Old 08-28-2014, 11:30 PM   #1
no_name
Member#: 400237
2014 WRX
Blurple
Default Did anyone solve the non-turbo related acceleration whine?
2014 WRX
11500 miles
Alright, I've been at this for a while...searching everything and I haven't found my exact problem yet. Here it is. Acceleration whine. Sounds almost wire interference, like an energizing wire is causing feedback. (I'm not saying its electrical, the sound just resembles it). Its coming from the front of my car, I can hear it from the inside mostly at fourth and fifth gear whenever I push down the gas pedal. I can hear it bounce off things on the outside of my car when the windows are down, for example other cars and buildings. It goes away when I coast in and out of gear, and it is in the background as I accelerate past 3.5k when the turbo kicks in. It is independent of the turbo sound! It goes away when I let off the gas at any speed or rpm in 4th and 5th. It sounds like, bare with me, a high pitch, but low frequency rrrrrrreeeeeeeeeeeeeee. Almost like someone is muttering rrrreeeeee under his or her breath. Its constant and doesn't fluctuate under more or less load. Its not loud, but load enough for me to think something is wrong, or some improvement could be made.
I followed a thread that said that loose clamps on the intercooler and turbo were the cause. Tightened them, noise is still there. But now I have a whoosh sound when I build up pressure in my turbo and let off the gas..almost like a blow-off. Reguardless, Ive been under the hood, Id like to take it to the dealer and have them take a look but I dont wanna have them point the finger at me for a pre existing problem. Ideas?
no_name is offline   Reply With Quote
Old 08-29-2014, 01:05 AM   #2
Jubathoph
Member#: 382959
This is a common problem. The Malaysia plant that assembled your WRX had been infiltrated by a disgruntled band of out of work Cambodian child laborers. Some of them made it into your transfer case. The TSB is very clear on this issue. All you need to do is apply some window lubricant into your transmission fluid dip stick and you will be good to go.
Sent from my Nexus 5 using NASIOC mobile app
Jubathoph is offline   Reply With Quote
Old 08-29-2014, 01:23 PM   #3
Blown95ImpalaSS
Member#: 87629
there is a pulley, I believe it;s an idler pulley, on the front of the ej257 cars that can go bad. my 04 sti sounded like it had a supercharger on it for a few days and I thought it was a boost leak as well, but it turns out the bearings inside the pulley had disintegrated and were generating this noise (and lots of heat too).
subaru oem was $190 or so but denso/oem replacement was about $50 at pep boys and took 5 mins to replace. your car sounds like it has much less mileage on it though - keep us posted.
Blown95ImpalaSS is offline   Reply With Quote
Old 08-29-2014, 03:44 PM   #4
Xcross
Member#: 398970
2014 wrx
Video?
Xcross is offline   Reply With Quote
Old 08-29-2014, 07:07 PM   #5
Honda_K_Power
Member#: 352666
2013 WRX Premium
One thing that I noticed is that if I have my stereo set to aux with a cable in or out and the stereo is on but nothing is playing, that it whistles through the speakers depending on my throttle, and gets louder when I accelerate and quieter when I decelerate.
Could this be it? I usually don't have that problem with the stereo off.
Honda_K_Power is offline   Reply With Quote
Old 08-29-2014, 07:21 PM   #6
jeffk182
Member#: 150649
2014 STI
Normally, that would be a proper fix, but luckily our Subaru's don't have a transfer case
Sent from my SM-N900V using NASIOC mobile app
jeffk182 is offline   Reply With Quote
Old 08-30-2014, 09:20 PM   #7
no_name
Member#: 400237
2014 WRX
Blurple
Thanks for the feedback. I'll try and get a video tomorrow on my way to work. Hopefully I can get the sound on my phone. And I'll definitely check out the idler pulley and aux cable. It be great if it was something simple.
