Old 08-28-2014, 10:22 PM   #1
LOLWAGN
Member#: 398096
2002 Wrx
World rally blue
Default Wideband
I have a 3" turbo back exhaust and it has a welded in bung about 6-8" from the turbo the instructions for the sensor says that it should be 36" from the turbo should I go get another bung welded on or is this just something they say to cover their asses
Sent from my iPhone using NASIOC
LOLWAGN is offline   Reply With Quote
Old 08-28-2014, 11:19 PM   #2
ALOKIN
Member#: 348177
2013 WRX STI Limited
550whp IAG CD goodness
Ive had mine installed for 40k miles about 6" from teh terbo. Still works fine.
ALOKIN is offline   Reply With Quote
Old 08-28-2014, 11:34 PM   #3
LOLWAGN
Member#: 398096
2002 Wrx
World rally blue
Awesome thank you for the input I figured it wouldn't make too much of a difference but I wanted to make sure
Old 08-28-2014, 11:46 PM   #4
its byron
Member#: 345847
2004 WRX STI
WRB- 20PSI on 93oct
As long as you have clearance you're fine. just wouldnt want the sensor hitting the firewall
its byron is offline   Reply With Quote
Old 08-29-2014, 08:36 AM   #5
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Agreed, I have had mine in the same spot for some time now with no issues.
shamrock 05 is offline   Reply With Quote
Old 08-29-2014, 08:41 AM   #6
ScoobyRue
Member#: 399926
2005 STI
On dsm's we use 02 simulate. We place the wideband in the 02 housing of the turbo. No ill effects.
ScoobyRue is offline   Reply With Quote
Old 08-29-2014, 01:33 PM   #7
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Originally Posted by ScoobyRue View Post
On dsm's we....
yeah.....that is irrelevant
Old 08-29-2014, 01:39 PM   #8
ScoobyRue
Member#: 399926
2005 STI
I didn't realize that personal experience related back to other uses of the product. I was stating on a certain application we have it on the 02 housing with no ill effects.
I found the douche. That was real hard..
Btw Scotty, I am safe to assume with all of the postings you have, all you do is sit at home and fap it. I am so happy my taxes go toward supporting you and your pizza rolls.
Old 08-29-2014, 02:12 PM   #9
RoadKillDMD
Member#: 284792
2011 STI
Blurple
If you go back and read again, it states '36" from the closest exhaust port' if you're running a turbo. Not 36" from the turbo itself.
Read this, I was going through the same thing when I was installing my WB. Post #11 has a link to the instructions I'm talking about: http://forums.nasioc.com/forums/show....php?t=2415362
RoadKillDMD is offline   Reply With Quote
Old 08-29-2014, 04:54 PM   #10
LOLWAGN
Member#: 398096
2002 Wrx
World rally blue
Default Wide band wiring help
I have the power wire for the controller hooked up but the analog output wires are giving me trouble so black goes to engine ground I'm good on that one but brown is for wideband analog out put and green is for narrowband analog output? I don't know what those are or where to tie them into please help
Old 08-29-2014, 05:24 PM   #11
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Gee, I bet if you kept this to one thread you'd get an answer.
Old 08-29-2014, 06:27 PM   #12
Uncle Scotty
OK buy Nates beans
piss the **** off
we dont give a **** about dsm here
