Old 08-30-2014, 11:01 AM   #1
Zitro
Member#: 369247
2013 WRX Hatch
Default PLEASE HELP, boost issue after ecu reset
Hey guys, I'm on a road trip to California and on the highway on a slight incline and I hit the fuel cutoff, check engine light, and P0244 code (overboost). I cleared the code/reset ecu with my accessport and kept driving. Car feels ok, but won't hit target boost. I'm protuned for 18 psi, and it won't go above 15. Did I do something wrong? I've already driven over 300 miles since the reset, and it still won't hit boost. Am I supposed to reflash the 18 psi map, or did resetting the ecu to clear the code screw something up?
Sent from my SAMSUNG-SM-N900A using NASIOC mobile app
Zitro is offline   Reply With Quote
Old 08-30-2014, 01:19 PM   #2
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Maybe your tuner set your DAM to a value lower than 1 to start. Maybe you have a boost leak. Maybe you are experiencing enough knock events for your ECU to not raise DAM back to 1. You should probably quit trying to hit target boost yo. At least until you figure out what it might be.
Old 08-30-2014, 03:19 PM   #3
Zitro
Member#: 369247
2013 WRX Hatch
I'm just nervous because I'm in San Fran and have to drive all the way back to Seattle.....played around with the AP and found out my wastegate cycle is always at 0, even when psi is at the max it's allowing me (got a 16.8 once, after I posted this, but now won't go over 16). Anything I can check for?
Old 08-31-2014, 05:59 AM   #4
jeffk182
Member#: 150649
2014 STI
I would wait to do anything until you get to your destination. Check vacuum lines from the wastegate to the boost control solenoid and other hoses. Could be something simple, could be a dead solenoid.
Sent from my SM-N900V using NASIOC mobile app
jeffk182 is online now   Reply With Quote
Old 08-31-2014, 10:45 AM   #5
Patrick92
Member#: 330541
2004 STI
PSM (01G)
I had the same problem once. I took off the battery and let it sit for a night. Then I flashed back to the stock map for a day and drove it like a grandma. Next day flashed it back to my tune and it ran like normal.
Patrick92 is offline   Reply With Quote
Old 08-31-2014, 12:02 PM   #6
Jubathoph
Member#: 382959
What are you doing for boost control? Do you have an MBC or EBCS? The stock boost control can allow boost spikes...which may have popped off an intake hose somewhere allowing a boost leak. Or there could actually be a mechanical problem with your wastegate. Check for boost/vacuum leaks; is your vacuum boost pressure above -10 psi? Do you have high AF learning values? Those can be indicators of boost leaks.
Sent from my Nexus 5 using NASIOC mobile app
Jubathoph is offline   Reply With Quote
Old 09-02-2014, 09:58 PM   #7
Zitro
Member#: 369247
2013 WRX Hatch
Well, I reached out to my tuner and he said after I reset the ECU, it defaulted economy mode, so I need to Realtime flash my 18 psi map back on. D'oh! Good to know.
