Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 08-28-2014, 05:01 PM   #1
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
Default Air coming out of oil filler neck
So my car is consuming ALOT of oil. Intercooler piping is clean. Not leaking. Some black smoke under hard acceleration but that is just fuel. Car is tuned a little rich. Just replaced pcv valve. But i thought i read a post when air is coming out of oil filler neck it means the rings are bad. Going to in the week or two get a compression and leak down in a week or two. But just curious if anyone can confirm or deny about what the air coming out of the oil filler neck may mean. Thanks in advance everyone! And have a great holiday weekend
SnowWhite07 is offline   Reply With Quote
Old 08-28-2014, 05:12 PM   #2
MikeG4936
Member#: 260561
2006 Impreza WRX Ltd
Grey
Smoke coming out is bad. Air will always come out when the engine is running.
MikeG4936 is offline   Reply With Quote
Old 08-28-2014, 05:12 PM   #3
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
is it visible air? as in smoke?
cause pressure builds up and air will come out of the oil filler tube regardless
Rob_STI_PNW is online now   Reply With Quote
Old 08-28-2014, 05:16 PM   #4
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Exhaust is bad and you will know it when you see it and smell it. How much oil is it eating?
Brother EddieJ. is offline   Reply With Quote
Old 08-28-2014, 06:54 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Smoke bad, air normal.
Old 08-29-2014, 08:44 AM   #6
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
No smoke coming out of oil filler neck. Just a little black smoke when i go WOT. AFR gauge reads 10.2 when i go WOT then climbs to 11. So far in five hundred miles i have probably gone through 4 quarts. Rotella T6. i know that is excessive. I wanted to start with PCv valve because if it was bad it could have caused problem. Car idles smoothly and runs great. Pulls strong to 18 pounds of boost. So i am guessing a compression and leak down test are next in line. There is ALOT of soot on the exhaust tip. My mechanic checked it and said it just seems to be from too much fuel. So i might have to look into getting to car retuned.
Old 08-29-2014, 10:36 AM   #7
ALOKIN
Member#: 348177
2013 WRX STI Limited
500whp on teh moonshine
Originally Posted by SnowWhite07 View Post
So I might have to look into getting to car retuned.
That's usually a good idea when you put in a new motor.
4 quarts in 100 miles??
ALOKIN is offline   Reply With Quote
Old 08-29-2014, 11:26 AM   #8
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
literally an oil change per 100 miles...
Old 08-29-2014, 11:44 AM   #9
JimmyBoyWRX
Member#: 371081
2013 WRX Limited
2006 WRX
4 quarts in 500 miles he said... Not that it matters!
JimmyBoyWRX is offline   Reply With Quote
Old 08-29-2014, 12:29 PM   #10
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
I freak when I go through 1/2 a quart in month....
Old 08-29-2014, 12:44 PM   #11
OK Houston
we have an Uncle
its got cracked ringlands....it ist dead yet but its terminal...that much oil is the tell, here
stick a fork in it...its done
Uncle Scotty is online now   Reply With Quote
Old 08-29-2014, 02:37 PM   #12
Back Road Runner
Member#: 60082
2004 Forester STI
Hehe. I hope you have $5k sitting around, because you're about to use it.
Old 08-29-2014, 02:48 PM   #13
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
of course. The five thousand is setting next to my pot of gold..........
But if that is the case on the plus i can build it stronger, better and faster
Old 08-29-2014, 02:55 PM   #14
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
one question though. If it is the motor wouldn't i see more smoke? There is none on start up. Just when i am WOT... And then it is just black and has a fuel smell to it.
Old 08-29-2014, 03:27 PM   #15
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Doesn't have to. My car didn't smoke at all, the only symptom I had of broken ringlands was my knock sensor going off.
ResidentR is offline   Reply With Quote
Old 08-29-2014, 03:35 PM   #16
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
maybe you are running so rich that its covering up the blue smoke?
that much oil in that low of miles is crazy, it would almost be pouring or dripping out somewhere.
Old 08-29-2014, 04:20 PM   #17
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
ah. When i got my last tune he mentioned something about that. He thought it was just the previous tune... well i guess time to baby the motor and start saving..
Old 08-31-2014, 04:26 AM   #18
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Compression test before assumptions ?
Sent from my SM-G900P using NASIOC mobile app
BeastianSTI is offline   Reply With Quote
Old 08-31-2014, 11:29 AM   #19
Hoon Goon
Member#: 335538
2008 WRX - Hatch
WRB - Kornluvr
Johnson valve malfunction.
Hoon Goon is offline   Reply With Quote
Old 09-02-2014, 08:41 AM   #20
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
Yep, Going to do compression and leak down test next week. Can't do now due to work schedule....
Old 09-02-2014, 08:59 AM   #21
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Sorry but if it was a PCV problem there would be trace amounts (maybe even puddles) of oil in the intercooler/piping/intake/compressor housing. This is an internal/turbo failure no doubt.
And 10.2 is pig rich. Id beat my tuner in his head if he ever tuned my car that rich....you might be getting some bore wash going on that led to the failure (s) you are about to diagnose.
2Fast4U1DAY is online now   Reply With Quote
Old 09-10-2014, 12:13 PM   #22
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
Well just did compression test. 155 across the board he said. So they are thinking it is the turbo starting to go. It is the stock turbo and i was thinking of upgrading it anyways. As far as running rich when i go WOT it goes to 10.2 and then climbs to 11. I asked the tuner about that and he said it was ok.. What numbers should I be looking for when I go WOT?
Old 09-10-2014, 03:55 PM   #23
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
Well I have done some poking around today on a plan of attack. I am thinking i will take this "opportunity" to do a slight upgrade with the turbo to a VF39. Not a big change but it will get me to where i want to be performance wise. Now I just need to find a good shop to talk to and take the car to them.
Old 09-11-2014, 07:32 PM   #24
bcollins92
Member#: 401362
I have literally the exact same symptoms as you, just replaced my pcv valve to see if thats what cures it. Im wondering if a leak down test would show something that the compression test is hiding?
bcollins92 is offline   Reply With Quote
Old 09-12-2014, 08:16 AM   #25
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
Compression & leakdown test will show you if your rings are bad. Mine came back good so the suspect is the turbo. By next friday i should have a new turbo and tune. Crossing my fingers that will fix the problem.
