354946
2013 WRX Hatch
Originally Posted by GrimmSpeed View Post
The splitter will be powdercoated aluminum. We make splitters for the 02-07 cars and haven't had a single issue with noise or damage. I suspect that what you've seen is from other manufacturers!
Matt Beenen
Engineering
Hopefully you're right! Thanks
redmy is offline   Reply With Quote
Old 08-27-2014, 06:39 PM   #627
Dirtyrex14
Member#: 370823
2014 WRX
. The splitter will be powdercoated aluminum. We make splitters for the 02-07 cars and haven't had a single issue with noise or damage. I suspect that what you've seen is from other manufacturers!
Just curious, what are the benefits of using aluminum over plastic? I fell like plastic wouldn't cost as much and be easier to use
Dirtyrex14 is offline   Reply With Quote
Old 08-27-2014, 08:49 PM   #628
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Sure! Plastic would require a different method of construction - probably multiple plastic injection molds for each part. Given that there will be a few different fitments of splitters, that ends up being a relatively large tooling cost. We've done a ton of work with sheet metal cutting and forming and have always found it to be a great way to make really nice parts at a reasonable cost.
I should note that the 'other' splitter is made of steel, which is much heavier than it needs to be. Despite being larger, ours will be substantially lighter.
Good question though, it's definitely something that we've discussed, along with other crazy options. In the end, we opted to keep it simple, low risk and cost effective.
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
Old 08-28-2014, 09:35 AM   #629
dwelker
Member#: 384247
2015 WRX Limited
World Rally Blue Pearl
That's exactly right! We use Solidworks, our FARO arm and our 3D printer heavily during the design/development process.
Matt Beenen
Engineering
Thats what I thought. You guys definitely use your resources. I work for a SOLIDWORKS reseller out of NY and I am so intrigued with all of the car related companies that use it. Cant wait until you get this project finished. I am waiting to get a TMIC and yours will be the one I purchase without a doubt, along with a handful of other goodies that you make.
Thanks,
Derek
dwelker is online now   Reply With Quote
Old 08-28-2014, 08:31 PM   #630
Dirtyrex14
Member#: 370823
2014 WRX
Matt Beenen
Engineering
Awesome, makes a lot of sense, I didn't even give thought to the multiple fitments, thanks for explaining!
Old 09-10-2014, 04:12 AM   #631
Nuclear Blast
Member#: 262399
Russian, while under the influence of sanctions, waiting for a new product from GrimmSpeed
Nuclear Blast is offline   Reply With Quote
Old 09-19-2014, 11:53 AM   #632
snow05gtRI
Member#: 228375
2005 Legacy GT
a thought that popped into my head... I'm guessing this doesn't fit with the stock engine cover?
snow05gtRI is offline   Reply With Quote
Old 09-19-2014, 11:57 AM   #633
zcparrott
Member#: 387305
2014 WRX
Have you decided on whether you are going to include a price for drilling and tapping for meth injection?
Sent from my iPhone using NASIOC
zcparrott is offline   Reply With Quote
Old 09-19-2014, 12:29 PM   #634
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Nope, sorry! We originally intended to try, but with it's size and the splitter, it just isn't possible!
We will not be able to offer that as an option, but will provide a recommended location and a DIY writeup on how to safely drill and tap yourself.
Matt Beenen
Engineering
Old 09-23-2014, 11:11 AM   #635
FL4TFTW
Member#: 256953
2014 WRX Hatch
No updates in a month
FL4TFTW is offline   Reply With Quote
Old 09-23-2014, 11:21 AM   #636
Relier1
Member#: 350437
Talked to one of the guys at Subiefest, he said probably by the end of the year?!....
Relier1 is offline   Reply With Quote
Old 09-23-2014, 12:57 PM   #637
snow05gtRI
Member#: 228375
2005 Legacy GT
Matt Beenen
Engineering
Figured, just wanted to ask. Thanks!
see post above yours
Old 09-23-2014, 12:59 PM   #638
FL4TFTW
Member#: 256953
2014 WRX Hatch
Okay now define update lol. He was just replying to a question. Not an update.
Old 09-23-2014, 03:59 PM   #639
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Outlet castings should be hitting the machine shop next week! I'll see what I can do about some pictures!
Matt Beenen
Engineering
Old 09-27-2014, 08:53 PM   #640
alphakiller
Member#: 94936
Any update?
alphakiller is offline   Reply With Quote
Old 09-27-2014, 08:54 PM   #641
FL4TFTW
Member#: 256953
2014 WRX Hatch
Originally Posted by alphakiller View Post
Any update?
You couldn't read the post literally right above yours?
Old 10-02-2014, 07:41 PM   #642
Anubis80
Member#: 341903
2016 STi
Hyperblue
lol it's to difficult i guess
Anubis80 is offline   Reply With Quote
Old 10-11-2014, 12:13 PM   #643
redmy
Member#: 354946
2013 WRX Hatch
Damn y'all see that top mount??!! Looks awesome! Just got myself a pw tho.. damn!!
Sent from my HTC One using NASIOC mobile app
Old 10-11-2014, 01:09 PM   #644
mdot1203
Member#: 310527
2012 WRX Hatchback
DGM, 281hp/316tq
I saw a picture on IG earlier this morning
mdot1203 is offline   Reply With Quote
Old 10-13-2014, 10:07 AM   #645
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Well, all updates are going out via the newsletter list now, but I figured I'd share this here, since it's a big step. This is the first preproduction unit to make it through welding. 'Preproduction' meaning in this case, that it won't be a sold unit. You can see that it's drilled and tapped for pressure and temperature sensors and that the weld is a touch messy. The great news is that these castings are welding up beautifully, which means a cleaner finished product and more efficient welding process.
Another big step is that with that, we now have all of the information that we need to setup final pricing for the TMIC packages.
Lastly, another development is that there's a chance that we'll actually be selling the splitter with the TMIC as a complete package. Of course, we'd have a separate package for the LGT splitter as well. We had talked earlier about selling it separately, since there are multiple fitments, but from to keep things simple for our dealers and to make sure people who are buying the TMIC know that they also need the splitter, it might just make the most sense to package them together.
Matt Beenen
Engineering
Old 10-13-2014, 10:14 AM   #646
RosscoB
Member#: 259989
2012 Impreza WRX
Is it to late for you to leave a spot for an IAT sensor near the outlet.
RosscoB is offline   Reply With Quote
Old 10-13-2014, 10:28 AM   #647
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
You'll be able to drill and tap for an IAT sensor in that same location, as needed. We did some research and given the small number of people running speed density right now (growing, I know, I use it myself), it's not cost effective for us to add that feature for you. We will, however, create a small write-up on how you can safely do it yourself. Another option would be to have a local shop weld a bung on.
The good news is that there's plenty of space on the passenger side of the car for an IAT sensor. There's also plenty of space on the driver's side, it's just not quite as accessible. Hope that helps!
Matt Beenen
Engineering
Old 10-13-2014, 10:51 AM   #648
N.Y.X.
Member#: 377857
Matt, what's up with the hammer man!??!?! Nice, level, surface???
N.Y.X. is offline   Reply With Quote
Old 10-13-2014, 12:09 PM   #649
FL4TFTW
Member#: 256953
2014 WRX Hatch
Props to anyone who waited. I broke down and brought a Process West. Looks nice though.
Old 10-13-2014, 12:28 PM   #650
WRXncrew
Member#: 39970
2008 LGT Spec.B
Quartz Silver Metalic
I will wait as long as needed, I cannot tell you how much I hate the FMS one, but got it a cheap price to hold me over.
WRXncrew is offline   Reply With Quote
