Old 08-01-2014, 08:30 PM   #1
2000FourSilverSTI
Member#: 348633
Default Idle/Rev Problems
Hi guys, I'm having an issue with my 05 STI.
To start, the car just got a brand long block & many other bolt on type stuff. Everything was working fine on the 5 hour drive home.
The car needed to be aligned so this week I changed the front axles, tightened some manifold bolts that seemed to be a bit loose & also removed the fuel rail because a couple of the O rings seemed to be a bit leaky.
After I started the car I noticed right off the bat the 1500rpm idle, I wasn't thinking too much of it since the battery had been out for a while & everything, so I waited a few minutes, nothing changed.
I then realized when I pressed the throttle pedal down, the car would only, slowly rev up to 2250rpms.
I am throwing a tps code.
Have any of you had this problem?
I'm going to clean the connectors good & everything, but still.
Its almost like its in a tight limp mode.
I'm still fairly new to the Subaru game, any educated input would be great.
Thanks in advance!
2000FourSilverSTI is offline   Reply With Quote
Old 08-02-2014, 04:32 PM   #2
2000FourSilverSTI
Member#: 348633
Anybody?
Sent from my SAMSUNG-SM-G900A using NASIOC mobile app
Old 08-02-2014, 04:35 PM   #3
atomicfire
Member#: 136296
2005 STi
Well, if it's throwing a TPS code, did you check your throttle body cable is plugged in tightly? A torn o-ring can cause a vacuum leak which can cause your car to idle high.
atomicfire is offline   Reply With Quote
Old 08-02-2014, 09:14 PM   #4
2000FourSilverSTI
Member#: 348633
I replugged it in pretty firm, same issue.
I'll upload a video in a bit showing exactly what I'm talking about.
O rings should be fine now, I'm seeing no leaks or anything, but even if there was, it shouldn't be the source of my current problem.
Old 08-03-2014, 04:53 PM   #5
2000FourSilverSTI
Member#: 348633
Here's a short video of my problem.
http://youtu.be/xd9jM-FZiTQ
Old 08-16-2014, 07:33 PM   #6
2000FourSilverSTI
Member#: 348633
Cleaned tps, cleaned throttle body & anything else I could think of, same problem still..
Old 08-16-2014, 07:36 PM   #7
2000FourSilverSTI
Member#: 348633
I had the intake manifold off prior to all of this, is there anything I could have not put back together right or something that would cause this sort of issue?
Old 08-19-2014, 08:17 PM   #8
2000FourSilverSTI
Member#: 348633
Nobody?
Old 08-19-2014, 08:21 PM   #9
LGT257
Member#: 398087
2007 Legacy GT EJ257
Something still leaking? Try resetting the ecu
LGT257 is offline   Reply With Quote
Old 08-19-2014, 08:24 PM   #10
2000FourSilverSTI
Member#: 348633
No leaking, everything is tightened down & cleaned.
Reset ecu, same issue.
I'm just not sure what have caused with since it was fine before I had the intake manifold off.
I've cleaned the tps & everything with still the same issue.
I mean it possibly could be the tps, but I feel like that would just have to be bad luck or crazy timing for it to screw up after the manifold was off.
Old 08-19-2014, 08:26 PM   #11
LGT257
Member#: 398087
Usually when stuff like this happens you need to literally start from scratch. Sucks but take everything off carefully, and put back together more carefully and try again. Most likely you missed something silly or something came loose/broke. Do that and report back, that is my 2 cents!
Old 08-19-2014, 08:31 PM   #12
2000FourSilverSTI
Member#: 348633
That's what I'm going to do & have been wanting to do, just so damn busy all the time.
Old 08-19-2014, 08:35 PM   #13
LGT257
Member#: 398087
Haha yea, I feel your pain on that good sir
Old 08-29-2014, 07:26 PM   #14
2000FourSilverSTI
Member#: 348633
Default Throttle body not responding
I finally got some time today to mess with the car more. Having the intercooler off & throttle body off the manifold, but everything still plugged in, I pressed the pedal & the the blade didn't move.
So, I'm assuming its either the sensor on the pedal or the sensor on the tb itself.
I'm going to test the voltage on each sensor, any other ideas while I'm doing this?
Old 08-29-2014, 10:54 PM   #15
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
look up the diagnostic procedure for that code in the manual. See what it says to do to identify if the sensor is at fault
Sent from my SM-G900P using NASIOC mobile app
BeastianSTI is offline   Reply With Quote
Old 09-07-2014, 10:20 PM   #16
2000FourSilverSTI
Member#: 348633
So, after a completely new pedal, new throttle body, same issues..
Is it possible a certain line could be the problem?
Could a vacuum line or anything related actually be the issue?
I just can't see it not letting the car rev up, but who knows..
Old 09-07-2014, 10:31 PM   #17
novacivic
Member#: 117980
2005 sti
wr blue
Seems like a wiring issue since you replaced all the mechanical parts. Maybe now you should try looking up the diagnostic procedure or take it to a shop
novacivic is offline   Reply With Quote
Old 09-07-2014, 11:05 PM   #18
2000FourSilverSTI
Member#: 348633
One thing I haven't tried after doing some more research is the relay under the glovebox.
Old 09-08-2014, 06:04 PM   #19
conklin_02
Member#: 324190
2005 wrx STi
Did you smoke test the intake manifold? If you overtightened the bolts, you could have cracked the manifold cause a massive vacuum leak. Smoke test the intake and manifold.
Sent from my iPhone using NASIOC
conklin_02 is offline   Reply With Quote
