Old 08-26-2014, 10:29 PM   #1
Fredysan
Member#: 39160
1993 Legacy RS
Green
Default Stage 2 STI MY07, Is the stock muffler a restriction?
Hi:
I just finished the remap for my MY07 STI Limited with pretty good numbers. This is the virtual dyno plot:
The red plot is the car with 3" downpipe, the blue plot is downpipe plus, Perrin EL headers, Perrin uppipe, Ebay turbo silicone inlet, ported VF43 exhaust housing, boost referenced water spray and torqued performance remap.
I'd like to keep the stock look of the car, including the engine. So I keep the stock airbox, midpipe and axle back.
The car is very fun to drive because of the midrange torque, but after 5000 RPM there is a huge decrease in both, power and torque. At this time I don't intend to change the turbo, but I donīt know if is possible to get some gains with other mods, by example:
- Is the stock muffler, midpipe and airbox a restriction for this level of power?
- Is necessary replace the STI Intercooler?
- Or, How can the top end power be increased without change the turbo?
Regards from Chile
Fredysan is offline   Reply With Quote
Old 08-26-2014, 11:00 PM   #2
raikesppf
Member#: 400045
Prepare for a crash
raikesppf is offline   Reply With Quote
Old 08-26-2014, 11:18 PM   #3
pooster.online
Member#: 120461
2004 WRX STi JBP
well the stock exhaust is 2.5 inch, so without it you don't have a full 3" turboback exhaust, I'm sure it causes some kind of backpressure..
I asked my tuner if it would be okay to run my stage 2 protune (tuned on 3" turboback) with just the DP and a stock axleback, and he advised against it(and said it would change the parameters it had been tuned on)... hopefully someone else with some tuning experience can chime in on the actual effects.
As far as the intake, the general consensus is that you'd prolly only make maybe 5 more hp or less with an aftermarket intake, its not a real restriction until you upgrade the turbo.
just my 2 cents.
pooster.online is offline   Reply With Quote
Old 08-27-2014, 03:31 AM   #4
what ya want is a 'straight through' design muffler on the axle back...even a 2.5" one is just fine if it has a 'straight through' muffler
regardless of what all the kidiots think they know about exhaust
Old 08-27-2014, 04:50 AM   #5
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
You can realize modest gains with an aftermarket muffler but to see gains in the top end power you will have to change the turbo.
Old 08-27-2014, 07:41 AM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Short answer, no.
Old 08-28-2014, 09:53 PM   #7
Fredysan
Member#: 39160
1993 Legacy RS
Green
Thanks for your answer!
I will stay with the stock muffler and airbox
Old 08-29-2014, 01:48 AM   #8
jeffk182
Member#: 150649
2014 STI
The stock air box is very efficient. Even though I'm running a cobb intake with the air box, it is still no where near as efficient as stock due to it being more prone to heat soak.
Sent from my SM-N900V using NASIOC mobile app
jeffk182 is offline   Reply With Quote
Old 08-29-2014, 06:27 AM   #9
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
Actually, there is evidence put there showing that a well designed intake does reduce pressure drop especially in high RPMs which means gains in top end. But, they are modest and will not drastically change your curve. On a stage2 car, intake side is the restriction. Your stock muffler may have some effect but it is very negligible. You could look at improving the overall the efficiency of your system by wrapping and isolating the hot parts: turbo wrap, downpipe wrap. Also, ELHs would improve efficiency but that would put a dent in your stealth strategy. Overall, sorry but you will not drastically change things without a turbo swap.
Sent from my XT1060 using NASIOC mobile app
Ziggyrama is offline   Reply With Quote
