Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Closed Thread
Old 10-15-2003, 03:16 PM   #1
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Default Stock WRX STi dyno figure with graph
ADDICT
JDM addict is offline
Old 10-15-2003, 03:28 PM   #2
wrx what
Member#: 19697
2008 WRX STi
Looks good, and glad your happy! w00t
wrx what is offline
Old 10-15-2003, 04:16 PM   #3
finger123
Member#: 42594
04 STI
black on Black wheels
wow, 260whp on 91 octane. thats pretty damn good!! so since im on 93 octane, i should be a tab higher right all??
finger123 is offline
Old 10-15-2003, 04:37 PM   #4
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
If your ECU is map to run on 93 octane, yes you should have a little more power.
wrx what.........thanks
ADDICT
Old 10-15-2003, 04:38 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Could be higher could be lower. The kind of dyno they are using is going to make it vary wildly. I would say this dyno is probably a bit on the optimistic side. You can't compare results from different dynos at all. I thought that one side was torque at first, do you have a graph of your torque as well?
dwx is offline
Old 10-16-2003, 11:25 AM   #6
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Peak power at the wheel is all around 260 whp. I think something like 258, 259, 261.....etc. The peak torque is 288.3 lb-ft at the crank.
260whp sounds right, that is what TurboXS got on there STi. Most other dynos get around 250whp.
I question the torque? You say at the crank? Not the wheel? Why would they give you wheel hp and crank torque?
I also have to go on record saying, I don't like XS Engineering charts. Why don't they show torque on there? And why do they show M.A.P. kPa? And why don't they have each side of the chart on the same scale? That just drives me batty!
Mattr762 is offline
Old 10-16-2003, 01:20 PM   #7
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
260ish HP Wheel & 280ish torque at the crank? huh?
WRSport is offline
Old 10-16-2003, 02:50 PM   #8
Tuning Factory Inc.
Vendor
Member#: 3600
It's a little high. I got 248 bone stock and 250 whp with removed resonator box. I was hittting 14.8 psi.
Tuning Factory Inc. is offline
Old 10-16-2003, 04:48 PM   #9
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Just to confirm. The DTS Dyno is the highest reading dyno of them all. That does not mean the dyno is a bad dyno.... Just for comparison purposes it reads higher then others.
Clark
AZScoobie is offline
Old 10-16-2003, 06:29 PM   #10
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Somehow the way the DTS dyno work, it doesn't measure torque at the wheel.
God.....may I ask what dyno do you use?
Clark
Clark.......thanks, I am aware of that. I like it because it make me feels good The fact is, dyno # from different brand dyno just can't be compare. My purpose is just so I know how much power I gain after I do all the mods, as long as I stay with one dyno, I am good.
ADDICT
Old 10-16-2003, 06:37 PM   #11
Tuning Factory Inc.
Vendor
Member#: 3600
I have a Dynapack 5000 dyno. Our new software reads a bit lower than Turbo XS's Dynapack 4000.
Old 10-16-2003, 06:42 PM   #12
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Thanks.
I always think Dynapack will read the highest since it is measuring power at the hub, it doesn't include the power lost from the weight of the wheels and tires. But there are so many factor involved
ADDICT
Old 10-16-2003, 10:13 PM   #13
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Throw it on a dyno dynamics Pull around 220whp and be elated.
mr2guru is offline
Old 10-20-2003, 02:17 PM   #14
Crzykdd
Member#: 11617
Errr am I missing something?? I see no dyno chart....
-Jason
Crzykdd is offline
Old 10-20-2003, 02:18 PM   #15
wrx what
Member#: 19697
2008 WRX STi
their was a chart
wrx what is offline
Old 10-20-2003, 06:27 PM   #16
strangerq
Member#: 13095
Default link to chart
strangerq is offline
Old 12-13-2012, 07:11 PM   #17
Goku2099
Member#: 336260
2007 Subaru WRX STI
Default Yay
Yay 260 whp stock is not bad
Goku2099 is offline
Old 12-13-2012, 07:32 PM   #18
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
I'll bet this thread is older than you.
LatentWagen is offline
Old 12-13-2012, 07:43 PM   #19
Corifto
Member#: 330652
1993 Legacy TW
Boys, we've got a grave digger on our hands.
Corifto is offline
Old 08-29-2014, 08:11 PM   #20
Goku2099
Member#: 336260
2007 Subaru WRX STI
I doubt this post is older than me considering I'm 30 and there is no over 30 year old STI's running around...
Sent from my iPhone using NASIOC
Goku2099 is offline
Closed Thread
Stock 06 STi Dyno Results Gruppe-S Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 02-20-2006 02:58 AM
Stock 06 STi Dyno Results Gruppe-S Proven Power Bragging 24 10-15-2005 02:24 AM
Stock VF39 STI dyno record? RainMaker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 09-20-2005 01:25 PM
100% stock 2004 STi dyno result SlowSTi Proven Power Bragging 8 11-14-2003 11:19 AM
Has Cobb ever released a dyno figure with ALL N/A mods? 2.5GT Normally Aspirated Powertrain 5 11-30-2001 03:22 PM
